Takin the Cam on its first road trip - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-29-2007, 08:58 AM   #1 (permalink)
Portholes are the Sh!t
CheeseHead91182's Avatar
View CheeseHead91182's Photo Gallery
In 3 weeks I will be fullfilling a childhood dream and going to Green Bay to see Brett Favre and the Packers at Lambeau Field. It will be the first time taking a long trip like this. So I was wondering should I get my car looked at before going on the trip? It just had an oil change and tire rotation about a month ago so I would think it would be alright but I don't want any problems on this trip. Also I was wondering about cruise control, I've never used it and my dad never used it on any trip we took, so I was wondering what are the benefits of using it?
CheeseHead91182 is offline   Reply With Quote
Old 10-29-2007, 09:09 AM   #2 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
Check and adjust tire pressure, including on pony wheel. Cruise control makes sure you don't need to give gas anymore. And it also leads to the most efficient operation of the car at the set speed (i.e. uses the lowest gear possible, no sporadic gas, etc).
However if you're still in your break in period, then do not use cruise control yet.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 10-29-2007, 09:11 AM   #3 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
Have fun with your road trip. It's a new car so you don't need any additional service. You should check the basis like check the folowing to make sure they are at the recommending level:
oil
coolant
coolant reserve
brake
power steering
tires psi
If you have a second set of headlight bulbs then bring it with you.
Other than that just fill up the gas and have fun!!!
For the cruise control, the benefit is better mpg assuming you're on flat surface most of the time. It also let your right foot rest during the long trip. The downside? You can fall asleep easier because it's kinda boring using the cruise control. I usually don't use the cruise control more than 1 hour because I like to feel the car through my pedal.
Old 10-29-2007, 09:38 AM   #4 (permalink)
So if you have cruise controll on you cannot hit the brakes?
Old 10-29-2007, 09:54 AM   #5 (permalink)
Here and there...
The cruise control will be disarmed when 2 things happened:
1. You stepped on a brake pedal or
2. you manually turn off the cruise control button
You have never use the cruise control before?
As Njerald said, you should read your owner manual about cruise control.
For the statement "break-in", that the "break-in" perior for new engine. You should not be driving the same speed on a new engine for a long period of time (the cruise control does just that)
You should drive normal with variations of speed to allow your engine parts to wear out normal.
Old 10-29-2007, 10:04 AM   #6 (permalink)
View Camrygen6's Photo Gallery
Correct me if I'm wrong, but, will it also disengage if you hit on the gas pedal?.
2AZ-FE VVT-i PZEV
Camrygen6 is offline   Reply With Quote
Old 10-29-2007, 10:27 AM   #7 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1076358
iTrader Score: 7 reviews
nope it doesn't, you can hit the gas to pass a car, but when you let off it goes back to the set speed.
I use cruise all the time when heading up north, as long as traffic is light. in the long run it will save some gas, but nothing to be excited about.
2002 Camry SE V6 "Snow White"
Old 10-29-2007, 11:03 AM   #8 (permalink)
View atsotnas's Photo Gallery
if the weather is bad, do not use the cruise control.
there have been accidents that happened while using cruise control on wet or icy roads as the cruise control hit a pool of water or an icy patch the wheel would then spin much faster and as soon as your tire hit the pavement would eventually push your car much faster than you have anticipated.
other than that use your cruise as you please and you will see how more it helps on the fatigue factor for long drives aside from the fact that it will also save you some gas in the process.
have fun and be safe on your road trip.
alex
atsotnas is offline   Reply With Quote
Old 10-29-2007, 11:20 AM   #9 (permalink)
Yeah I have never used it before and as many trips as my fam has taken, my dad never used cruise control even though every car he he has had since 1988 has had cruise control. So I've never even seen it in use.
Old 10-29-2007, 11:47 AM   #10 (permalink)
before you leave, go on a hwy and just test it out, and get used to setting your speed, and engaging "coast" when you need to slow your speed (not stop) it saves using the brakes.
Old 10-29-2007, 12:59 PM   #11 (permalink)
Wow you know you all were really helpfull. After the portholes thing I didn't think you guys were all that nice but I was wrong.
But Punks_not_dead5, you need to take down that Red Sox avtar, I hate them. They shouldn't have beaten the tribe like that.
Old 10-29-2007, 01:07 PM   #12 (permalink)
View clarkgrizwald's Photo Gallery
i think you should check your portholes before the trip, make sure thier funtionality is good, make sure there is clear breathability between your engine bay and the fake hole. the LAST thing you need on a road trip is a failed porthole. trust me! it renders your car useless!
are yall for real??? people dont know how to use cruise control????
clarkgrizwald is offline   Reply With Quote
Old 10-29-2007, 01:11 PM   #13 (permalink)
yazofets, once again, you.....
cruise control is NOT the most efficient way to operate a car. as if everyone doesnt already know that...
Old 10-29-2007, 01:16 PM   #14 (permalink)
Here and there...
I'm glad I can be helpful to you. Many members here had gone out of their ways to helped me before. We all good members here, just that some of us express our opinions a little more than others. It's all good.
Old 10-29-2007, 03:01 PM   #15 (permalink)
You know i was being nice until you said that about my Red Sox.......now you can just kiss my ass........I'll get rid of the Red Sox stuff when you get rid of your uglyass portholes and stop defacing the Camry name...
Scrapyard in the GTA TdotTercel General Discussion 16 11-23-2011 03:18 PM
Took her on a 320 miles road trip and now Shes "ICED" Just a few pics. lotust 2nd Generation (2005+) 22 06-13-2006 04:54 PM
Road Trip Question jhbhatia Off Topic 7 04-16-2006 07:28 AM
Road Trip with Camry ToyotaToday Camry & Solara Lounge 9 03-30-2006 02:39 PM
Alpine Navigation installed for trip... Choops 2nd Generation (2005+) 16 03-24-2006 11:27 PM
