painting 2az-fe plastic engine cover - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2007, 04:23 PM   #1 (permalink)
The Connoisseur
CharmCityES's Avatar
i decided that i want to paint the plastic engine cover on my 2az silver instead of the standard black....i was considering this today, and since im sure someone here has painted the engine cover, i was wondering a few things that you guys might be able to help me with
1. what type of paint would i need?
2. would i need to sand/primer before i paint?
any help is appreciated as usual!
The "Executive Sedan"
Old 11-18-2007, 04:37 PM   #2 (permalink)
Gameroom cash: $283730
View LE05's Photo Gallery
i haven't painted the engine cover myself, but i have painted plastic before:
1. i would use paint that can withstand the engine heat, probably engine enamel paint or something similar
2. if you want the paint to last, i would definitely sand and primer before painting
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 11-18-2007, 05:24 PM   #3 (permalink)
Love my Camry
View Engineer2048's Photo Gallery
To add to LE05's post: degrease thoroughly, then dry, sand with 320-grit sandpaper, prime, then paint. Not to insult you by any means, but several thin coats of paint will give you a longer-lasting job than trying to cover in one coat. Good luck, and please post pictures of the result.
Engineer2048 is offline   Reply With Quote
Old 11-18-2007, 05:36 PM   #4 (permalink)
The Connoisseur
thanks for your help everyone....i will definitly be painting it next weekend, and i will post pictures of the finished product
Old 11-18-2007, 05:57 PM   #5 (permalink)
importcars's Avatar
View importcars's Photo Gallery
look forward gl
importcars is offline   Reply With Quote
Old 11-18-2007, 06:48 PM   #6 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
I've considered painting mine Lunar Mist to match my car for some time now.
I agree that you will need to sand it first. Primer will definetely help also.
Hurry up so I can see some pics...
2006 Camry LE Special Edition
Old 11-19-2007, 11:41 AM   #7 (permalink)
& JustAnotherCamry
View JustAnotherAsian's Photo Gallery
speaking of painting covers... has anyone clearcoated their stock cover (without paint)? i actually really like the red and silver letters on black (which happens to by my favorite color next to silver and red lol). i'm just wondering what the steps are to make the cover really glossy. so i assume...
light sand >>> clean and alcohol >>> light coats of clearcoat?
JustAnotherAsian is offline   Reply With Quote
Old 11-19-2007, 12:52 PM   #8 (permalink)
TRD VVTi's Avatar
If you sand the plastic and clearcoat it, you will be able to see where you sanded.
If you want it to look glossy but otherwise the same you should just clean it and clearcoat.
Old 11-19-2007, 01:03 PM   #9 (permalink)
Not-So-New TN User
Netforcer's Avatar
Gameroom cash: $225700
don't forget to mask off letters and areas you don't want painted
My Partial Partout!!!
Photo Album
Old 11-19-2007, 01:05 PM   #10 (permalink)
& JustAnotherCamry
^ok. that makes sense. thanks.
Pics after removal of Valve cover, and of Cleaned engine sk8ersublime 3rd & 4th Generation (1992–1996 & 1997–2001) 13 08-19-2007 04:23 PM
How to remove the valve cover. 2slo5sfe 3rd & 4th Generation (1992–1996 & 1997–2001) 3 08-09-2007 12:26 PM
Do-It-Yourself : Check Engine Light - Diagnosis bonnie* Archived Corolla threads 5 01-01-2007 02:12 AM
"A" engine info freakinbox Archived Corolla threads 29 05-10-2006 12:05 AM
What is the use of the plastic cover that goes over the engine? ponq 2nd Generation (2005+) 8 01-07-2006 08:23 AM
