08 Camry Fog Light Help!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-20-2007, 09:37 PM   #1 (permalink)
View stevesig226's Photo Gallery
I recently bought a new 08 Camry LE. It did not come with any foglights. I wanted to replace them with factory ones or OEM style aftermarket ones. I read in other threads about the 07 LE being prewired for foglights and I am guessing it will be the same for mine. Does anyone know how to replace them and use the factory brackets and wiring??
stevesig226 is offline   Reply With Quote
Old 11-20-2007, 09:42 PM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Welcome to TN.
I recommend you do a search before you start a thread. This item is covered very frequently...and pics were even posted.
2006 Camry LE Special Edition
Old 11-20-2007, 09:43 PM   #3 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
Well I know that even though there are harnesses for the fog lights, they don't work without other components. I know there was someone else here that was looking into the parts needed, you should try searching and see if you can find it.
geoff5093 is offline   Reply With Quote
Old 11-21-2007, 01:43 AM   #4 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
All you need is the stock headlamp switch from an SE or XLE, and a relay for the fuse box. I know 'cause I was the first one that did it that way on a Gen 6 and made a thread about it. In the process though, I fawked up the clockspring in the steering wheel, so I had to buy a new one for ~$200... oh well, my bad.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Trunk tail light for 08 camry crooked? tonyizhurr 5th & 6th Generation (2002-2006 & 2007-2011) 24 11-03-2007 02:02 PM
Gen 1 - Gen 5.5 massive compile of bulb info ASG14 1st & 2nd Generation (1983–1986 & 1987-1991) 20 01-03-2006 03:51 PM
97 camry fog light bezels??? gen4cam 3rd & 4th Generation (1992–1996 & 1997–2001) 7 01-20-2005 08:39 PM
Fog light wire tapping for 03 (gen 5) camry yli5 5th & 6th Generation (2002-2006 & 2007-2011) 0 01-14-2005 11:30 PM
Fog Light Installation gen3 Camry WhiteRabbit 3rd & 4th Generation (1992–1996 & 1997–2001) 16 04-19-2004 03:31 AM
