To make the process less messy, remove the drain plug and drain the oil first before tackling the oil filter. Do not use any tool to remove the O-ring, you may damage the cap. Don't forget to apply a thin coat of engine oil to the O-ring.
Torque specs
Torque: 25 N*m (255 kgf*cm, 18 ft.*lbf) Oil Filter Cap Torque: 13 N*m (127 kgf*cm, 10 ft.*lbf) Oil filter drain plug to the filter cap Torque: 40 N*m (408 kgf*cm, 30 ft.*lbf) Oil drain plug with a new gasket
Torque specs
I don't think draining the oil would have any impact on the oil filter since the oil, when it is drained, drains out of the oil pan, which doesn't share the same "area" with the filter. The did find out that it is possible to activate the release valve inside the filter to drain the filter out, but that's not absolutely neccessary. As for the O-ring removal, the new filter comes with new O rings (you shouldn't reuse the old ones) and I did infact apply engine oil liberally to the new O rings
I will probably re-do the video next time and update it by adding the torque specs.
... As for the O-ring removal, the new filter comes with new O rings (you shouldn't reuse the old ones) and I did infact apply engine oil liberally to the new O rings ....
I agree with you, O-rings should be replaced everytime you change your oil. But I saw you in the video, using a tool instead of your hands to remove the O-ring. But if you are careful, I guess you won't damage the filter housing.
For my last oil change, I used Amsoil 100% synthetic 5W-30 (ASL). I don't think series 3000 5W-30(HDD) is recommended for use in Toyota's engines (ILSAC GF-4, 3 ..). For your next oil change, you might need to switch to 5W-30 ASL to avoid any warranty problems. I might be wrong, just contact Amsoil Customer service and ask them if it is ok to use 5W-30(HDD) for your Camry.
I have changed the oil a week ago. I drain the oil first. Then when the oil is still draing I replaced the filter. The oil pan can cover both at the same time. But you need to be very careful positioning the pan.
2007 Camry XLE V6, metallic silver, Navigation, smart key, heated leather seats, VSC, Tint 35% back 50% front, K&N.
2001 Camry LE V6, sold
I used the hose peice/filter canister adaptor and just ran the hose to the drain pan, worked great, probably the cleanest oil change for me sofar and I've had some pretty ugly ones, like that time I forgot to put the plug back in and realized on the last quart (not on my car or driveway for that matter LOL)
