Tire pressure? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-07-2007, 11:15 PM   #1 (permalink)
etc
View etc's Photo Gallery
Tire pressure?
Got Michelin HydroEdge. What's the best tire pressure for MPG? I put 33 psi in them.
This is 02 camry.
etc is offline   Reply With Quote
Old 10-07-2007, 11:21 PM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Best MPG = max inflation pressure on the side of the tire.
2006 Camry LE Special Edition
Old 10-08-2007, 01:35 AM   #3 (permalink)
boo.hoo.hoo.
desentrix's Avatar
iTrader Score: 6 reviews
View desentrix's Photo Gallery
just remember that higher psi = better gas mpg, however that comes at the price of comfort unless you have better shocks and such.
2007 Magnetic Gray Camry LE V6:
Lit door sills, F/R cathode, trunk cathode, K&N SRI, IS250 chromes, LED tails/ bulb swaps, Katzkin leather
desentrix is offline   Reply With Quote
Old 10-08-2007, 08:25 AM   #4 (permalink)
I do all my own stunts
View 07XLE's Photo Gallery
You should have a sticker on your drivers door that givces you the recommended PSI for the car based on the weight of the vehicle, what does that sticker suggest?
'07 Camry XLE V6, Titanium Silver, Moonroof, Spoiler, JBL Audio, Tint, Car Seat
07XLE is offline   Reply With Quote
Old 10-08-2007, 08:45 AM   #5 (permalink)
View Mike Murrell's Photo Gallery
I find it interesting that car mfgs. and tire mfgs. have a different opinion about tire pressure.
Phone calls to Continental, Bridgestone; Michelin tech supoort have shown that what the car mfgs. post inside the door is usually way under what the tire mfgs. suggest.
Mike Murrell is offline   Reply With Quote
Old 10-08-2007, 09:19 AM   #6 (permalink)
Gameroom cash: $555540
View Camread's Photo Gallery
35.9876543210123456789 psi
Camread is offline   Reply With Quote
Old 10-08-2007, 11:27 AM   #7 (permalink)
TRD VVTi's Avatar
That's because car manufacturers have to take into account NVH. Tire manufacturers do not.
That's why I tell people to use the maximum tire pressure that makes them comfortable between the the cars recommended pressure and the tires max pressure.
Old 10-08-2007, 02:31 PM   #8 (permalink)
TRD - thanks for the information. For those of you wondering about "NVH" - here's an overview.
http://www.frost.com/prod/servlet/ma...docid=35405241
Old 10-08-2007, 03:19 PM   #9 (permalink)
View robob2's Photo Gallery
^Thanks for the link, very interestnig.
robob2 is offline   Reply With Quote
Old 10-08-2007, 03:28 PM   #10 (permalink)
johnnyzee's Avatar
View johnnyzee's Photo Gallery
35psi, been doing it for 10+years now, perfect tire wear and handling
johnnyzee is offline   Reply With Quote
Old 10-08-2007, 09:04 PM   #11 (permalink)
Gameroom cash: $101605
View kenny1773's Photo Gallery
but if I do that, the center of the tires wear out way before the edges do
and I get noticeably worse traction in rain
I have a formula saved in my notes on another computer, once I can get to it I will post the formula here, that I was given to help figure out what the tire pressure should be for any given car.
I remember when I ran the numbers on the camry, it was higher than what was on the door plate, but lower than the max MPG on the side of the tire. The ride seemed fine, I just can't remember the details right now.
kenny1773 is offline   Reply With Quote
Old 10-08-2007, 09:36 PM   #12 (permalink)
Here and there...
Gameroom cash: $153229
View lammydi's Photo Gallery
+1 on 35 psi.
Old 10-09-2007, 12:22 AM   #13 (permalink)
Rapid Roy's Avatar
View Rapid Roy's Photo Gallery
True, but the original post only asked about maximum gas mileage, not the best balance between mileage, wet traction and even tire wear.
I have run 40psi on my wifes 02 camry without crowning. I didn't notice much mileage increase, but every bit helps. Now if I can get the putzs at Costo to put more then 32 lbs into the tires life would be good.
Rapid Roy is offline   Reply With Quote
Old 10-09-2007, 09:07 AM   #14 (permalink)
etc
At 35psi, you can feel the difference from 28-30psi. The road feel is different.
Old 10-09-2007, 07:18 PM   #15 (permalink)
Tire Pressure
(Vehicle Weight in lb/100) + 2 psi at heavier end + 2 psi all around if suspension and alignment are stock.
Example: Stock 911, 3,000 lb.
(3000/100) = 30 psi
Add 2 psi all around = 32 psi
Add 2 psi to heavy end = 34 psi at rear
With modified suspension, the result is 30 psi front, 32 psi rear.
"There is no 'golden' tire pressure"
The optimal setting depends on the individual driver and his preferences.
This is around where I run my pressure.
Camry SE I4 = roughly 3100lbs - (I rounded DOWN)
Front wheel drive assumes the front is the heavier end
Stock suspension
3100/100 = 31
+2 PSI for stock sus = 33
+2 PSI on heavy end = 35 front and 33 rear
My tires seem to be wearing ok, I have 30k miles on the stock crapstones. SLIGHT center wear happening, but not enough to worry about. If I ran them any higher the centers would burn out. It makes no sense to me to burn out the center of tires to increase fuel economy by fractions.
Tire Pressure sensors 05 Highlander GH05 1st Generation (2001–2007) 8 10-31-2007 08:08 PM
Tire pressure questions buckstom 2nd Generation (2007+) 6 09-02-2007 06:43 PM
tire pressure masteryota1 3rd & 4th Generation (1992–1996 & 1997–2001) 7 08-26-2007 06:48 PM
Odd tire pressure? newenglander 2nd Generation (2005+) 1 08-19-2007 08:28 PM
ABS, Brake and Tire pressure warning lights on!!!! DarkArcanine Archived Corolla threads 10 01-22-2006 09:15 PM
