Putting SE wheels on a LE Camry (07) issue! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-18-2007, 11:01 AM   #1 (permalink)
View ScottFern's Photo Gallery
Well, I just found out the hard way that you cannot put 17" SE rims on a LE that came with 15" steelies without having the tire pressure sensor go off.
Just a heads up to all you guys who want to put 17" SE rims on your LE with steelies the LE Camry is NOT compatible with 17 SE rim tire sensor.
I just wasted like 4 days of my car sitting at the dealer.
Wish there was a way to remedy this? I hope they don't charge as I had no idea and never knew the tire pressure sensors are completely different on the 17" SE rims and 15" steelies. DOH!
2007 Toyota Camry LE I4
ScottFern is offline   Reply With Quote
Old 10-18-2007, 11:23 AM   #2 (permalink)
boo.hoo.hoo.
desentrix's Avatar
iTrader Score: 6 reviews
View desentrix's Photo Gallery
What was the matter? It wouldn't fit?
If thats the case, I read a thread somewhere that involved a guy modifying the TPMS to fit..
2007 Magnetic Gray Camry LE V6:
Lit door sills, F/R cathode, trunk cathode, K&N SRI, IS250 chromes, LED tails/ bulb swaps, Katzkin leather
desentrix is offline   Reply With Quote
Old 10-18-2007, 11:33 AM   #3 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Good God.......So Wrong!!!!!!!!!!
What 15" steelies?? Amazing!!!!!!!!!!!!!!!
The tire sensors are the same, not different!!!!!!!!!
The 7 digit number (transmitter ID) on any replacement tire sensors or tires with tire sensors them have to registered in the ECU by the dealer. It's that simple!!!!!!!!!!!!!!!!!!!!!
If you don't have the number, the tires will have to be dismounted to read the numbers.
The first reply was lame too!!!!!!!!
Old 10-18-2007, 11:36 AM   #4 (permalink)
Here and there...
Gameroom cash: $153229
View lammydi's Photo Gallery
Are you sure the dealer isn't jacking you around???
I just did this 2 days ago.
1. I bought a set of TPMS from 07 Camry LE steelie on ebay from the LKQ Corp.
2. I brought my car to my dealership. The service advisor didn't think it would fit. I asked if I can talk to the wheels/tires specialist. (each dealership has at least 1 person)
3. The specialist look at my Lexus GS rims and my TPMS from ebay and said it should fit. If not, we will not charge you. If it works, we'll charge you 1 hour of labor.
4. An hour later, my car was done with 4 TPMS inside my rims+tires and the Tire sensor light on the dash board finally went away (it has been 10 months) after he reprogrammed them. He also told me, I could have write down the serial number of each sensor with the exact wheel location (FR,FL,RR,RL) from any local tire shop then bring it in so he can reprogrammed them.
Old 10-18-2007, 11:58 AM   #5 (permalink)
From what I understood the onboard computer in the car that reads the sensors in the rim are different on the LE (15" wheels) and the SE (17" wheels). This is what I was told anyway.
There is no chance they try and bill me for this warranty work is there?
Old 10-18-2007, 12:01 PM   #6 (permalink)
Wait a second. Your saying that the transmitter ID on my new 17" wheels has to be registered in the ECU? Meaning the ECU does not recognize the serial numbers on these 17" wheels which never came on my car?
That seems so silly that a transmitter ID would have to be registered. I guess the dealership doesn't want to find out what those IDs are?
Old 10-18-2007, 12:16 PM   #7 (permalink)
'07 XLE
Gen6
Like, Yes, Doh.............
Quit discussing about non-existent 15" wheels. They should have been 16"!!!!!!!!!!!
There is no warranty work and they should bill you for their work.
It's your screwup.
Since a good number of forum posts contain misleading/wrong information, check it out in your Service manual!!!!
Old 10-18-2007, 12:31 PM   #8 (permalink)
View streetxdreamer's Photo Gallery
Ummm if u think about it, its not that silly. Alot of new cars come equipped with this feature. So to keep the system from not mixing up signals from another car the TPMS is registered to the ECU.
streetxdreamer is offline   Reply With Quote
Old 10-18-2007, 12:33 PM   #9 (permalink)
Eyekutr's Avatar
View Eyekutr's Photo Gallery
This is retarded !@!
11 Sienna XLE / 07 Camry / 06 GS300 / Retired from service 04 GX470
Eyekutr is offline   Reply With Quote
Old 10-18-2007, 12:49 PM   #10 (permalink)
View 07toycamry's Photo Gallery
yeah i have 20's and i never had no problems with my sensors
camry 3.5 k&n intake, eibach springs, 20's, hid kit, fog lights, led's, strut bar, chrome trunk piece, centric rotors drilled and slotted, trd brake pads.
http://www.cardomain.com/ride/2930405
07toycamry is offline   Reply With Quote
Old 10-18-2007, 01:03 PM   #11 (permalink)
with my sensors
Did you take the sensors out of our existing rims and put them into your 20s? No need for the thread crapping.
njerald, my bad you are correct they are 16" steelies. Yes, I now get how it makes sense that the sensors are unique to the car's ECU and how that is beneficial. Wish I knew this a week ago. I suppose the only remedy is to take out the sensors from my 16" steelies and then put them into my new 17" SE rims. Lesson learned!
Old 10-18-2007, 01:20 PM   #12 (permalink)
i wasnt crapping and yes i did
Old 10-18-2007, 01:25 PM   #13 (permalink)
My bad, I was referring to Eyekutr.
Old 10-18-2007, 01:29 PM   #14 (permalink)
Eyekutr's Avatar
It is a well known fact that the TPSs are interchangeable but they are mated to your car from the factory. What is retarded is that the car has been at a dealer for 4 days....WTF for ??? This should go something like this...
You:
I bought 17s with sensors in them and put them on my car, now my light is on
Service advisor:
You need them programmed for your car OR you need to swap them over, take your pick, have a nice day @!@@@
Old 10-18-2007, 01:40 PM   #15 (permalink)
'07 XLE
Gen6
You:
Service advisor:
That assumes that he told the dealer that he had other tires/wheels/sensors installed rather then go in and scream warranty!!!!!!!!!
07 Blue Ribbon SE w/ aftermarket wheels Smok3y 5th & 6th Generation (2002-2006 & 2007-2011) 6 02-04-2007 03:08 PM
My New '07 Camry SE 4 Stnd Shft Camuser15yrs Camry & Solara Lounge 3 09-17-2006 07:28 AM
Can I Retrofit 2005 Camry SE Headlights to a 2002 Camry LE??? LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 20 07-31-2006 10:54 PM
rim manufacturers? fireman9170 2nd Generation (2005+) 6 02-19-2006 11:05 AM
