Camry syereo upgrade - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-18-2007, 09:36 PM   #1 (permalink)
View HDLLLIII's Photo Gallery
I need some accurate information for a stereo upgrade. I bought a 2007 Camry LE 4 cyl that is a base car. The stereo leaves a lttle to be desired compared to what I had been listening to. I like the appearance of the factory stereo but need a cost effective way of upgrading. With that being said, will it be a plug and play situation if I purchase the upgraded sound system from a higher end camry/avalon. Or should I look into the aftermarket for the best cost effective upgrade? Thanks in advance for your responses...
HDLLLIII is offline   Reply With Quote
Old 10-18-2007, 09:41 PM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Use the search function.
The audio/speaker topic has been covered ad nauseum for the last 18 months on a large number of threads.
Read the threads and throw out the useless.........
Old 10-18-2007, 10:49 PM   #3 (permalink)
spoon059's Avatar
View spoon059's Photo Gallery
Easiest thing to do is replace the stock speakers with some quality aftermarket speakers. Maybe get a 4 channel amplifier as well. That way it appears stock, but sounds much better. The headunit itself has little to do with the way it sounds.
2008 Camry SE
I4 auto
Leather, JBL, VSC
spoon059 is offline   Reply With Quote
Old 10-18-2007, 10:54 PM   #4 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
That exactly what I did. I replaced all four 6x9 stock with JBL speakers and a JL amp under the passenger seat. It sounds so much better. I sat inside my friend Camry that has a JBL system. It sound the same as mine.
Old 10-18-2007, 11:00 PM   #5 (permalink)
Gorky_Park's Avatar
View Gorky_Park's Photo Gallery
I swear if you could ONLY post informative AND/OR positive comments some people on here would have 1 post, because they would not be able to refer someone to use search option..I say if you don't have anything nice to say don't say nothing. My $0.02.
As far as stereo goes, I say get a "12 L7 solobaric with mono d rated amp 800W RMS at 2 Ohm and some 250W 4 channel amp with some polk audio mids you'll be set. $450-$600 depending on your bargain skill. Use Ebay or Craiglist both are straight.
2007 SE i4
Gorky_Park is offline   Reply With Quote
Old 10-18-2007, 11:05 PM   #6 (permalink)
97 Avalon Silver Spruce
View parimento1's Photo Gallery
Originally Posted by lammydi View Post
That exactly what I did. I replaced all four 6x9 stock with JBL speakers and a JL amp under the passenger seat. I sound so much better. I sat inside my friend Camry that has a JBL system. It sound the same as mine.
you were able to get the rear speakers to fit without the magnets hitting the trunk rod?
parimento1 is offline   Reply With Quote
Old 10-18-2007, 11:08 PM   #7 (permalink)
The Connoisseur
CharmCityES's Avatar
i'd upgrade to JBL componets....its a great system and im sure youll like it better
as for headunits, they make a dash kit for gen 6 and u can choose th headunit to suit you
The "Executive Sedan"
Old 10-18-2007, 11:12 PM   #8 (permalink)
Here and there...
At first it was hitting the trunk rod. I brought it back and the guy kinda bent the rod just enough to made it not rubbing anymore. And yes, the trunk open and close just fine.
Old 10-19-2007, 02:31 AM   #9 (permalink)
Bootyologist
View 2k4CamThrilla's Photo Gallery
Is that safe to do? Or you just don't care?
www.myspace.com/djkraz
2009 Toyota Camry SE-(BLK LEATHER,NAVI,Debaged,Blue LED shifter mod,20% Tint)
2004 Toyota Camry LE(SOLD)
1989 Ford Tempo AWD(SOLD)
2k4CamThrilla is offline   Reply With Quote
Old 10-19-2007, 09:56 AM   #10 (permalink)
spoon059's Avatar
its safe, the metal rods you refer to are actually the tension springs to hold open the trunk. If you just tweak them a little bit you should be fine. If you bend them too much, the trunk may not hold itself open as high, or someother adverse effect like that. But it should still close and latch securly without messing up the gaps in your body.
2008 Camry SE
I4 auto
Leather, JBL, VSC
Old 10-19-2007, 10:18 AM   #11 (permalink)
Here and there...
Exactly, as long as the trunk still open and close without rubbing the speaker...that's all I care.
Old 02-27-2008, 06:25 PM   #12 (permalink)
JohnnyBerry
View JohnnyBerry's Photo Gallery
Gen6
I have a 07 SE with the non-JBL stock radio. A friend upgraded his JBL to NAV and gave me his head unit -- but kept the amp and speakers.
Based on what I saw on the JBL - Toyota page I was planning on buying an amp and replacing the speakers & wiring, but I was told today at Sound Advice that I would have to purchase the JBL amp that originally came with the head unit for it to work in my car.
Does anyone know if there's a way around this because I saw the amp on sale at Wilde Toyota Parts for $655 - that seems a little high (yeah I know I got the head-unit for free) but I think I might be missing out on something here.
JohnnyBerry is offline   Reply With Quote
Old 02-27-2008, 06:44 PM   #13 (permalink)
'07 XLE
Gen6
You're going to need some wiring from the headunit to the amp, power to the amp and the amp to all the speakers also. and tear out 50% of the interior.
Have fun!!!!!!!!!!!
Old 02-27-2008, 07:03 PM   #14 (permalink)
B0R1CHA
b0r1cha's Avatar
Gameroom cash: $125535
View b0r1cha's Photo Gallery
actually changing the headunit makes a noticable difference depending on what kind you get. at least thats what ive noticed on my accord. but anyways quick question is there a DIY on speaker replacement for the 6th gen or can someone at least tell me how to get to the speakers? i kind of have an idea but i like to make sure and get my facts straight before i perform an operation on my car
19x8.5 +35 Axis Hiro for sale
b0r1cha is offline   Reply With Quote
Old 02-27-2008, 07:49 PM   #15 (permalink)
'07 XLE
Gen6
It's in the Service Manual..............
Toyota Camry Remains America's Best-Selling Passenger Car humanoid Toyota News 0 10-06-2007 03:04 PM
08 Accord EXL-V6 vs Camry SE V6 krispykreme 5th & 6th Generation (2002-2006 & 2007-2011) 12 10-01-2007 08:43 PM
2007 Camry Reviews 71Corolla 5th & 6th Generation (2002-2006 & 2007-2011) 17 01-16-2007 10:54 PM
1999 Camry, should I upgrade? geoff5093 3rd & 4th Generation (1992–1996 & 1997–2001) 7 01-12-2007 12:09 PM
04' Camry Sportivo 6Stacker Mp3 Upgrade SportivosRock 5th & 6th Generation (2002-2006 & 2007-2011) 0 04-20-2006 02:56 AM
