Exact Tire Pressure? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2007, 05:14 PM   #1 (permalink)
View bxcamry89's Photo Gallery
Gen5 Exact Tire Pressure?
Whats up? I wanted to know from you guys if i should still be filling my tires on my 05 se v6 up to what is required 32psi or the max 35psi. With all the tires at 32psi i feel like i'm using more gas even though i do have a v6 and it does burn more gas than a 4cyl. Also is regular good for the se v6? I have notice a lack in power. Thanks for reading and Happy Thanksgiving.
bxcamry89 is offline   Reply With Quote
Old 11-21-2007, 05:25 PM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
What "max 35 psi" are you talking about?????????
I run mine at 35-36 psi all the time.
No adverse wear patterns, a little better gas mileage, a little firmer ride.
You double posted also...................
Old 11-21-2007, 05:45 PM   #3 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1076258
iTrader Score: 7 reviews
run them at 6lbs on the right side, will help your cornering...and 10lbs on the left! You'll be loose in the corners until your tires get some heat into them though..so take it easy...
run them at 33.5PSI
2002 Camry SE V6 "Snow White"
19x8 +48 Offset TRD rims are Foe Sale. PM For Inquiries
Old 11-21-2007, 11:25 PM   #4 (permalink)
spoon059's Avatar
View spoon059's Photo Gallery
What is the max press as noted on your tire?? That is the safest maximum pressure to use.
Manufacturers recommend a lower pressure because softer tires provide a softer ride. Personally I prefer higher tire PSI for longer tire life, better handling, and better gas mileage. It's a balancing act, comfort versus performance.
2008 Camry SE
I4 auto
Leather, JBL, VSC
spoon059 is offline   Reply With Quote
Old 11-21-2007, 11:33 PM   #5 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
I recommend that you run as high of a pressure that you're comfortable with up to the max pressure on the side of the tires.
I usually use 35-40 PSI. I use less if I take off into the mountains for some enthusiastic driving.
2006 Camry LE Special Edition
Tire Pressure sensors 05 Highlander GH05 1st Generation (2001–2007) 8 10-31-2007 08:08 PM
Tire pressure questions buckstom 2nd Generation (2007+) 6 09-02-2007 06:43 PM
tire pressure masteryota1 3rd & 4th Generation (1992–1996 & 1997–2001) 7 08-26-2007 06:48 PM
Odd tire pressure? newenglander 2nd Generation (2005+) 1 08-19-2007 08:28 PM
ABS, Brake and Tire pressure warning lights on!!!! DarkArcanine Archived Corolla threads 10 01-22-2006 09:15 PM
