'03 4-cyl ATF change - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-22-2007, 09:42 AM   #1 (permalink)
View jjvb's Photo Gallery
I bought this Camry used and it has 60k and I am going to change the ATF. Do I need any parts other than a pan gasket? Anything out of the ordinary? Thanks.
jjvb is offline   Reply With Quote
Old 10-22-2007, 10:43 AM   #2 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
Trans filter. Comes as a kit with the pan gasket.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 10-22-2007, 10:51 AM   #3 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
You don't have to even get a gasket. You can just drain the fluid from the drain plug.
It is certainly a good idea to examine the content of the normal wear materials in the bottom of the pan. But honestly, if you aren't having a problem there isn't much to be gained by doing so.
A drain and fill would probably be sufficient.
2006 Camry LE Special Edition
Old 10-22-2007, 11:56 AM   #4 (permalink)
The Connoisseur
CharmCityES's Avatar
i'd assume the drain and fill should suffice at 60K....changing the filter tho and dropping the pan for an inspection isnt a bad idea either
my car has 52k and i usually change my trans fluid with toyota ATF fluid every 20k
The "Executive Sedan"
Old 10-22-2007, 12:51 PM   #5 (permalink)
Thanks for the replies guys. I have never changed the ATF in any of my other vehicles without changing the filter. Maybe it isn't necessary. Perhaps that is why the Toyota dealership only does a drain and fill unless you specifically request a filter change. It's really not much effort to drop the pan and change the filter. What to do..........
Old 10-22-2007, 02:55 PM   #6 (permalink)
View marc780's Photo Gallery
Its pretty easy to change ATF but some important points to keep in mind:
1. Check the dipstick and/or owners manual for what ATF to use. I think your model car requires Type IV Toyota fluid and this is a dealer only, about $5 a qt. Toyota says to use no other kind of fluid and they warn of bad shifting if you do. If you are just doing a drain and fill and no pulling the pan, its a little over 3 qts to refill.
2. I think your year car might have a metal strainer and not a gauze filter like other cars. This means you clean it in solvent and dont replace it unless you like buying these things for some reason.
When i got my 2002 V6 it had 66,000 on it and the first thing i did was change the fluid. Ive maintained and pulled plenty of trans in the past and most of the filters i have removed at this mileage were more or less clean - so i didnt even bother pulling the pan (i am lazy when i can get away with it).
I'd bet you if you pull the pan now your strainer will be pretty much clean and you will wonder why you bother with all this mess, but if the fluid looks dirtier than it should be, then i would bother with removing the pan.
Old 10-22-2007, 07:16 PM   #7 (permalink)
View Mike Murrell's Photo Gallery
I have never seen a transverse-mounted 4 cyl Asian car that used a transmission filter.
As TRD said, pull the plug and drain.
It's a "rotation" type drain. By that I mean you will likely only remove about 1/2 what the system holds.
I've seen Accords go over 300K using a rotation drain and Toyotas have likely done so as well.
Mike Murrell is offline   Reply With Quote
manual tranny. fluid change, 4 cyl. selftc 2nd Generation (2005+) 0 04-20-2007 10:56 AM
Gen 3.5 Oil Change camryelaine 3rd & 4th Generation (1992–1996 & 1997–2001) 4 05-19-2006 07:23 AM
How to: Change tranny fluid? SmokeyWren 2nd Generation (2000-2004) 4 04-29-2005 11:51 PM
