Fog light install help, with diagram... - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-15-2007, 09:05 AM   #16 (permalink)
rydr1's Avatar
View rydr1's Photo Gallery
Originally Posted by Luna2 View Post
20 AWG is smaller than 16 AWG which is smaller than 14 AWG.
Check it out.
that is my mistake sorry about that you are correct.
AWG is the key to the sentence.
good thing you corrected that.
rydr1 is offline   Reply With Quote
Old 10-15-2007, 01:39 PM   #17 (permalink)
carlo$'s Avatar
View carlo$'s Photo Gallery
all that is too difficult.
just wire your own relay.
forget about the schematics.
much easier to wire your own relay and switch.
look at my xrl.us website to see my schematic.
2005 LE 4 cyl
carlo$ is offline   Reply With Quote
Old 10-22-2007, 10:25 PM   #18 (permalink)
View t3knoman's Photo Gallery
Gen6 yes
yes i agree this is complicated and i dont want to mess with the wires of the inside. So i am thinking i will connect the 18 awg wire with the 15 amp fuse directly to the car battery. I will then hook the red smaller wire and jam it into the one side of the fuse for the right or left head lamp. This will all be kept with in the engine comparment. i will keep the entire harness intact including the switch (i could use it to turn it off if i want too). The fog lights will turn on everytime i turn on the head lights... IN THEORY. how does this sound?
t3knoman is offline   Reply With Quote
Old 10-29-2007, 10:26 PM   #19 (permalink)
Gen6
I figured out how far it was wired. what was missing was the relay, so i used 3 and 5 jacks where the relay is suppose to be plugged into and connected those to aftermarket relay using 18 wire. I then grounded the entire system to the body(where i saw another grounding wire) and ran the switch power to cigarette power line, i jacked into there.
Something’s to be noted
I used factory harness and factory fuses.
I used plenty of black tubes, so i don’t have nay lone wires hanging around or being run.
Something’s i will do in the future is change my connectors that are jacked into factory harness to gold and shorten all wires with gold connectors.
So far it works fine and because i am powering the switch with power outlet if i forget to turn the fogs off, they will turn off.
As for the switch I am using 3m double side tape until I find another suitable spot
Next up is my TRD 18 wheels plus 35 percent tint...
Old 10-30-2007, 08:05 AM   #20 (permalink)
carlo$'s Avatar
good job man.
2005 LE 4 cyl
Old 04-28-2008, 02:01 PM   #21 (permalink)
View manny_elmaravilla's Photo Gallery
corolla '06 CE install wiring fog lights
Hello
I have a corolla 06 EC and did not bring the wiring up of the relay or fog lights, I already have the turn signal lanterns and head fog switch, if someone can give me reference on the installation and a wiring diagram.
Thank you for your attention
manny_elmaravilla is offline   Reply With Quote
Old 04-28-2008, 02:46 PM   #22 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
Originally Posted by manny_elmaravilla View Post
Hello
Post in the Corolla forum, not the Gen 5/6 Camry forum.
geoff5093 is offline   Reply With Quote
DIY Cold cathode trunk light install (56K warn - 988KB of photos) touringcamry 5th & 6th Generation (2002-2006 & 2007-2011) 129 04-08-2012 09:32 PM
HOW TO: 2005-06 Fog Light Modification SWTRDSPORT 2nd Generation (2005+) 110 10-24-2011 07:40 AM
Fog Light Mounting Bracket for 07 Matrix. imEric! 1st Generation (2003-2008) 19 08-07-2008 01:25 AM
Mechanical Oil Pressure Gauge Install Stillrunning 3rd & 4th Generation (1992–1996 & 1997–2001) 0 09-05-2007 05:12 PM
what do u guys think? Geius Maniacal 89-95 Toyota Pickup/Hilux 33 05-26-2006 02:45 PM
