Define what you mean by difficulty. If you are putting it in park and then setting the emergency brake the car is probably rolling back an inch and putting pressure on the transmission's internal mechanism which sets and holds the gears from moving. Try setting the emergency brake first, let off the stopping brake and then put it in park.
setting you parking break is a good habit overall, whether on a hill or even a flat surface. When your car rolls after you put it in park ( provided you haven't used your parking break) you are putting unnecessary strain on the car.
__________________ SE I4: 20% Tint All Around, H.I.D., K&N Air Filter, Blacked Out Headlights. Future Mods: Blacked Out Tails, Hoen Fogs, Lowering Springs, Exhaust, LED Side Markers
It's good to do, but i've found that in my case, I almost always forget about the brake until I start to drive, so my brake would be worn out in no time
My parents never used theirs, so neither did I, until I learned how important it can be. What I did was stick a posit on my steering wheel that said 'BRAKE'...and after about a week, it became second nature. I also push it all the way down, so even when in drive, it wont go! I had my dad and cousin thinkin my new car was broken.lol.
ive gotten accustomed to using mine....i dont like how the car "Kicks Back"when u just leave it in P, so i use the parking brake and i dont feel the car "kick back"
it was so used to it when driving the gen5 with the handle when i switched to the gen6 i always forgot about it because it was the pedal type. When even i drive the gen5 now i forget to disengage the ebrake until im down the block.
You couldn't do that with a Gen 6, damn thing starts beeping at me if I try to drive with the parking brake engaged. If I so much as touch that handle when driving, it starts beeping at me too.
Is there a difference in setting the parking brake first then engaging to "P"? I always engage to "P" first and pressing the parking brake.
Yes there is, when you engage park the car will still roll back a ways. The best thing to do is set the parking brake, let the car roll a tad, then engage park.
OK thanks, will try that. Will it eliminate the difficulty of disengage from Parking position to drive position later? My car posh is on the slope. Every morning I have difficulty of pulling the gear lever from "P" and sometimes I hear loud sound from the gear box when I pull it down. However, when the engine hot or rather have been draven before then this will not happen. Will I damage my gear box if I continue to do this?
It might wear some parts out a bit faster, but I think it's minimal wear at most.
Personally, I set the parking brake first and let the car settle. I get it so that the car doesn't move at all most of the time. Then I put the car in gear so that way I use the parking brake to hold the car and the transmission and engine as a backup. I can generally tell if the car has moved at all just by the resistance taking it out of gear to neutral to start.
2007 Camry 2.4L 5M
