plz!! help me the engine is too much shaking.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-11-2007, 11:48 AM   #1 (permalink)
View mmdie's Photo Gallery
Gen5 plz!! help me the engine is too much shaking..
i have camry 2004 2.4v automatic 55,000miles im here in the philippines
now..probably there is no serious problem with my camry..
when i got this camry the engine support was completly broken..
and of course the engine was shaking if i turn on the airconditioner or
when the transmission is on R(reverse) or D(drive)..
few days ago i replaced it..i was expecting the engine was totally fine..
but now its exactly the same compare with before..my dealer said this
vibration is normal...but i dun think this is normal...cuz its too much..
has anyone had this problem? now i dun know what to do..pls help me!!
mmdie is offline   Reply With Quote
Old 10-11-2007, 11:51 AM   #2 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
How many RPM's does the dash show when you're idling?
geoff5093 is offline   Reply With Quote
Old 10-11-2007, 11:53 AM   #3 (permalink)
wow so fast reply...tnx so much...its around 6,500 i think? the dealer said thats also normal..
Old 10-11-2007, 11:56 AM   #4 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
You mean 650
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 10-11-2007, 11:57 AM   #5 (permalink)
i yup...sorry man...hehe its around 650
Old 07-07-2009, 12:07 PM   #6 (permalink)
View blackmatt3r's Photo Gallery
I've got the same exact problem. Dealer also recommending replacing the engine supports (which costs a lot a money) which I very much doubt.
blackmatt3r is offline   Reply With Quote
Old 07-07-2009, 12:21 PM   #7 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Clean your MAF and throttle body.............
Old 07-07-2009, 12:30 PM   #8 (permalink)
njerald thanks for the quick response. what is MAF btw?
Old 07-07-2009, 12:45 PM   #9 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
Remove the duct to the air cleaner so you can see the throttle area. It will be dirty. Try to clean it with carb cleaner or other similar solvent. The idle is perhaps a little slow. Someone else here can offer a suggestion how to increase idle speed on that engine. If not, the dealer can do it. Perhaps 700 rpm would be enough to settle it.
If rough idle continues, other problems could exist. A burned exhaust valve is a possibility but remote at this mileage.
gdanaher is offline   Reply With Quote
Old 07-07-2009, 12:56 PM   #10 (permalink)
'07 XLE
Gen6
The Mass Air Flow sensor sits between the air cleaner and the throttle body. It converts the air flow into an electrical signal that goes to the ECM to determine the amount of fuel to use, when to inject it, etc.
You can remove it in less than a minute and then spray/clean with MAF sensor cleaner.
gdanher has explained the thottle body procedure and you can SEARCH for more info.
Old 07-07-2009, 03:07 PM   #11 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1076358
iTrader Score: 7 reviews
accidentally moved this..it will be moved back shortly.
2002 Camry SE V6 "Snow White"
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 06:20 PM
Trouble Codes abew330 3rd & 4th Generation (1992–1996 & 1997–2001) 9 02-09-2007 01:04 PM
Do-It-Yourself : Check Engine Light - Diagnosis bonnie* Archived Corolla threads 5 01-01-2007 02:12 AM
"A" engine info freakinbox Archived Corolla threads 29 05-10-2006 12:05 AM
Jasper remanufactured engine (5sfe) cupcakes 3rd & 4th Generation (1992–1996 & 1997–2001) 10 04-01-2005 04:09 PM
