Originally Posted by evokitan
I have a 02 Camry XLE V6. I dont have heat going to the feet area. The defrost and face works just no heat going to the feet. any suggestions..?
please help
As stated above, Your best bet for a resolution is the online service manual. If you can give a bit more information maybe we can narrow down the problem.
Since you have the XLE, I assume that you have the Automatic Climate Control. What do you mean by no heat? Is it just no heat or no air at all, can you get cold air to the "feet area"? When you switch from "face" to "feet", do you still hear the air blower or does the entire system shut off? Are you getting heat to the passenger "feet" area? Did you recently get any work done that would have required removal of any panels?
