window problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-01-2007, 10:57 PM   #1 (permalink)
knowledge brings power
View felya589's Photo Gallery
window problems
my first probelm is taht when im opening my fornt two windows, they jerk down adn theres a loud thump like its stuck and it got jerked out and my second problem is that on the front passenger window i can hear air coming in. Any suggestions on why this is happening adn how to fix it?
2002 Camry LE I4
TRD Front Strut Bar/Rear Sway Bar, OEM Spoiler, Tein H-tech Springs, KYB-GR2 Shocks and Struts, Tints 15% on back windows(had to take off the front because of tickets), K&N Short Ram Intake,Pioneer DEH3900MP Headunit,agencypower light weight crank pulley
Future: Rims
felya589 is offline   Reply With Quote
Old 11-01-2007, 11:13 PM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
The leak is probably a bad weatherstrip or window run. You will have to find exactly where the air is leaking and repair or replace that specific area.
The window that's stuck could have a faulty regulator or track/guide. You will have to go into the door and find the problem.
2006 Camry LE Special Edition
Old 11-01-2007, 11:15 PM   #3 (permalink)
the leak is the top right cornor of the window, i was also told that the alignment might be off
2002 Camry LE I4
Future: Rims
Old 11-01-2007, 11:17 PM   #4 (permalink)
TRD VVTi's Avatar
It's possible but very unlikely. Is it? You should be able to see if that's the case when you roll the window up. If it's not out of adjustment you will need a new run channel.
Old 11-01-2007, 11:24 PM   #5 (permalink)
well i was told by the guy who did my tints that as the window goes up it shifts
2002 Camry LE I4
Future: Rims
Old 11-01-2007, 11:41 PM   #6 (permalink)
TRD VVTi's Avatar
Maybe it does.
Does it? Look and see. It doesn't matter if someone says that and it's not true. It only matters if it's true. Slowly roll the window up and watch to see if it shifts...
Old 11-01-2007, 11:45 PM   #7 (permalink)
its 12:45am and i just checked, yeah it shifts
2002 Camry LE I4
Future: Rims
Old 11-01-2007, 11:50 PM   #8 (permalink)
TRD VVTi's Avatar
It's 11:47 PM and yeah, I'm typing.
It's also possible that the window could be dragging on the run channel. Does it shift back into position when you roll it down? Does it go into position when it reaches to top of the channel?
A better description of what exactly happens and at what points would help greatly.
It's 11:50 PM and I'm done for the night...
Old 11-01-2007, 11:53 PM   #9 (permalink)
it shifts what looks like back into place when i put it up all the way
2002 Camry LE I4
Future: Rims
Old 11-02-2007, 10:01 AM   #10 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
Sounds like the tracks are worn. I'd remove the interior panel, loosen the glass from the lowering mechanism, and slide it up and down slowly by hand so I could feel at what point it goes in and out of proper alignment. You should be able to work it up and down until you find an exact spot and then take a look at that track and see why it is behaving the way it is.
gdanaher is offline   Reply With Quote
Old 11-02-2007, 10:31 AM   #11 (permalink)
TRD VVTi's Avatar
It really could be anything from a window track problem, a regulator problem, a run channel problem, or an adjustment problem.
Old 11-02-2007, 12:28 PM   #12 (permalink)
johnnyzee's Avatar
View johnnyzee's Photo Gallery
yes this is TRUE, same problem on mine, window rolls up then shifts towards the front of the car slightly (few mm's). Had to get it retinted twice. It's a toyota thing apparently.
I even get the odd wind noise here and there, easy fix... just quickly tap the power window button down and the window will ever so slightly dislodge from its shifted position into a more sealed position. works every time and happens to me very rarely, once a month or so.
johnnyzee is offline   Reply With Quote
Old 11-02-2007, 11:11 PM   #13 (permalink)
TRD VVTi's Avatar
Running the tint on the window into the run channel is a no-no. It can cause the window to bind slightly, which can cause the condition described.
01 camry le driver side window problems... flyboi 3rd & 4th Generation (1992–1996 & 1997–2001) 1 06-30-2007 08:45 PM
rear window problems pucklekum 89-95 Toyota Pickup/Hilux 1 06-06-2006 01:17 PM
rear window problems pucklekum Introduce Yourself Here 0 06-06-2006 04:15 AM
Gen2 window problems.....already searched.. storydude 1st & 2nd Generation (1983–1986 & 1987-1991) 8 08-28-2003 01:49 PM
window problems need help jiggaboo Camry & Solara Lounge 5 08-26-2003 03:38 PM
