USA Spec PA12-TOY Install - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2007, 09:00 PM   #1 (permalink)
View w8291's Photo Gallery
Gen5 USA Spec PA12-TOY Install
Hi, this is my first post to ToyotaNation.
I've been reading the forums for the last couple of weeks and got a lot of useful information from everyone. I just installed my iPod adapter to my Camry today and decided to make it a DIY.
I took information from lots of different posts , here are two that I can remember:
iPod
USASpec DF-TOY Install for Aux Inputs to Stock Stereo
So for my Install, I choose the USA SPEC PA-12 TOY, which has the Ipod connection (play and charge) and a set of RCA ports for additional AUX.
Installed onto my 2005 Camry LE with a 1 CD Player (Type 1), No Cassette, No NAV, No TEXT.
Materials Used:
Bottle cap Opener
10mm Bolt (Nut) Driver (Metric Nut Driver)
Installation Prep:
Remove any CDs in the CD player and turn it off (Just in case)
Disconnect Battery (You will lose your radio presets, so write them down if you forget them).
Installation:
Use the bottle cap opener to pop open the Air Conditioner Control Assembly.
(I found that the easiest spot was the bottom middle. Just popped right out at one spot)
After popping out the Air Conditioner Control Assembly, there are 2 connections that need to be removed. All the connectors have a release piece, so make sure not to just yank them out.
Once this is done, you can remove the entire piece and place it out of your way.
Use 10mm Bolt Driver to remove the 10mm bolts
(two are in the front middle and two are hidden in recessed pockets).
(Circled areas are the hidden bolts)
Pull out the CD Player/Head Unit (Vent covers and the clock come out with it.) There should be at least 4 connectors attached to it, make sure to get them all (don’t worry about mixing them up, since all the ports are different, but make sure not to let the cords drop to the bottom of the console).
(back of the CD Player)
(circled part is where the AUX connector goes).
Plug in the Aux connector (PA12-TOY) in to the 2nd to the left port (looking from behind).
Install the wires to where ever you like.
Put everything back by reversing directions.
I don’t have finish product pictures yet, night came too fast. I will post them when daylight comes.
w8291 is offline   Reply With Quote
Old 11-18-2007, 10:31 PM   #2 (permalink)
boo.hoo.hoo.
desentrix's Avatar
iTrader Score: 6 reviews
View desentrix's Photo Gallery
Good write up thus far! I might buy the materials and do it for my sister's xmas present.
2007 Magnetic Gray Camry LE V6:
Lit door sills, F/R cathode, trunk cathode, K&N SRI, IS250 chromes, LED tails/ bulb swaps, Katzkin leather
desentrix is offline   Reply With Quote
Old 11-18-2007, 10:32 PM   #3 (permalink)
bigloubumpin's Avatar
Gameroom cash: $151645
View bigloubumpin's Photo Gallery
How's it working for u?...I installed the same unit in my 08,works as designed & no cables to see.Good job on the install pictorial.
bigloubumpin is offline   Reply With Quote
Old 11-19-2007, 12:57 AM   #4 (permalink)
Working great for me. I'm very pleased with all the features. My unit doesn't have TEXT function, or else it would be just perfect. There is a tiny delay changing tracks, but overall I'm pretty pleased.
Old 11-19-2007, 11:29 AM   #5 (permalink)
Even in the 08 the location of the plug is the same,I bought mine from Crutchfield & what I like about them is they send u a 'Master Sheet' for ur specific vehicle.If u decide to use the unit in another Toyota(since u bought from them u have lifetime CS) u can call & get the MS for that vehicle.
Old 04-09-2008, 09:18 AM   #6 (permalink)
View upinya's Photo Gallery
w8291, what was the faceplate # of your radio? I'd like to know if I have a chance with my 2002 stock JBL radio to install ANY type of iPod adapter.
upinya is offline   Reply With Quote
Old 04-09-2008, 11:21 AM   #7 (permalink)
hey upinya, what do you mean by the faceplate #?
Old 04-09-2008, 12:46 PM   #8 (permalink)
Gen5
Its the number on the faceplate of the unit. Mine is the dreaded AD6806, which I think may not have all the connections in the rear of the unit as yours does, but the front of mine looks identical to yours. My wife ordered me a Peripheral iPod® Interface Kit (iSAS71 + PXDP + PXHTY3):
http://www.crutchfield.com/App/Produ...1ISAS71&tp=120
and I'm hoping I'll have luck, but I won't be sure until I open up the dash and look. Is yours a changer, or explicitly has changer controls?
Old 04-13-2008, 01:08 PM   #9 (permalink)
Mine says 16860
mine doesn't explicitly have changer controls
hope that helps
Old 02-19-2009, 11:28 PM   #10 (permalink)
ed310's Avatar
View ed310's Photo Gallery
i know it was some time ago since the last post, any instructions on how you got it to work? meaning if you are listening to the radio and you want to listen to the ipod what do you have to do?
ed310 is offline   Reply With Quote
Old 02-20-2009, 03:19 AM   #11 (permalink)
you press disc or cd. pressing it once should go into your regular cd, pressing it again will go to the ipod.
hope that helps
Old 02-20-2009, 04:13 AM   #12 (permalink)
New CA User
View jojo05Camv6xle's Photo Gallery
Great picts w8291! Very informative. Thanks.
I'd like to try this out myself but does it matter that I do have a cassette player? Just bought a 2005 camry xle and still learning a lot. Does the unit pulls it's power from the aux connection?
jojo05Camv6xle is offline   Reply With Quote
Old 02-20-2009, 02:08 PM   #13 (permalink)
gen 5.5 owner
xenergyx's Avatar
View xenergyx's Photo Gallery
^^^ most units I've seen should work with a cassette & cd player combo.
I just bought a similar unit and installed it in my '06...
Axxess AIP-TY02-ID
circuit city clearance $25.
I haven't tried the ipod function yet with my gf's ipod... I have a zune so I've just been using the aux input.
Although with mine if you crank the volume up you can hear the engine revs with a high pitched whine.
Anyone else have a similar experience?
I am thinking maybe the ipod hookup would yield a different result but I still have to try it out.
'89 gen 2 camry (stolen,recovered,sold) < '96 saturn sl (totaled) < '94 V8 thunderbird (traded) < '06 gen 5.5 camry LE I4 (financed )
visit my city
xenergyx is offline   Reply With Quote
Old 02-20-2009, 03:38 PM   #14 (permalink)
it should work as long as you have the aux/cd changer input.
the unit also draws power from the connection and the one i posted on can charge the ipod at the same time
Old 02-20-2009, 03:39 PM   #15 (permalink)
i'm pretty sure the ipod hookup will be different, but i can't say since i'm not familiar with the brand you have. an ipod connection would definately be better in sound quality etc.
turbo? yota22re Pre-88 Toyota Pickup/Hilux 3 09-21-2007 09:12 PM
CT20 turbo 1987 4runner 22R-te kylecaves 4Runner Lounge 1 09-21-2007 08:17 PM
WTB: 22re Intake Manifold jbhashem Pre-88 Toyota Pickup/Hilux 2 05-16-2006 09:24 PM
20 R Wiring Harness 86BLUETOY Pre-88 Toyota Pickup/Hilux 7 05-07-2006 10:10 PM
Question about fenders? wikkd88 Pre-88 Toyota Pickup/Hilux 8 04-22-2006 09:36 AM
