Dealer oil change - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-16-2007, 04:26 PM   #1 (permalink)
Gameroom cash: $555540
View Camread's Photo Gallery
Gen6 Dealer oil change
Took the car (4cyl) in for an inspection and I thought might as well have them change the oil too. But I just notice on the invoice they charged me 5qts. I think the 2.4 only requires a little over 4qts (I normally only use 4qts myself), now are they charging you for a full quart because they have to use a little bit extra or do they actually fill all 5qts? I just checked the dipstick and its about a qtr of an inch over the mark. is this ok?
Camread is offline   Reply With Quote
Old 10-16-2007, 04:45 PM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Probably would be best if you both used the correct amount of oil.....
Ask the dealer how much they used and if there is a problem!!!!!!!!
Old 10-16-2007, 05:07 PM   #3 (permalink)
View Mike Murrell's Photo Gallery
I've owned 4 Toyota's: '83 4 cyl truck, '04 4 cyl Tacoma, '06 6 cyl Avalon; '07 4 cyl Camry.
Following the instructions in the owners manual with regard to refill quantity and using a new dealer filter, I've noticed that the oil level in all 4 has always been above the full mark after an oil change with time for the oil to settle.
If your car holds 4.2 qts., you're going to get charged for 5 qts. Should they give you the left over qt?
If they have one to give, maybe so, but some dealers use guns to refill with.
Given all of the things that can go wrong when a dealer works on a car, I wouldn't worry much about a little oil.
If they actually changed the filter and added close to the right amount of oil, consider yourself lucky.
Mike Murrell is offline   Reply With Quote
Old 10-16-2007, 05:17 PM   #4 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
4.5 QTS With Filter
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 10-16-2007, 09:12 PM   #5 (permalink)
View marc780's Photo Gallery
Given all of the things that can go wrong when a dealer works on a car, I wouldn't worry much about a little oil. If they actually changed the filter and added close to the right amount of oil, consider yourself lucky.
Lol yep. So many horror stories i've read here about shop oil changes i think i agree.
And usually they are not going to have left over oil to give because they use bulk oil from 50 gallon drums.
Old 10-16-2007, 09:27 PM   #6 (permalink)
The Connoisseur
CharmCityES's Avatar
takes 4.5 qts with the oil filter and its right on the money.....hence they charge for 5 qts
The "Executive Sedan"
Old 10-17-2007, 07:38 AM   #7 (permalink)
I do all my own stunts
View 07XLE's Photo Gallery
Could be worse, V6 need 6.4 quarts! I think if a dealership uses a pump to fill, they should be able to charge for the nearest 10th of a quart. That'd be like putting 11.2 gallons of gas in your car but getting charged for 12. Change your own oil, you'll still buy 5 quarts (7 for V6) but get the oil you paid for and you know it's done right.
'07 Camry XLE V6, Titanium Silver, Moonroof, Spoiler, JBL Audio, Tint, Car Seat
07XLE is offline   Reply With Quote
Old 10-17-2007, 08:14 AM   #8 (permalink)
Thnx for all the advices. The first time I changed the oil in this car, I used 4 1/3qts. I checked it several days later and it was way over the mark. So now I'm only buying 4qts and its still right at the max dimple.
WTF! 2007 Camry SE Only Giving Me 263.7 mi WITH Full Tank! LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 262 01-15-2011 01:17 PM
1st oil change, 08 Corolla, Did I make the right choice? phs 9th Generation (2003-2008) 12 10-15-2007 04:44 AM
Another oil change horror story! witxp 5th & 6th Generation (2002-2006 & 2007-2011) 16 05-13-2007 12:29 PM
About to change my oil on my new camry,what type oil to change it to?high mileage cam Whitecamryghost Camry & Solara Lounge 9 09-25-2005 11:36 PM
Oil Change Camryfanatic Camry & Solara Lounge 12 11-06-2003 08:08 PM
