Winter Tire Size Question: 215/60/R16 vs 215/65/R16 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-10-2007, 09:58 PM   #1 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
Question Winter Tire Size Question: 215/60/R16 vs 215/65/R16
I am looking for a new set of winter tires and separate 16" steel wheels for my 2007 Camry SE V6.
The stock tire size (current) is 215/55/R17. When using the tire circumference calculator found here, I found out that the proper "size down" combo is a tire with specs 215/60/R16 which is also what my dealer recommended.
Tire Calculator Linkage
However, instead of using the recommended 215/60/R16 size, is it OK to go with a profile size up? 215/65/R16 would be better because it would raise my car by 1 inch. And then I wouldn't scrape all the stuff on the underside of the car during the winter.
Aside from making the speedometer display 1MPH slower than I'm actually doing, is there any danger to go with a profile size up? I've received mixed answers from various tire stores.
Thank you to those who read and possibly answered.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 10-10-2007, 10:09 PM   #2 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1076358
iTrader Score: 7 reviews
I have Michelin X-Ice tires and i think they're 215 65 16, if not 215 they're 205s. When i get them out of the loft i'll check the numbers and let you know ifyou're still intrested, but i won't be getting them down for a few weeks.
2002 Camry SE V6 "Snow White"
Old 10-10-2007, 10:40 PM   #3 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
Same question from me: Need some opinions with sizing of winter tires
It's recommended to have narrow tires during the winter in order to thread through snow better.
It mainly depends on the amount of snow. If your in a big city, the snow should get plowed pretty fast, so you will need some decent dry traction.
I'm looking for more opinions as well, but I'm leaning towards 215/60/16.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 10-11-2007, 09:12 AM   #4 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Bump
Old 10-11-2007, 09:24 AM   #5 (permalink)
View buckerboo's Photo Gallery
In my opinion, the minimal difference that you are talking about is not a big deal. When in doubt I would go with the slightly taller tire. Keep in mind that it is metric not standard and it is an aspect ratio. So the difference between a 60 and 65 tire is nominal. 65 will give a slightly taller tire.....I emphasize slight, it is not at inch.
buckerboo is offline   Reply With Quote
Old 10-11-2007, 09:25 AM   #6 (permalink)
View SuperGoop's Photo Gallery
Here is what I did: Winter Tires & Rims on XLE (pics!)
SuperGoop is offline   Reply With Quote
Old 10-11-2007, 07:31 PM   #7 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Dilemma solved:
Winter Tire Questions Resolved: See Within
The classic tire size question... rockfish 1st Generation (2000–2006) 2 01-31-2007 03:14 PM
Lift and tire size question jkcparker 2nd Generation (2005+) 1 05-24-2006 11:37 AM
Tire size question. Jay Camry & Solara Lounge 2 09-26-2002 11:03 PM
Question for rims and tire size. please help.. guddn17 Camry & Solara Lounge 2 06-24-2002 11:55 PM
tire size question scotia Archived Corolla threads 12 04-30-2002 03:54 PM
