Relay Harness? HIDs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-08-2007, 05:02 PM   #1 (permalink)
View simple0ne1's Photo Gallery
Gen6 Relay Harness? HIDs
I know everyone says its best to use a relay harness with an hid kit.
The dealer I got my Apexcone HID Race Kit says that the startup draw is very low and i do not need a relay harness. Input from anyone? Thanks!
"Want even more output? Step up to Apexcone Race, featuring 55 watt HID ballasts offering up to 40% more brightness than 35 watt HID kits! Special circuitry provides low startup current draw (6 amps) negating the need for additional relay harnesses in most fitments. Due to its intense light output, Apexcone Race is not recommended for non-projector headlights or foglights."
-From www.understeer.com
Additional Product Info: http://forums.bimmerforums.com/forum...d.php?t=800714
simple0ne1 is offline   Reply With Quote
Old 11-08-2007, 05:41 PM   #2 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
You wanna trust them? Have them send you a written guarantee that if something fails on your car due to the lack of a relay harness that they will pay for all repairs.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 11-08-2007, 06:27 PM   #3 (permalink)
Gameroom cash: $283730
View LE05's Photo Gallery
i seriously doubt their claims on 6 amp startup draws... not to mention they are 55w kits. as for the relay harness, better safe than sorry! its not like it takes all that much more time to install a relay harness...
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 11-08-2007, 06:35 PM   #4 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
Please just do what I did and others before you. Go to HIDPlanet.com and learn about HID as much as you can. It will all make sense after you take HID 101 course.
Old 11-08-2007, 07:05 PM   #5 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
Well some say it's not required, but from my experiences I'd say otherwise.
After retrofitting my TSX projectors, every once in a while, the HIDs turn on with only one light bulb on, that happened in about 1 out of every 5 times I used the HIDs.
Then I purchased a wiring harness.
Problem solved.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 11-08-2007, 09:56 PM   #6 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
I've used both, a cheap eBay kit with no relay harness and a more expensive one from XenonDepot with a relay harness. When I used the one without, the majority of the time only one of the bulbs would actually come on, and I would have to turn them off and back on quickly in order to do so. I dont know if that was just a faulty ballast, or because it was attempting to draw too much power.
Either way, just install it right the first time.
geoff5093 is offline   Reply With Quote
Old 11-09-2007, 12:51 AM   #7 (permalink)
Thanks guys! I'll get it soon as I can, you guys are great
Old 11-09-2007, 01:18 AM   #8 (permalink)
Webb26's Avatar
View Webb26's Photo Gallery
Make yourself one...tis much cleaner and more OEM'ish. I would recommend using a relay harness...if you are the least bit worried or unsure then just use it.
Webb26 is offline   Reply With Quote
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
yet another foglight question cddallara 2nd Generation (2005+) 21 08-01-2008 09:11 PM
HID question CamNub 5th & 6th Generation (2002-2006 & 2007-2011) 13 09-05-2007 06:50 PM
'Power Harness' Strat42586 MR2 Forum 0 05-27-2005 09:27 PM
HID Relay Harness PtBaller General Discussion 1 10-10-2004 06:20 PM
