Shifter modification? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-29-2007, 08:32 PM   #1 (permalink)
Forgive meee.
liquidi3ladz's Avatar
View liquidi3ladz's Photo Gallery
I was thinking back to my old car (88 accord) and I remember how the shifter could be pulled from D4 to D3 without pushing the button. Now I know same thing 4-3 could be done but turning off o/d, but is it possible to mod the shifter so I can pull it from D to 2 without pushing the button? Being able to pull the shifter from N-D-2 would be nice.
2002 Camry LE I4
liquidi3ladz is offline   Reply With Quote
Old 10-29-2007, 08:43 PM   #2 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
whats the diff in just holding the button in? i usually drive with my hand on the shifter anyway and the thumb naturally rests on the button..
edit: and u prob cant do that without also allowing the shifter to go into reverse and park without holding the button also, which is quite dangerous if you ask me(a slip of the hand or a fumble could throw it into reverse at a high speed and then kabloomy!)
MrSo0h0o is offline   Reply With Quote
Old 10-29-2007, 08:57 PM   #3 (permalink)
Forgive meee.
Since theres already a lock at neutral, could it be at all possible to keep it and only have it go the other way? Holding the button in creates more of a drag while pulling down (or the illusion of) Haha but I guess I could get used to it..
2002 Camry LE I4
Old 10-29-2007, 09:02 PM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Get a stick shift, no buttons to press. Just two pedals to play with. Cluth in shift to N, blip gas to match, shift to next lower gear clutch out.
I drove older Hondas before and I don't remember the shifter bing able to go from D to 2 without pressing the button. The shifter would stop once it hit the S position.
2007 Camry 2.4L 5M
Old 10-29-2007, 09:09 PM   #5 (permalink)
Forgive meee.
Older honda, I recall are like, D4-D3-2.
I wish my car was a 5spd.
2002 Camry LE I4
Old 10-29-2007, 09:16 PM   #6 (permalink)
Maybe the Prelude was different. It went from D to S3 and then there was a S4 button on the handle that would allow it to go to 4th in S position. I remember the shifter wouldn't go past S without pushing the shifter button though.
2007 Camry 2.4L 5M
Old 10-30-2007, 08:18 AM   #7 (permalink)
View McNose13's Photo Gallery
I've gotta ask, as I never understood the Honda shifting thing (being able to go switch gears w/o the button).
Why are you even changing gears often enough for this to be an issue?
I currently drive a manual, but I've had autos and have never switched to anything but drive (save for maybe decending a hill). I've driven (not owned) Hondas and thought it was a stupid design I kept putting the car in D3 instead of D.
b
McNose13 is offline   Reply With Quote
Old 10-30-2007, 05:13 PM   #8 (permalink)
Forgive meee.
I like forcing a downshift/engine braking.
2002 Camry LE I4
B&M Shifter Install musubi 2nd Generation (2005+) 19 02-26-2008 09:54 PM
Stiff shifting with TRD quick shifter Jose123 Archived Corolla threads 1 05-18-2005 03:17 PM
Shifter assembly modification details Meisner Camry & Solara Lounge 10 07-23-2004 08:31 AM
Gen3 TRD Short Shifter install (and NEW fix for a solid feel)... BLUEMEANIE 3rd & 4th Generation (1992–1996 & 1997–2001) 6 05-30-2004 10:51 PM
shifter questions menaboy64 Camry & Solara Lounge 2 06-12-2003 12:33 PM
