acceleration kink? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2007, 03:16 PM   #1 (permalink)
2003 Camry Speedster
View IPDaily's Photo Gallery
Gen5 acceleration kink?
okay so maybe i'm being a little critical, but lately i've noticed a small annoyance with acceleration... basically it goes like this... i'll press the accelerator a certain amount, say 20% or so to accelerate from a dead stop... the car will accelerate, all is well, it'll shift from 1st to 2nd at whatever speed, but then here is where the issue lies... after the shift occurs, it seems as if the car loses power and requires more acceleration... in other words, in order to keep accelerating after the shift, i'll have to press the accelerator in more in order to maintain the acceleration, like if i have it pressed in 20% from the stop, after the shift i'll have to press it in 30% or else it will stop accelerating after it shifts or so it seems... the same thing happens after shifting from 2nd to 3rd... it's almost as if i lift my foot off of the accelerator after shifting, as the car basically just coasts, and the whole time i have the accelerator depressed... has anyone else experienced this? what could be causing it... maybe the throttle body is just dirty, or could it be a faulty TPS? all input appreciated...
2003 Toyota Camry XLE V6, 18x7.5" ASA rims +40mm offset, Bridgestone Potenza Tires 225/45/18, H&R Sport Springs, TRD Exhaust/Strut Tower Brace/Rear Sway Bar, Wood Steering Wheel, 20% LLumar Tint
2007 Toyota Camry SE V6, Sport Leather
IPDaily is offline   Reply With Quote
Old 11-11-2007, 03:33 PM   #2 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1076258
iTrader Score: 7 reviews
i expearianced something like this lastnight and the last few starts that it was cold outside (engine warm or not)...but it did disappear after i drove for awhile..
2002 Camry SE V6 "Snow White"
19x8 +48 Offset TRD rims are Foe Sale. PM For Inquiries
Old 11-11-2007, 04:19 PM   #3 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
It's unlikely that there is a TPS problem or anything along those lines because the MIL would illuminate due to a mafunction code.
If that was happening to me, I would remove the negative battery cable for a couple minutes to see if resetting the ECU helps.
2006 Camry LE Special Edition
Old 11-11-2007, 06:13 PM   #4 (permalink)
View Aceventura9586's Photo Gallery
+1 on that. Don't forget that after you disconnect it to reset it, then make sure you drive it around for a while so that it relearns the process.
Aceventura9586 is offline   Reply With Quote
Old 11-11-2007, 08:45 PM   #5 (permalink)
Gen5
maybe a stupid question, but how do i disconnect the battery?
Old 11-11-2007, 09:05 PM   #6 (permalink)
find the right sized wrench for the negative terminal bolt..and undo it, then pop the cable off. just becareful not to touch the wrench to any metal surfaces, or you'll feel a bigass shock..which could kill you.
Old 11-11-2007, 11:48 PM   #7 (permalink)
bigloubumpin's Avatar
Gameroom cash: $151645
View bigloubumpin's Photo Gallery
^^^10mm socket w/rachet should due
bigloubumpin is offline   Reply With Quote
Old 11-12-2007, 01:38 AM   #8 (permalink)
TRD VVTi's Avatar
Yep, just use a 10mm wrench/socket and ratchet to disconnect the negative battery cable. Smoke a cigarette (or masturbate), then reconnect the cable to the battery.
Old 11-12-2007, 03:40 PM   #9 (permalink)
View kennb's Photo Gallery
I had a similar problem before I got the ECU flashed with the august update, now it doesn't dog down as much when it shifts into 2nd as it use to.
kennb is offline   Reply With Quote
Timing belt & acceleration omegarex 3rd & 4th Generation (1992–1996 & 1997–2001) 20 12-06-2008 12:12 AM
Consumer Reports: M35 vs. 535i vs. E350 vs. S80, E320 vs. GS450H, S550 vs. LS460 IFCAR General Discussion 1 09-29-2007 03:07 AM
Acceleration Weirdness.... 01FIERA Archived Corolla threads 12 05-12-2006 11:26 PM
Weird acceleration problem dstlaurent Camry & Solara Lounge 5 06-28-2005 07:48 AM
