brake sqeak at 10,000 miles - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-01-2007, 02:18 AM   #1 (permalink)
View krouchchocolate's Photo Gallery
I was leaving my apartment, and when i was braking to get out. I heard a nasty break squeak. Is this normal at 10,000 miles?
The thing is, it went away after i got onto the main street at the light. I only heard the squeak 2 times after i left the apartment, then it was fine again.
Is this something i should let the dealership look at or should i just replace the brake pads.
krouchchocolate is offline   Reply With Quote
Old 11-01-2007, 04:50 AM   #2 (permalink)
I callz it like i seez it
View ScrooYoo's Photo Gallery
was the squeak coming from the front or back? Take off a wheel and inspect your brake pads to see if they're worn down. Its not that unusual for pads to wear out at 10k especially if they're cheap ones. If you have to replace them buy the good stuff, they last twice as long.
ScrooYoo is offline   Reply With Quote
Old 11-01-2007, 05:10 AM   #3 (permalink)
rommel5u's Avatar
View rommel5u's Photo Gallery
Gen6
i had the same experience when my camry se v6 is still around 5000 miles. it still does it once in a while but it goes away. i checked my pads when i was rotating the tires but they were fine. my opinion is that it's the accumulation of brake dust because when my car is clean i never notice it.
rommel5u is offline   Reply With Quote
Old 11-01-2007, 08:58 AM   #4 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
I would say that if it's just at first it's probably normal. It's not abnormal to get some brake squeaking on occasion.
You should check the brakes though, just to make sure that there isn't a problem.
2006 Camry LE Special Edition
Old 11-01-2007, 09:27 AM   #5 (permalink)
View Aceventura9586's Photo Gallery
If you just had a frost cuz of winter rolling in, then you could have had a skim of moisture or some such gunk on your rotors. I get that sometimes when my car is parked outside at night. It just builds up some stuff on the rotors then it rubs off and its good to go.
Aceventura9586 is offline   Reply With Quote
Old 11-01-2007, 12:03 PM   #6 (permalink)
2007 Black XLE V6 Camry
View smilepak's Photo Gallery
my reach 13k miles when it start shaking the steering wheel on braking at high speed. Turned out the rotor were warped. From research, it seems a few people had to change their rotor around 13k - 16k miles.
Took it into the dealer and had it replaced with new pad, under warranty.
smilepak is offline   Reply With Quote
Old 11-01-2007, 12:35 PM   #7 (permalink)
Yeah winter started, but the car was in the garage. The temperature wasn't that cold outside either.
The squeak was coming from the back.
If i do decide to change the pads, any recommendation on brake pads? The GOOD shit!
Old 11-01-2007, 02:08 PM   #8 (permalink)
View danorthface's Photo Gallery
it's normal.. the pads rust and make the squeak noise.. once you stop once or twice, the squeaks go away
danorthface is offline   Reply With Quote
Old 11-01-2007, 03:29 PM   #9 (permalink)
daveart's Avatar
View daveart's Photo Gallery
Canada
first thing in the morning,its the condensation on disc,not to worry,the dealer will service them but it will come back,like i said its just condensation on the disc
daveart is offline   Reply With Quote
Old 11-01-2007, 04:16 PM   #10 (permalink)
Gameroom cash: $303755
It's actually the rotors that rust from the condensation, not the pads. If you have ever washed a car with alloy wheels (allowing visual access to the rotors) while it is still a bit warm, you can actually see the rust form on the rotors, as you are washing the car.
Mike
Old 11-01-2007, 11:54 PM   #11 (permalink)
Mistabullet's Avatar
View Mistabullet's Photo Gallery
There is a TSB out that may or may not apply to what you're experiencing.
BR008-06 --- FRONT BRAKE SQUEAK
BR010-06 --- REAR BRAKE SQUEAK
If the problem persists, go to your dealership and ask them to apply the TSB's (give them name of TSB)
Mistabullet is offline   Reply With Quote
Old 11-02-2007, 12:03 AM   #12 (permalink)
It seem to only happen once. Drove my car again tonight, and i did not hear anything. I was looking at the rear brake squeak tsb, and my car did squeak at low speed with a light pressure to the brakes.
If i do bring it to the dealership, I am afraid that when they take the car for a test drive, they will not hear the squeak.
Old 11-02-2007, 12:26 AM   #13 (permalink)
wonger's Avatar
View wonger's Photo Gallery
if techs not an ass. and wants the .7 time.. than he will do it.. even if he hears it or not.. its better to go when the dealer is slow hehe.. i know i would do it.. if it was slow
88 4Runner
wonger is offline   Reply With Quote
Brake Noise FirstCamry 5th & 6th Generation (2002-2006 & 2007-2011) 7 10-30-2007 02:40 PM
Adjusting E Brake ForTech 2nd Generation (2005+) 15 09-23-2007 12:36 PM
AE92 & AE82 Brake upgrade options.... freakinbox Older Generations (1969-1987) 8 09-13-2007 03:41 AM
07 V6 brakes? lalojamesliz 5th & 6th Generation (2002-2006 & 2007-2011) 31 06-18-2007 08:56 AM
2007 Camry In-depth Consumer Review phenderson Camry Hybrid 0 08-09-2006 09:15 PM
