Steering wheel off center... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-05-2007, 10:58 PM   #1 (permalink)
Baby's got a new skirt
ebumdude's Avatar
Gameroom cash: $180662
iTrader Score: 7 reviews
View ebumdude's Photo Gallery
Gen6 Steering wheel off center...
It took me a while to search for that guy that posted a month ago or so about his stearing wheel being off center to the right about 5 or 10 degrees when he drives straight.
Well, I don't know if anyone was able to help him, I was out of town. But when I got back I noticed mine was doing the same thing. I took it in to the dealer and found that the "toe" adjustments for the front right tire were out of wack.
They fixed it and all is better. So if anyone else has the same issues, hope this helps.
ebumdude is offline   Reply With Quote
Old 11-05-2007, 11:45 PM   #2 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
It's just a bit of alignment issues, some people get it when they hit curbs or it just wasn't aligned correctly from the beginning.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 11-06-2007, 12:14 AM   #3 (permalink)
importcars's Avatar
View importcars's Photo Gallery
yep , what he said. lol. or anytime you get bigger rims, u usually have to align..
importcars is offline   Reply With Quote
Old 11-06-2007, 12:16 AM   #4 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Wheel size doesn't affect alignment.
2006 Camry LE Special Edition
Old 11-06-2007, 12:20 AM   #5 (permalink)
importcars's Avatar
well unfortunately i was told that on these fourms
what could i be mistaken that part of information from?
there is something that falls hand in hand of getting a much larger rim..
such as 14's to 18's
Old 11-06-2007, 12:35 AM   #6 (permalink)
bigloubumpin's Avatar
Gameroom cash: $150645
View bigloubumpin's Photo Gallery
Mine was off,dealer took care of it-FREE!
bigloubumpin is offline   Reply With Quote
Old 11-06-2007, 11:07 AM   #7 (permalink)
TRD VVTi's Avatar
I believe that someone did pass that incorrect information onto you in this forum. That's common. Even some of the ASE Master Tech's post bad information at times. Be very careful who you believe.
I have no idea where the mistake was made or where part of the information was drawn from.
Old 11-06-2007, 11:38 AM   #8 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $318510
View gdanaher's Photo Gallery
On the subject of new rims casuing the need for an alignment, please exercise a little common sense and logic. What you are really aligning is the hub or spindle. The wheel just happens to be bolted on it and offers a bigger target. If the wheel is not bent and appears to spin true, it is parallel to the brake rotor, and it can't possibly change the alignment regardless of the width or diameter. Changing the springs or something else is another story but not part of this one.
gdanaher is offline   Reply With Quote
Old 11-06-2007, 11:56 AM   #9 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $172825
View JSM1284's Photo Gallery
Aftermarket wheel sizes can in fact change alignment. Not neccessarily rim diameter, but offset. If you change to anything from the stock offset, it will change your camber angles.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 11-06-2007, 12:58 PM   #10 (permalink)
TRD VVTi's Avatar
Offset doesn't affect any angle by itself. The affect of offset on the suspension or steering could affect alignment angles. The change in offset would have to be quite extreme though. In a case where enough of a change was made to actually affect the alignment, I doubt that the car would even be driveable.
So for the basic street driven vehicle, alignment would not be needed due to changing wheels.
Old 11-06-2007, 01:36 PM   #11 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Correct again.
Offset changes will only affect scrub radius.
There is a lot of hearsay, old wives tales, etc. on these forums.
Old 11-06-2007, 01:37 PM   #12 (permalink)
importcars's Avatar
Thumbs up
well thanks for clearing that up for me
Old 11-06-2007, 11:44 PM   #13 (permalink)
View ciscoboy's Photo Gallery
You may have seen my posting but I've got mine fixed finally. My idiot dealer used 5th gen Camry alignment specs to do alignment on my 6th gen Camry which did not do a thing to remedy the problem. I brought the car back twice for the same problem after the first incorrect alignment and they kept telling me everything was within spec and that it was "normal" for the steering wheel to be pointing at 11 O'Clock position to go stright due to road crown. I finally discovered they used the wrong specs to do alignment on my car and had to point that out to my dumb-ass dealer. After using the correct specs to alignment on my car, it now tracks straight even on crowned roads.
Here are the links to my before and after alignment result sheets.
The first one clearly says for 02-06 Camry.
http://s229.photobucket.com/albums/e...EAlignment.jpg
http://i229.photobucket.com/albums/e..._Alignment.jpg
ciscoboy is offline   Reply With Quote
Old 11-07-2007, 04:16 AM   #14 (permalink)
ebumdude's Avatar
Right on man...
your pics didnt work, but at least you got it fixed like I did. As soon as I noticed mine, I was like "ahh sh*t, I remember reading about this in a thread on TN"....
Old 11-07-2007, 08:59 AM   #15 (permalink)
Right on man...
The links have been corrected. Sorry.
Anyone see this? Steering wheel came off! Nicky9 2nd Generation (2005+) 14 02-26-2007 12:38 PM
steering wheel whiteae92 Archived Corolla threads 7 05-06-2006 11:16 PM
leather steering wheel rewrap? ea8631 Celica Forum 2 01-12-2005 10:21 PM
How to change steering wheel on a Gen2? Gen2RacerX 1st & 2nd Generation (1983–1986 & 1987-1991) 7 09-08-2003 03:31 PM
Loose Steering wheel 92LudeSR Hardcore Tech and Competition 2 06-19-2003 04:59 AM
