Vibration after new rims/tires - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2007, 12:33 PM   #1 (permalink)
MCeatalot's Avatar
iTrader Score: 7 reviews
View MCeatalot's Photo Gallery
Gen6 Vibration after new rims/tires
I know this topic has been covered before, but I'm wondering for those people who had this problem after installing new tires and rims, what did you have to do to correct the vibration? I've been to the shop 2 times now, and so far they've re-balanced it and changed the plastic hub centric rings with metal ones.
Forgot to say that it didn't fix the problem. Still have vibration at 65+ mph.
I replaced my 4-cyl with another 4-cyl, equally powered, but faster ride...
http://i234.photobucket.com/albums/e...e/P9231851.jpg
MCeatalot is offline   Reply With Quote
Old 11-11-2007, 01:48 PM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
The desription of the problem sounds like excessive runout of the wheels, tires, or out of balance. The only way to know it to actually check it.
2006 Camry LE Special Edition
Old 11-11-2007, 01:52 PM   #3 (permalink)
View krouchchocolate's Photo Gallery
how do you know if it is out of balance or not? Is this something you have to bring to the store for them to check it out?
krouchchocolate is offline   Reply With Quote
Old 11-11-2007, 01:55 PM   #4 (permalink)
TRD VVTi's Avatar
Yes. The hard part is finding a shop with a technician that really knows what he's doing. It's even harder if they aren't the ones that installed the wheels and tires, as there isn't really any money in figuring out someone else's tire/wheel issue.
Old 11-11-2007, 02:19 PM   #5 (permalink)
Newbie
deezeejoey's Avatar
View deezeejoey's Photo Gallery
sounds like out of balanced tires.
deezeejoey is offline   Reply With Quote
Old 11-11-2007, 02:54 PM   #6 (permalink)
2007 RED Camry XLE Owner
Old Dood's Avatar
View Old Dood's Photo Gallery
I have that problem from time to time with my after market rims.
The Service Manager takes my Camry over to the Lexus shop and uses their newer machine....seems to work pretty good.
"We can't solve problems by using the same kind of thinking we used when we created them." Albert Einstein
Old Dood is offline   Reply With Quote
Old 11-11-2007, 04:04 PM   #7 (permalink)
it pays to floss
Trojan's Avatar
View Trojan's Photo Gallery
I had the vibration at the same exact speeds. Was at the shop for like 4 days straight and they tried nearly everything. But it turned out it was some bad tires. They installed a new set of tires and the vibration was gone.
07 Camry LE
http://www.cardomain.com/ride/2688832
08 WRX Sport Wagon Premium Edition
http://www.cardomain.com/ride/392672...sport-wagon-4d
Trojan is offline   Reply With Quote
Old 11-11-2007, 08:08 PM   #8 (permalink)
View V6 LVR's Photo Gallery
Try to find a shop that has the Hunter Road Force balancing machine. Then ask for the tech who is trained on that machine. Most likely you will have the tires balanced properly. For more info on the Road Force go to TireRack.com
V6 LVR is offline   Reply With Quote
Old 11-11-2007, 08:31 PM   #9 (permalink)
MCeatalot's Avatar
Thanks for the reply guys. The techs over at America's Tire Co. were really helpful since that's where I bought the set. They recommended me to do a road force balancing, but I'd have to go to another America's tire store, which is about half-hour drive. My other option is to get a different set of tires. I might just go with the latter and put on other tires. I currently have Kumho Ecsta SPT 225/45/18s, which got so-so reviews.
Old 11-11-2007, 11:12 PM   #10 (permalink)
Gameroom cash: $103555
View laphan's Photo Gallery
I have 225/45/R18 with bridgestone RE960AS tires and Konig Further wheels.
At first I have bad vibrations (Discount tires) and they finally did the road force balance after 3 trips of unresolved vibrations issue.
It cured the vibartions but I still has vibrations at 85+ mph.
They decided to put some hub rings and that really cured the vibrations issue.
'08 Toyota Camry Hybrid
'00 Grand Marquis LS (winter beater)
'04 Porsche Boxster
Gone: '06 Solara
laphan is offline   Reply With Quote
Old 11-12-2007, 12:06 AM   #11 (permalink)
MCeatalot's Avatar
How long did the road force balance take to finish? I don't want to spend an extra 100 bucks just to get another set of tires, so I might just do that since they're covering charges.
Vibration Findog Introduce Yourself Here 0 11-07-2007 12:50 PM
Another Vibration Thread cgrivois 1st Generation (1995.5–2004) 13 08-30-2007 10:06 AM
Vibration issue on 1994 Pri/Cor rangejeepjeep Archived Corolla threads 4 08-07-2007 02:39 AM
new owner problems dack41 2nd Generation (2005+) 17 10-04-2006 10:53 PM
Engine misfire - clutch vibration - some what rough idle? blueapple Camry & Solara Lounge 0 04-08-2006 03:48 PM
