Originally Posted by 1996camry
i have done a lot maintenance to my car..96 toyo camry le 4 cylinder 5sfe engine.
new spark plugs
new spark plug wires and button and distrubutor
new pcv value
new engine mounts (front and rear)
flush antifreeze (new)
flush transmission (new) and differential flush
new fuel filter
cleaned bottle throttle(took apart)
spread little bottle throttle can in small hold IAC
have put fuel injection in gas tank but didn't help
rough idle ONLY occure at dead stop.
have any ideas what cause?
you think dealer have a machine do test to see what is cause rough idle?
any ideal?
What is a "bottle throttle"?
SeaFoam usually won't fix anything. It's preventative maintenance.
The best way to fix your miss is find out why it's missing.
Do all the cylinders have good and equal spark?
Is it running lean (lean missfire)?
How much vacuum do you have?
How much compression?
Is it really a rough idle?
Are you sure that it's not normal?
You list all sorts of things that you've done, but not one of them has anything to do with diagnosing a rough idle or a miss.
If your car is a '96, why are you in the Camry section for '02 and up?
