Supertech synthetic Oil?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-13-2007, 12:53 AM   #1 (permalink)
View sundarpn's Photo Gallery
2002 camry I-4
I always look at super tech full synthetic oil at walmart and wonder if it is at least as good as valvoline durablend or castorl synthetic blend?
Its again oil change time so thought of asking here.
Also any word on the Super tech filter?
I typically change my oil abt 3.5 K miles. Also how about mobil 1 drive clean 5000? or Motorcraft synthetic blend?
sundarpn is offline   Reply With Quote
Old 10-13-2007, 01:21 AM   #2 (permalink)
View XxRushxX's Photo Gallery
I wouldnt trust the stuff at walmart. I use Mobil 1 and i do my oil changes every 3k, you can put in regular oil because toyota engines do not require synethic oil, unlike BMW and MBenz.
XxRushxX is offline   Reply With Quote
Old 10-13-2007, 04:10 AM   #3 (permalink)
BANNED
View w203's Photo Gallery
you can get mobil 1 at walmart. so is mobil 1 crap? its what i use, but not on the camry. the i4 camry requires a specific engine oil. no idea where rush is getting his info from
w203 is offline   Reply With Quote
Old 10-13-2007, 04:11 AM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $510625
If the Super Tech synthetic oil meets GF-4 requirements, it will be fine but I wouldn't run it past 5000 miles because the additive package isn't that good. Given the price, you should not expect it to be the best, but it is good considering the price.
Changing Mobil 1 at 5000 miles is just wasteful.
2007 Camry 2.4L 5M
Old 10-13-2007, 04:15 AM   #5 (permalink)
What oil would that be?
2007 Camry 2.4L 5M
Old 10-13-2007, 08:05 AM   #6 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
I agree with the first part completely.
I don't agree with the second. I change the oil every 3,000 miles on my Formula and 5,000 miles on my Camry using Mobil 1. Nothing was wasted. The engines look and perform as new, the exact reason that I am using the oil.
2006 Camry LE Special Edition
Old 10-13-2007, 10:24 AM   #7 (permalink)
I work at a Garage so i know what im talking about, i was saying if that super synethic oil that you were talking about was a no name brand then you shouldnt put it in your car. I only use mobil one because most of my driving is high way to school. I still change it every 3 because its not worth driving a brand new engine 5k trust me.
Old 10-13-2007, 01:04 PM   #8 (permalink)
etc
View etc's Photo Gallery
I've used both SuperTech and Mobil 1, usually the latter, in both 2.2L and 2.4L yota engines, with success.
IMO changing the oil often is more important thanthe brand. Fresh Supertech is better than used mobil 1.
etc is offline   Reply With Quote
Old 10-13-2007, 01:23 PM   #9 (permalink)
Used Mobile 1?
Old 10-13-2007, 04:57 PM   #10 (permalink)
TRD VVTi's Avatar
Of course you do. Working at a garage means everything...
Old 10-13-2007, 05:54 PM   #11 (permalink)
BANNED
what i meant to say was if it met the gf-4 as mentioned.
i own a garage wOOt
its not a no name brand its called supertech and i've heard of it just being a wiseass but seriously i have heard of it, if it passes the gf-4 testing then you know its good enough for the i4 engine.
Old 10-16-2007, 12:31 AM   #12 (permalink)
View Camry5genrocks's Photo Gallery
It should be better than conventional oil. It is probably a group Three synthetic. Run it for 5000 miles with a good filter and send a sample to a laboratory for an oil analysis ($15-$20) to see how the oil is holding up. It is safe to run it for 5000 miles, Supertech synthetic 5W30 meets GF-4 requirements. If money is not an issue go with Mobil 1 or Amsoil signature series 0W30 ($9.95/Qt).
Camry5genrocks is offline   Reply With Quote
Old 10-16-2007, 12:53 AM   #13 (permalink)
Used oil analysis on a 5S-FE with 4572 miles on Supertech synthetic oil, and 3RZ with 4219 miles on oil. Both are engines are steel block with alloy heads...
Both look really good but the TBN is a bit low. Seems like it would be safe to run the oil to 4000-4500 miles.
2007 Camry 2.4L 5M
Old 10-16-2007, 09:29 AM   #14 (permalink)
I work with reTRDs
manaburrn's Avatar
View manaburrn's Photo Gallery
Nice research!
By the way, Supertech synthetic is all I use. Why? Because synthetic 0wnz a11 and I'm a cheap bastard.
Originally Posted by TRD VVTi
You car looks like ass!!!!
manaburrn is offline   Reply With Quote
Old 10-16-2007, 09:42 AM   #15 (permalink)
I never heard of supertech, so i dont know its reputation, took a wild shot in the dark and guessed it was a walmart brand, knowing walmart i wouldnt trust their quality jackass. w203 im happy for you.
2008 Camry SE V6
Magnetic Grey
Toyota Stand on Synthetic Oil siennavan General Discussion 51 12-09-2007 10:00 AM
Synthetic oil - your real world results? islandboy57 5th & 6th Generation (2002-2006 & 2007-2011) 57 07-18-2007 06:21 PM
Synthetic Oil KingofDiamonds General Discussion 32 01-08-2006 09:38 PM
Mobil1 5w-30 Synthetic and my 2002 Corolla??? gadawg Archived Corolla threads 6 01-26-2004 05:39 AM
