Wheels balanced correctly? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-10-2007, 02:29 AM   #1 (permalink)
fredberg's Avatar
View fredberg's Photo Gallery
Gen5 Wheels balanced correctly?
I had Pep Boys swap my 17's for a another set, just used the same tires. They supposedly balanced my new wheels, they charged me for it.
The new wheels are on my car now, and I looked closely at them, especially inside the rim. I don't see any counterweights. Should I be concerned?
Is it possible that the wheels are already balanced w/o having to use counterweights? Or did Pep Boys rip me off by not doing the work?
How will the ride be if not properly balanced? I think my ride is more wobbly at the sterring wheel, especially on the freeway. Or maybe its psycholocigal because I think the work wasnt' done.
Please give me any input to help ease my mind. Thanks, guys...
fredberg is offline   Reply With Quote
Old 10-10-2007, 02:50 AM   #2 (permalink)
Forgive meee.
liquidi3ladz's Avatar
View liquidi3ladz's Photo Gallery
I don't know what I'm asking but, lug centric or hub centric wheels?
2002 Camry LE I4
liquidi3ladz is offline   Reply With Quote
Old 10-10-2007, 07:32 AM   #3 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
Surely to goodness you can drive the car down the road and tell if the wheels are balanced or not. Just drive the darned thing. If there is anything wrong you will feel and hear it.
Yes it is possible that they required little or no counter weighing but they might also have weights on the inside and not on the outside. Just test drive it.
gdanaher is offline   Reply With Quote
Old 10-10-2007, 02:43 PM   #4 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
They may have static balanced the wheels with stick on wheel weights which would be the reason there are not weights on the wheel lip.
As stated above, drive the vehicle. You should be able to feel if the tires/wheels are out of balance by getting a vibration at or near highway speeds.
2006 Camry LE Special Edition
Old 10-10-2007, 03:09 PM   #5 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
They also try to hide the stick on weights behind any spokes on the wheel.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 10-10-2007, 06:28 PM   #6 (permalink)
View sundarpn's Photo Gallery
I had got 2 new yoko's avid v4s tires installed at discount tire. The two that were in the front originally had 50% treat.
SO I just asked them to move those to the rear and and put the new tires in the front.
Now feel vibration at close to 80 mph. It certainly seems to be from the front wheels where the new tires were put.
Can I ask them to balance it again?. (they have lifetime balance). Is there like a print out the balance machines give to show that balancing results?
The discount tire guys asked me if I want the other two wheels (that had the older tires) balanced. I said NO, just move them to the back (since there was absolutely no vibration before wheb they where in the front).
sundarpn is offline   Reply With Quote
Old 10-11-2007, 12:11 AM   #7 (permalink)
fredberg's Avatar
Gen5
ok, so i took off 1 wheel, and i found that Pep Boys put the counterweight on the inside of the rim, hidden. i'm assuming the balanced the rest.
but im still having vibrations between 60-70 mph. again, Pep Boys did the balancing.
shall I go to my local tires/wheels place to have them redone? thats where I usually go for tire/wheel stuff and they do great work. or am i just imagining the vibrations?
Old 10-11-2007, 12:42 AM   #8 (permalink)
Forgive meee.
How easy is it to have wheelweights fall off?
2002 Camry LE I4
Old 10-11-2007, 09:03 PM   #9 (permalink)
View marc780's Photo Gallery
About as easy as you'd imagine. I'd think twice about using jb weld on the wheel weights, let alone that little bit of sticky stuff on the weight that looks like it came from a post-it note.
Stick on weights are a compromise just for appearance - obviously. One drawback of after market wheels. What can you do, glue them on? I dont really know of the solution if you want to keep your wheels unmarred by weights.
No they are not balanced at the factory, because the wheel comes all by itself from the maker. And tire and wheel must be balanced together, tire installed - and they cant possibly know by how much the tire is going to throw the wheel off balance.
Old 10-12-2007, 12:42 AM   #10 (permalink)
Forgive meee.
I think my wheelweights fell off then. =/
2002 Camry LE I4
Old 10-13-2007, 02:29 PM   #11 (permalink)
fredberg's Avatar
Gen5 Problem solved!
so I went to my trusted wheels/tires show earlier today. they said the tires were balanced okay, but each wheel needed a hub ring. its a plastic ring that goes inside the wheel if there's too much space.
my wobbling at 60-70 mph was due to too much wheel movement from the extra space.
but they balanced them 4 me again anyways too make sure.
everything costed under $11!!!
problem solved.
Old 10-13-2007, 03:54 PM   #12 (permalink)
TRD VVTi's Avatar
Gen5
problem solved.
I'm glad it was that simple.
So apparently it wasn't done properly the first time. If the wheels don't fit the hubs properly, the hub ring/adapter was needed from the start.
That was an extremely cheap lesson.
16" versus 17" wheels Fluxaholic 2nd Generation (2005+) 14 06-22-2007 10:15 AM
2005 Corolla XRS Wheels vs 2003 Matrix XRS Wheels The Kev Master Archived Corolla threads 2 11-01-2006 10:33 PM
new owner problems dack41 2nd Generation (2005+) 17 10-04-2006 10:53 PM
larger wheels up front? salesman deceitful? zippity Camry & Solara Lounge 17 10-02-2005 10:16 AM
what does TOYOTANATION think of these wheels... xxpanipuri Camry & Solara Lounge 37 08-27-2004 07:11 PM
