Sunroof not Responding - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-09-2007, 06:58 AM   #1 (permalink)
atirevold's Avatar
View atirevold's Photo Gallery
Gen6 Sunroof not Responding
I did a quick search and didn't see any threads previously on this. Does anyone else have a problem with the sunroof not responding? Sometimes I'll have to sit and mess with the sunroof controls for a minute or so (pressing up, down, back, and forward) to get it to respond. It always happens when I want to open it. It hasn't ever done this trying to close it, so far thank goodness.
atirevold is offline   Reply With Quote
Old 10-09-2007, 07:12 AM   #2 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
Give this a shot. Try procedure B, it's what re-initializes the memory in the ECU:
NOTE:
  • Do NOT switch any electrically powered systems ON or OFF during initialization.
  • If electrical power fluctuates by 0.5V or more, initialization will fail.
  • Permanent ECU damage will occur if power is disconnected while the moon roof motor is operating.
Initialization Procedure A:
  1. Push and hold the "OPEN" switch until the moon roof glass reaches the full open position.
  2. Push and hold the "CLOSE" switch until the moon roof glass reaches the full close position.
  3. Push and hold the "TILT UP" switch until the moon roof glass reaches the full tilt up position.
  4. Push and hold the "TILT DOWN" switch until the moon roof glass reaches the full closed position.
  5. Confirm that the AUTO operation features work for open, close, tilt up, and tilt down. Initialization Procedure B:
  1. Push and hold the TILT UP" switch until the moon roof glass reaches the full tilt up position. Once the moon roof glass is in the full tilt up position, release the TILT UP" switch.
  2. Push and hold the "TILT UP" switch for approximately 11 seconds. The moon roof glass will begin to move. Continue to hold the switch while the moon roof glass cycles through the entire range of positions, returns to the full close position, and stops.
  3. Confirm that the AUTO operation features work for open, close, tilt up, and tilt down. NOTE: Initialization Procedure B removes the ECU memory of the original sliding force curve and resets it to the latest sliding force curve. Failure to perform this procedure may result in glass reversal/kickback during operation.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Old 10-10-2007, 08:26 PM   #3 (permalink)
atirevold's Avatar
This seemed to work, thanks!
sunroof type? keithy 3rd & 4th Generation (1992–1996 & 1997–2001) 4 10-13-2006 03:26 PM
SR5/GTS Sunroof assembly dirt666 Archived Corolla threads 1 07-05-2005 04:03 AM
The sunroof pop TSB toyota_tech_01 Scion Forum 4 11-05-2004 01:07 PM
93 Gt sunroof no worky 93gt Celica Forum 7 08-22-2004 02:13 AM
Paseo sunroof neil Tercel, Paseo, Starlet, and Sera Forum 2 07-23-2003 06:35 AM
