does anyone know how to take off the front bumper? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-16-2007, 07:20 PM   #1 (permalink)
View 07toycamry's Photo Gallery
Gen6 does anyone know how to take off the front bumper?
does anyone have a diapgram of how to take off the bumper?
camry 3.5 k&n intake, eibach springs, 20's, hid kit, fog lights, led's, strut bar, chrome trunk piece, centric rotors drilled and slotted, trd brake pads.
http://www.cardomain.com/ride/2930405
07toycamry is offline   Reply With Quote
Old 10-16-2007, 07:23 PM   #2 (permalink)
Gorky_Park's Avatar
View Gorky_Park's Photo Gallery
Tie it with the rope to a tree and reverse real hard.
JK don't do it.
Don't really know. I normally just try to locate all the plastic tabs and take them off as I go.
2007 SE i4
Gorky_Park is offline   Reply With Quote
Old 10-16-2007, 07:44 PM   #3 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
Pm me your email address so I can send you the attachment.
Old 10-17-2007, 06:17 PM   #4 (permalink)
another_person
View cdtran's Photo Gallery
From a post on HIDplanet.com
Originally Posted by Larry aka LittoDeviL
Hey, yea actually I pulled more pieces off the first time then I should've so maybe I can help you to take off the bumper with removing only the pieces tha'ts needed.
Starting with the hood open, take out that 10mm hex black screw in the middle. Then take a philips #2 tip and take out the two rubber bump stops for the hood (one toward the driver and one toward the passenger side). Then... along the same area you'll notice a bunch of plastic pushin round tabs all along that area. You ONLY need to take out 1 near each of the headlight. And it would be the Second To Last on each side. So not the one that's right next to the headlight, but the second one away from the headlight.
That basically completes the top.
Under the bumper on the permeter will be a bunch of grayish 10mm socket hex screws so remove those. Then when you get to either end, there will be a BLACK 10mm socket hex screw. Only take one out from each end, the one on the edge of the bumper, you don't need to remove the other 2 next to them.
Then in your wheel well, in front of each tire you'll noticed a plastic tab. Take a flat screw driver and turn it 1/4 turn. Then pull it out, like all the way out. You can't leave part of it in there, you have to pull it out, either take a plyer or something.
One last 10mm hex gray screw is behind that wheel well flap. You can take a screw driver and push the black flap away where the bumper meets the fender. You'll see that 10mm gray hex screw. Just remove it with a socket or a philips screw driver.
Pull on each side of the bumper. Pull it forward and at the same time lift the bumper up so the top of the bumper (where it meets the hood) can come off the rails.
And that's it. When I first took it off, i had the car on a lift so I took all the black plastic panels underneith the car off too hehe which wasn't needed. But when you put it back together, you have to make sure part of those black panels slide into the bumper and some of it doesn't. The ones where you took those gray 10mm hex screws are the ones that has to be on the outside or below the bumper, not into it.
cdtran is offline   Reply With Quote
Old 10-17-2007, 09:36 PM   #5 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
I took my front bumper off in about 15 minutes to install my fog lights. If you get stuck anywhere just ask me and i'm sure I can help you.
geoff5093 is offline   Reply With Quote
Old 10-17-2007, 10:53 PM   #6 (permalink)
Here and there...
Dude, I just emailed you the information.
Old 10-17-2007, 11:18 PM   #7 (permalink)
thanks guys for all your help!
Old 11-10-2007, 05:58 PM   #8 (permalink)
ram
ram's Avatar
View ram's Photo Gallery
does anyone know where to find the pics to cdtran's writeup?
SE I4: 20% Tint All Around, H.I.D., K&N Air Filter, Blacked Out Headlights. Future Mods: Blacked Out Tails, Hoen Fogs, Lowering Springs, Exhaust, LED Side Markers
ram is offline   Reply With Quote
Old 11-10-2007, 06:13 PM   #9 (permalink)
View tonyizhurr's Photo Gallery
Gen6
hey can you send me the attachment to take off the bumper too? after you take off the bumper i can install a grille correct?
20" black lenso's /w red brake calibers, 6000k HIDs, tint my car site
tonyizhurr is offline   Reply With Quote
Old 11-10-2007, 10:13 PM   #10 (permalink)
Here and there...
Tony,
Pm me your email address then I will send the attachment. Also, you can install the grille without take off the bumper.
Old 11-10-2007, 10:25 PM   #11 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1076358
iTrader Score: 7 reviews
hahahahahaha!!! before i even opened the thread i was going to type that
2002 Camry SE V6 "Snow White"
Old 11-11-2007, 10:20 AM   #12 (permalink)
another_person
I don't have any pics, but I can take some the next time I take my bumper off to test my retro(hopfully tomorrow, but if not, then sometime before thanksgiving) The write up is fairly detailed, so if you follow it, you shouldn't have a problem.
Old 11-11-2007, 10:54 AM   #13 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Try your Service Manual................
Old 11-11-2007, 11:37 AM   #14 (permalink)
geoff5093's Avatar
It's honestly not that hard. I had absolutely no idea what I was doing, or what to look for. I just unscrewed anything that was attached to the bumper pretty much, and when you start to pull on it you will notice if/where the other screw(s) are located.
Old 11-11-2007, 12:56 PM   #15 (permalink)
Eyekutr's Avatar
View Eyekutr's Photo Gallery
another helpful post
11 Sienna XLE / 07 Camry / 06 GS300 / Retired from service 04 GX470
Eyekutr is offline   Reply With Quote
Fullsize spare hybridamp 5th & 6th Generation (2002-2006 & 2007-2011) 13 01-24-2007 08:56 AM
Fix Front Bumper Scratches 2005 Matrix XR (?) Matreks 1st Generation (2003-2008) 5 11-09-2006 09:57 AM
Front Bumper Questions obeycamgiant Camry & Solara Lounge 0 04-23-2006 08:53 PM
Camry Front Bumper Removal saltypig Camry & Solara Lounge 5 01-21-2004 04:13 PM
Problems with the paint on front bumper? (2000 Celica GT-S) Adambriz Celica Forum 1 05-11-2003 05:01 PM
