Originally Posted by clarkgrizwald
the original poster was not smart enough to maintenance his vehicle at 30k...
You've been a bad boy!
Here is what I would do at the minimum(I'm presuming that you've only done 5,000 mile services):
Lube, oil, and filter change
Tire rotation and adjust tire pressures
Inspect tires for any unusual wear - If uneven, have a 4 wheel alignment performed
Throttle body service/cleaning (I don't care what anybody else says)
Check/clean/replace air filter
Check/clean/replace cabin filter
Inspect brake system
Clean and adjust the rear brakes (only needed if drum brakes)
Complete vehicle inspection
I've seen plenty of Camrys with Type T-IV fluid that needed to be serviced because the fluid is brown/burned/discolored. Make sure you check it. The majority don't need service but some people must drive the hell out of their cars, because I've seen it MANY times.
I've done all of this to my car with the exception of cleaning the throttle body. But I have a can of Gumout throttle body cleaner sitting on the bench calling for me as we speak. I've just been a little bit lazy.
Of course, if something else is seen while checking the vehicle over it should be addressed as well.
Make sure you apologize to the Toyota Gods before you go to bed tonight.
