2007 Speaker install questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-04-2007, 06:18 PM   #1 (permalink)
touringcamry's Avatar
Gameroom cash: $510625
Gen6 2007 Speaker install questions
I got a set of Arc 6000 components and put them in the door with the woofer and tweeter next to each other. I then tried to disconnect the stock tweeter that's in the dash, but upon doing so, I found that it would cut signal to the doors.
Anyone who's replaced the stock speakers, did you just cut the wires and crimp them?
This is the wiring harness that connects to the left side tweeter.
Here's what the stock dash speaker looks like for anyone who's curious
2007 Camry 2.4L 5M
Old 11-04-2007, 07:00 PM   #2 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $393350
View Luna2's Photo Gallery
Install jumper(s) Purple to Purple & Pink to Pink.... they are bridged in the mating connector in the speaker....
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is offline   Reply With Quote
Old 11-04-2007, 07:09 PM   #3 (permalink)
Twin & (1 of 8)
Luna2's Avatar
You could also just cut one leg of the cap or the red or black wire to "open" the tweeter circuit, then reconnect the plug. The tweeter will be dead, but could be reconnected later, if needed. [Cover and secure the loose ends, to prevent an intermittent audio output problem, or rattles.]
MFG 02/25/2010
Stock, Shucks!
Old 11-04-2007, 08:55 PM   #4 (permalink)
yeuemhoai's Avatar
View yeuemhoai's Photo Gallery
If you have multimeter, you can measure the 2 pins on the left in the last pix to see if they are shorted (0 ohm) then do the same to the right. If they do, you can remove the the harness from the tweeter and put jumpers between left 2 pins. Do the same for the right pair.
That' what I guess the tweeter is in parallel to door speaker.
'07CamryLEV6|Whyt|V4|EF|Mudguards|All-weatherMats|LipSpoiler|Tinted|3MProtector|LEDInterior|SERims|Xtreme5000K| LEDTaillights...
'01LexusRX300|PearlWhyt...
'96CamryLEV6CollectorEd.|PearlWhyt...
yeuemhoai is offline   Reply With Quote
2007 Tacoma Questions from a Noob Volrus 2nd Generation (2005+) 38 02-24-2007 12:12 PM
Few questions after DR coilover install dwntwnall4u 2nd Generation (2005+) 2 01-07-2007 05:52 PM
Nav Unit - Pionner or Eclipse - & Install Questions leepark 5th & 6th Generation (2002-2006 & 2007-2011) 5 11-04-2006 10:20 PM
Attn: FLOWERMAN, heres your 2002 speaker install... Zeek321 5th & 6th Generation (2002-2006 & 2007-2011) 8 08-30-2002 10:59 PM
