KONI Adjustable Shock Inserts for 02-03 (maybe even 03-08?) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-23-2007, 03:58 PM   #1 (permalink)
I work with reTRDs
manaburrn's Avatar
View manaburrn's Photo Gallery
UK KONI Adjustable Shock Inserts for 02-03 (maybe even 03-08?)
Okay, guys, I got together with the KONI Engineers in the Netherlands, and they sent me the drwings of the European strut inserts (hack up OEM strut, insert KONI). What someone needs to do now is precisely measure the OEM struts to see if these babies will fit our US Camries.
Measurements like this need to be taken in mm:
Maximum total length (normal state)
Minimum length (fully compressed)
Diameter of body (e.g. everything but the rod)
Length of body
Diameter of rod at each step
Length of each rod step
Thread size and pitch
Honestly, the thought of taking my struts off and apart again makes me want to vomit, so if anyone would like to volunteer, please by all means. I'll post the above measurements of the KONI inserts later on tonight when I get home.
Also, as far as I know, 02-03 Camrys have different struts that 04-06, and I have no idea about 07-08, but I'm pretty sure they use the same springs as the 04-06. For all I know, the only difference is the spring seats, and if that is the case, you guys may very well be able to use these inserts also.
Originally Posted by TRD VVTi
You car looks like ass!!!!
manaburrn is offline   Reply With Quote
Old 10-23-2007, 04:06 PM   #2 (permalink)
Not-So-New TN User
Netforcer's Avatar
Gameroom cash: $225700
Why can't koni make their own shocks? are european specs different from us spec?
My Partial Partout!!!
Photo Album
Old 10-23-2007, 04:17 PM   #3 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
If Koni was interested in the future sales, they could buy a front and rear strut for their own examination.
Old 10-23-2007, 05:09 PM   #4 (permalink)
I work with reTRDs
manaburrn's Avatar
Wow, you guys are so helpful.
Old 10-23-2007, 05:26 PM   #5 (permalink)
& JustAnotherCamry
View JustAnotherAsian's Photo Gallery
suspension components can't be done without sacrifice- usually in form of an interested customer willing to give up his/her car for about a week so that manufacturers can do their r&d.
i would be concerned if koni wasn't going the extra length to make sure it fits usdm gen5 camrys by not requesting these measurements. apparantly, someone in the uk already gave up their camry for a week for koni to produce the shocks- koni just wants some measurements to make sure usdm gen5 shocks are identical to the uk counterparts.
JustAnotherAsian is offline   Reply With Quote
Old 10-23-2007, 06:11 PM   #6 (permalink)
johnnyzee's Avatar
View johnnyzee's Photo Gallery
an IDEA, a good one...
Buy a new stock strut from an auto parts store that allows returns with receipt (should be the majority of stores). here in canada we have canadian tire and partssource. Yankees got Autozone.
So, "Get in the zone", "Autozone", hook one up, measure it out, tell them you didn't need it and done deal.
good idea? why take your struts apart?
johnnyzee is offline   Reply With Quote
Old 10-23-2007, 09:07 PM   #7 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
We have guys here that work at dealers and parts stores.
Can anybody check the different years?
That's a lot easier than taking a car apart.
2006 Camry LE Special Edition
Old 10-24-2007, 02:58 AM   #8 (permalink)
I work with reTRDs
manaburrn's Avatar
From Drawings
8610-1421SPORT (Front Insert, externally adjustable)
Maximum total length (normal state): 608mm
Minimum length (fully compressed): 425mm
Diameter of body (e.g. everything but the rod): 43mm?, 38.75mm? (stepped @ 225mm from bottom)
Length of body: 359mm
Diameter of rod at each step: 14.85mm, 20mm?, 21.75mm
Length of each rod step: 38mm, 4.5mm, 206.5mm
Thread size and pitch: M14X1.5
86-2639SPORT (Rear Insert)
Maximum total length (normal state): 674mm
Minimum length (fully compressed): 461mm
Diameter of body (e.g. everything but the rod): 44mm?
Length of body: 404mm
Length of each rod step: 38mm, 5mm, 227mm
Old 10-24-2007, 03:09 AM   #9 (permalink)
I work with reTRDs
manaburrn's Avatar
Now, the important measurements are the max length and the body diameter, because they won't work if they are too long or won't fit inside the body of the OEM strut.
Also, if you do make any measurements, please tell us EXACTLY what you are measuring (e.g. OEM, OEM Replacement, Aftermarket), because KONI's site says explicitly "for original struts only". What I don't want to happen is for someone to go measure a KYB or Monroe and it turns out that the body is a different diameter than the OEMs or something like that.
Old 10-24-2007, 03:33 AM   #10 (permalink)
& JustAnotherCamry
bingo.
bump.
Old 10-24-2007, 08:34 PM   #11 (permalink)
Asian N00b Modder
Gellenole's Avatar
View Gellenole's Photo Gallery
corcamry is affiliated I believe, if anyone, he can provide that info!
1995 Camry I4 @ 123k Miles - RIP 5-26-07
[Silverado Backed into it]
Originally Posted by catric69 View Post
It's cheaper if you get a new gf.
Gellenole is offline   Reply With Quote
Old 04-03-2009, 02:37 PM   #12 (permalink)
A stock Camry? Blasphemy!
Gibson99's Avatar
View Gibson99's Photo Gallery
old thread from the dead... did anything come of this?
98 Camry CE v6 5s
97 MX-5
95 Camry SE v6 2dr SC (sold)
www.gibson99.com
Gibson99 is offline   Reply With Quote
Old 04-06-2009, 03:30 PM   #13 (permalink)
& JustAnotherCamry
^i second. my rears are blown, and the only decent option out there is oem/kyb.
Old 04-06-2009, 03:33 PM   #14 (permalink)
The Connoisseur
CharmCityES's Avatar
i had the KYBs and they were OK...not great but OK
i had a front strut blow out within 2 months of install, and i had to get a new one sent out to me...
from now on i will only use oem's unless someone like koni would actually make something for our cars
The "Executive Sedan"
Old 04-06-2009, 09:54 PM   #15 (permalink)
Asian N00b Modder
Gellenole's Avatar
I gave up -- i'm getting coils -- on snap! I said coils!!!
anyway, i purchased a set of BC racing coils, from what I heard, they are the closest to teins as you're going to get -- spring rates are almost the same and I've heard nothing but raves with them. plus they come with an external reservoir.
other words, give up on a good set of shocks -- they'll never come. get coilovers and adjust ride height and your dampening, best to just spend a bit more and get what you need/want.
Superpro/Whiteline Group Buy due to North America wide Price Increase raptorracing Supporting Vendor Sales 51 07-22-2009 11:12 AM
Whiteline; Superpro and Dobinson Group Sale ...PART II raptorracing Supporting Vendor Sales 93 05-02-2007 05:02 AM
Whiteline MA70 Front/Rear Adjustable Swaybar GroupBuy!! raptorracing Supporting Vendor Sales 30 04-27-2007 03:27 AM
Whiteline; Superpro and Dobinson Group Sale raptorracing Supporting Vendor Sales 222 03-09-2007 05:51 AM
going to attempt to replace shocks lilmudmonster 89-95 Toyota Pickup/Hilux 12 07-12-2006 05:25 PM
