Stalling and VSR/Trac Off
History:
My friend and I did a brake job on his 03 Camry since the dealer quoted $1000. We replaced front rotors/pads and rear pads. A pretty easy job actually.
Prior to the brake job, it had a CEL that we had checked. We were told that it was corrosion on the gas cap. We cleaned it up and put some grease on the seal. Then cleared the codes by disconnecting the battery.
Problem:
Now the car will not idle at a stop. It shuts down like the key was turned off. So we took it to see if there were any stored codes in the ECU that maybe did not activate the CEL. There were none.
I did a search here as well. A number of people said it will clear up on its own and that the ECU needs to "re-learn" or something. I drove it for about 1/2 an hour but it actually seems like it's worse. It certainly isn't getting better at least.
Now on top of that, the VSR/Trac Off light came on right after we had the codes checked. This was about 40 miles after the brake job and immediately after the code check.
Can anyone shed any light on this for me? I am stumped.
The good news? The CEL isn't on.
Thanks,
Dave
"The normal make a living. The deranged make history." -Christopher Titus
