Smokey Mornings - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-09-2007, 10:40 AM   #1 (permalink)
I'm a NOOB at <3
mega87's Avatar
View mega87's Photo Gallery
Gen5 Smokey Mornings
I have been experiencing this wierd start up every morning, for the past 4 or 5 months. Everytime I start my 2002 camry (2A-ZFE), a puff of white smoke comes out the muffler at a cold start, but once the car starts running it's fine. I have been checking my oil level to make sure if it was any leaks but apparently my oil level pretty much stays the same. I just changed my oil roughly about 2000 miles ago I used 10-W40. I was thinking about putting some Seafoam in the oil and see what happens. Any suggestions what it could be? Thanks
2002 Camry LE
mega87 is offline   Reply With Quote
Old 11-09-2007, 10:49 AM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Gen5
I'm guessing that it's just condensation. By the way, it's a 2AZ-FE.
Using 10W40 is stupid, that same thing with adding SeaFoam to your oil. You should be using 5W30.
2006 Camry LE Special Edition
Old 11-09-2007, 10:58 AM   #3 (permalink)
I'm a NOOB at <3
mega87's Avatar
Whoops I know it's typo 2AZ-FE....but from the post I keep on reading about Seafoam being so good. I thought I'd give it a shot. Why would you say it's bad to add Seafoam to your oil? I've heard nothing but good things.
2002 Camry LE
Old 11-09-2007, 11:00 AM   #4 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
It's a preference thing. Some people add it to oil, others dont. It is safe to do though.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 11-09-2007, 11:08 AM   #5 (permalink)
TRD VVTi's Avatar
It's a very strong solvent/detergent in a liquid form. I don't see the advantage to adding it to the engine oil. Oil already has detergent additives in it. As long as you change your oil and use the CORRECT oil (which you don't), SeaFoam won't be that beneficial.
SeaFoam works great for cleaning fuel systems and air intakes.
Quality oils work great for lubrication and cleaning of the engine.
Old 11-09-2007, 12:08 PM   #6 (permalink)
Forgive meee.
liquidi3ladz's Avatar
View liquidi3ladz's Photo Gallery
I used seafoam on my oil right before I made the switch to mobil1. :]
2002 Camry LE I4
liquidi3ladz is offline   Reply With Quote
Old 11-09-2007, 12:50 PM   #7 (permalink)
The Connoisseur
CharmCityES's Avatar
its most likely condensation....i know BRAND NEW toyotas at the dealer i work at all put out puffs of white smoke when you start them up because theyve been sitting....esp if u live in an area where theres a drastic change in temp between day and night
and make sure you use 5W30 oil only....its what toyota reccomends for your camry
The "Executive Sedan"
Old 11-09-2007, 12:52 PM   #8 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
That the best way to use Seafoam is you should do an oil and oil filter change right afterward.
Old 11-11-2007, 04:39 PM   #9 (permalink)
I'm a NOOB at <3
mega87's Avatar
Actually yeah I thought it was condensation but when I was Seafoaming my car yesturday I noticed behind my valve cover right next to the intake manifold, I see and oil leak(s). I think thats the source of. I'm going to take it to my mechanic and have it let him take a look at it.
2002 Camry LE
Old 11-11-2007, 07:31 PM   #10 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
An oil leak at the valve cover isn't going to result in smoke out the tail pipe. You didn't say how many miles you had but suggested this had been happening throughout the summer. If the engine is high mileage then the smoke out the tailpipe is more likely oil getting past the valve stem seals. This isn't a huge deal unless they fail entirely which is rare.
gdanaher is offline   Reply With Quote
Old 11-11-2007, 07:46 PM   #11 (permalink)
I'm a NOOB at <3
mega87's Avatar
Hmmm yeah I think your right. I have 85,000 miles on the Camry now, and she drives smooth no hicups or anything. I keep up with the oil change and check all the hoses regularly. Though that puff of smoke keeps me worried casue i always think that I might be developing some slug in the enigne. But I might be wrong.
2002 Camry LE
Old 11-12-2007, 01:53 AM   #12 (permalink)
TRD VVTi's Avatar
Hell, just remove the oil cap and look inside. If there's sludge you'll see it. If you service your car regularly with the approved oil, you shouldn't have anything to worry about.
Old 11-12-2007, 01:59 AM   #13 (permalink)
Archosman's Avatar
View Archosman's Photo Gallery
Does synthetic oil make that much of a difference? I'm at 45,000.
Archosman is offline   Reply With Quote
Old 11-12-2007, 02:01 AM   #14 (permalink)
TRD VVTi's Avatar
You're asking for an arguement with that question.
That being said, I use synthetic oil and have never had and engine problem since switching...
I use Mobil 1 and change at factory recommended intervals.
Old 11-12-2007, 04:57 PM   #15 (permalink)
View CMSE07's Photo Gallery
Ageed, perfect question for an argument. I'll just add that using synthetic oil is great prevention against engine problems, It will not repair any existing problems or reverse normal wear, hints best time to switch to synthetic is right after the engine's initial break-in
CMSE07 is offline   Reply With Quote
99 Camry won't start humid mornings gilmort Camry & Solara Lounge 1 07-22-2006 07:47 PM
Noise Front Passenger in the mornings toamitanand Solara 8 01-15-2006 05:59 PM
Corolla - Noise on cold mornings kewl_chap Archived Corolla threads 1 12-01-2004 02:52 PM
20v ae86 won't run right on damp mornings, help!!!! evo_n8 Archived Corolla threads 2 07-07-2004 05:39 PM
20v ae86 won't run right on damp mornings, help!!! evo_n8 Hardcore Tech and Competition 4 07-06-2004 09:20 AM
