Tire Pressure Sensor - Page 3 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2007, 10:56 AM   #31 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Originally Posted by 808YOTA View Post
My light just came on tonight after I left the Hawaii vs. Fresno game (which was awesome). Nothing like capping a good night at the football game with a stress creating light.
I immediately went to the gas station and inflated the tires to the correct tire pressure. All for of my tires were a tad bit low. So I am gonna wait till the morning and check the tires.
Note: I have 18s on my Camry w/ 215/35/18s tires that I've been running for about a month now. Had the car since July and only have 2,800 miles.
I am gonna wait it out and give it a few days. If the light does not go out I'm gonna call the dealership.
Mahalo,
Shane
Don't use a two bit pressure gauge!!!!!!!!
Old 11-13-2007, 11:33 AM   #32 (permalink)
munge's Avatar
View munge's Photo Gallery
Originally Posted by darksparkz View Post
It happened to me just recently as well.
I beleive it was because the temperature in my area dropped, so it made the tire pressure go down a bit. I checked right away and filled it back to optimal pressure for cold inflation levels. The light still stays on. It stays like that for a day or two, but I made sure that there was no nails or anything.
I ended up just driving on the highway and giving it some time, and it went away after a day or two.
this was my experience too. the outside temp gauge showed 41F when the light went on, then it didn't go off til it hit 58F many miles and warmer area later.
__________________________________________________ ____________
munge is offline   Reply With Quote
Old 11-13-2007, 01:20 PM   #33 (permalink)
I do all my own stunts
View 07XLE's Photo Gallery
I had mine go off the other day, checked the pressure of the tires and they were all around 22 psi (yikes), fired up the compressor and got them all back to 30 psi, the light stayed on for maybe a minute after driving, hasn't come on since. Just the cold weather reducing the pressure.
'07 Camry XLE V6, Titanium Silver, Moonroof, Spoiler, JBL Audio, Tint, Car Seat
07XLE is offline   Reply With Quote
Old 11-13-2007, 01:53 PM   #34 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
The cold weather from Florida reduce that much psi?
Just make sure your car has been park at least 3 hours before you check to add or minus air pressure. When you car is moving, your PSI wil not give accurate reading because of the frictions the air created when your tires is rolling around.
Old 11-13-2007, 03:52 PM   #35 (permalink)
Could have been the temp change but then again I hadn't checked the pressure in a while so I can't totally blame the weather change. I'm about an hour north of Tampa which can make for up to 10 degrees different from Tampa's lows, hilly area believe it or not. I made sure to top them off first thing in the morning so the tires didn't have any heat to them. You should have seen the look on my face when I found out they were only at 22 psi, kinda looked like this
Old 11-13-2007, 10:15 PM   #36 (permalink)
JAKSTER's Avatar
View JAKSTER's Photo Gallery
Ok here are a couple of things that can cause the sensor to light up.Do you have good valve stem caps on your stems. The cap should have a rubber washer inside the cap which seals the stem tight. Another thing is where you get your air at it may be wet air they have no dryer on the line and allot of moisture gets inside your tires. This is a common problem wet conditions (rain)and sensitive electronic insturments. also freezing conditions can cause a fault. Seal the stems find a place with dry air and that may cure the problem if its not an electrical problem.
TUNER OR LATER
JAKSTER is offline   Reply With Quote
Old 11-13-2007, 10:45 PM   #37 (permalink)
Here and there...
Maybe your face looked like this
Old 11-14-2007, 07:20 AM   #38 (permalink)
A red X?
Still don't see it. probably the corporate filter here at the office.
Old 11-13-2008, 04:11 PM   #39 (permalink)
View AloRock's Photo Gallery
On my camry LE 2007, the are no sensors in the wheels anymore. So the orange warning light in my dashbord contstandly lights up.
Is it possible the shut this down ?
AloRock is offline   Reply With Quote
2004 highlander low tire pressure indicator laputagd 1st Generation (2001–2007) 10 03-19-2007 12:36 PM
Tire Pressure, How much do you have? Chazmanian 2nd Generation (2005+) 28 12-07-2006 11:49 AM
Anyone take out their TPMS sensors on a 07 yet?? Klutch 5th & 6th Generation (2002-2006 & 2007-2011) 14 09-08-2006 09:47 PM
Tire pressure sensor compatability ponq 2nd Generation (2005+) 1 08-03-2006 04:47 PM
ABS, Brake and Tire pressure warning lights on!!!! DarkArcanine Archived Corolla threads 10 01-22-2006 09:15 PM
