Have owned 03 Camry since new. Keep having problem with rodents in heater fan motor compartment. Cannot see where or how the squirrels can get in...they filled the whole compartment with pine cones, until the fan wouldn't even turn. I've never had this happen with other makes of cars....maybe there is a screen missing???
Usually they nest on top of the filter and not in the blower area.
Rodents can fit into the smallest spaces. It probably a mouse/rat/chipmunk type of animal and not likely a squirrel.
You really need to get rid of the rodent. They like to chew wiring for some reason and can lead to very expensive damage.
My father recently had mice nesting in the air filter box and under the engine cover of his car. They chewed through the wiring for the transmission range sensor. I had to splice in a new pigtail for that part of the harness. He didn't even realize that the transmission wasn't shifting properly until I noticed the harness during a routine visual inspection. This occured on his Oldsmobile.
Thanks for the quick reply...I'm positive it's a squirrel....they chewed through the filter and I removed the cabin filter and installed a heavy wire mesh to stop them...two days later..FULL of pine cones...again. Thanks again!
The only time that I've seen a rodent that large inside the car was because the cowl was removed and a possum climbed inside. When the cowl was reinstalled it was trapped and died inside the vehicle because it was trapped (this happened at a body shop).
Mice eat acorns, pine cones and the like also. For a squirrel to get in you must have large hole/gap in the cowl area at the base of the windshield or the firewall area. Be sure to check the door jamb by the front door hinges also.
Make sure the rodent is gone before you block it's access point. If it dies in your car you're in for a serious mess.
When I go to the cottage, I have a similar problem with our Benz ML500. Basically, chipmunks steal drywall insulation (fire and sound fiberglass stuff) and create a "next" right on top of the battery.
The battery is located in the top-left corner in the engine bay. The ML's V8 really heats up and in the winter the engine bay remains warm for quite some time. That's why the chipmunks love it.
I've cleaned up probably 20 times, and they keep up setting up "shop" in there. When the Camry is parked in the exact same spot, they never ever set up shop in its engine bay. Only in the ML for some reason.
I have found absolutely no solution to this. In fact, each month during the winter, I get my mechanic/friend to inspect if any hoses in there have been eaten or else.
__________________ 2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
haha this isnt uncommon at all....any rodent (squirrels included) can get into the smallest of spaces....theyre very creative....there are many openings under the vehicle's engine bay in which they can crawl into, and hence they have an easy way to get into the heater box and keep warm....inspecting it regularly is the only option, o creating some sort of shield under the vehicle to keep them from being able to enter....
i can consult my toyota manuals and see if i can locate the closest acess point so you can make some sort of way to close it off....just make sure the "guest" is gone before doing so...dead animals dont smell too good in cars
Put a little cup of rat poison in there, But make sure you keep checking in there so when the die, they dont rot.
__________________ Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals “My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
Yup, the mice sneak in the garage when it's open and you're not looking, they then find warmth on the car when the light goes out.
In the old days of waterpump mounted fans and huge radiator shrouds, cats would be a problem... Start the engine and mmmmmeeeeeeyyyyyooooooww!
They will get anywhere that isn't protected and chew the hell out of wiring... I've rewired countless trailers and we'd find mice and such in snowmobile pipes and airboxes... Boats accumulate them in the winter time. Mothballs will keep them away, but I wouldn't really want mothballs in the heater blower.
Are you sure there's no other opening they're getting through, like maybey through a floor vent? Maybe a hole in trunk and there's a path to the blower box, look for evidence like scat or dropped nest/food material.
