Gen 5 (2002) camry - how to remove clips in trunk - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-17-2007, 09:15 PM   #1 (permalink)
View dash242's Photo Gallery
How do I remove the clips that hold covers in trunk? Need to change my license plate light bulbs.
dash242 is offline   Reply With Quote
Old 10-17-2007, 09:36 PM   #2 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
flat head screw driver. pop the inner piece out and than just pull the clip out.
CamrySExxx is offline   Reply With Quote
Old 10-17-2007, 09:46 PM   #3 (permalink)
The Connoisseur
CharmCityES's Avatar
i just use a phillips head screwdriver....apply very small pressure, and the inner piece will screw loose, and then you can just pull the clip out
make sure you use a flathead to pull the inside trunk release (the green inside handle) apart and get the piece that holds it in place, or else the cover wont come off
The "Executive Sedan"
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
Camry 2002 - How to remove the climate control panel? kalinaprobe 5th & 6th Generation (2002-2006 & 2007-2011) 7 02-25-2005 06:30 PM
2002 Camry 4 cyl - Suspension Sucks? 2002CamryNJ4cyl 5th & 6th Generation (2002-2006 & 2007-2011) 7 02-23-2005 12:25 PM
Gen 5 Billet grill by Trenz (2002 Camry) edfrsd 5th & 6th Generation (2002-2006 & 2007-2011) 8 08-21-2002 09:04 PM
