2003 turbo camry <<< need help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2007, 08:06 PM   #1 (permalink)
old red
old red's Avatar
View old red's Photo Gallery
Question 2003 turbo camry <<< need help
hi everyone
i have a 2003 4 cylinder camry
i installed my own custom turbo kit
it's similar to the ZPI stage 0 kit (made for the scion tc which has the same 2AZ-FE)
the kit doesn't have an intercooler nor e-manage... yet the tc guys put up to 230whp@6psi boost
at 5 psi they get around 222whp
here's the problem:
i only got 161whp
huge disappointment
my kit is similar to the ZPI's one.. same layout too
i'm using a catless exhaust system..
what's the problem guys? why am i not getting enough power??
knowing that nothing's wrong with the clutch...
s.o.s.
old red is offline   Reply With Quote
Old 11-21-2007, 08:24 PM   #2 (permalink)
View Aceventura9586's Photo Gallery
Get an intercooler for starters.
Aceventura9586 is offline   Reply With Quote
Old 11-21-2007, 08:28 PM   #3 (permalink)
old red
old red's Avatar
hi everyone
i turbo-charged my 2003 2.4L camry
my turbo kit is similar to the ZPI's stage 0 kit (made for the scion tc which uses the same 2AZ-FE engine)
the ZPI's kit doesn't use an intercooler nor an e-manage yet it puts up to 230whp running 6 psi
i've seen dyno charts giving 221whp at 5 psi..
i've put up my own turbo kit similar to the tc's one, with same pipe layout too..
but i only got 161whp !!!!! <<<< huge disappointment
there's nothing wrong with the clutch..
i'm using a cat-less exhaust sys. (no back pressure)...
so what's wrong guys?
where's my extra 50whp???
Old 11-21-2007, 08:36 PM   #4 (permalink)
old red
old red's Avatar
they get 230whp without an intercooler...
i'm way behind...
surly there's a problem other then icoming air's temp..
Old 11-21-2007, 08:39 PM   #5 (permalink)
&amp; JustAnotherCamry
View JustAnotherAsian's Photo Gallery
any tuning done?
JustAnotherAsian is offline   Reply With Quote
Old 11-21-2007, 08:52 PM   #6 (permalink)
The Connoisseur
CharmCityES's Avatar
have u had any sort of tuning to make sure everything is runing up to par?
and an intercooler is a big help....is not much to add a small one either
pics too please....this isreal interesting and i wanna see hpw this is turning out
The "Executive Sedan"
Old 11-21-2007, 09:00 PM   #7 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
get some pictures up, and put up a detailed parts list of what you added (dont just say "its like so-and-so's kit")
then maybe we'll have a clue as to whats going on
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 11-21-2007, 11:19 PM   #8 (permalink)
Not-So-New TN User
Netforcer's Avatar
Gameroom cash: $225700
how big is the turbo?
My Partial Partout!!!
Photo Album
Old 11-22-2007, 12:58 AM   #9 (permalink)
BANNED
View w203's Photo Gallery
so what are you using to tune?
w203 is offline   Reply With Quote
Old 11-22-2007, 07:29 AM   #10 (permalink)
Not a Pre-runner
Twisted Sid's Avatar
Gameroom cash: $386100
View Twisted Sid's Photo Gallery
this might have just a little to do with it.
'94 Pickup: Std Cab, 22RE, 5spd, 2wd
Front: Total Chaos Uniball Kit, Fox 8''Coilovers, Custom Engine Cage, Hannemann Fenders,
REAR: Deaver F67 Leafs, Fox 14''Shocks, Custom Bed Cage, Glassworks Bedsides, Tacoma E-locker Axle 4:88 31x10.5 BFG AT Tires
Twisted Sid is online now   Reply With Quote
Old 11-22-2007, 07:37 AM   #11 (permalink)
07 Camry XLE V6
View tiswicked's Photo Gallery
There could be many reasons why you are not getting similar numbers, you need to give more details on your setup and also most of the guys on the forums like to see pics. Could be any of the following:
No tuning -(need a piggy back, management or reflashed ECU), this is usually the #1 reason for lack of power and most like with out it you will be running a LEAN condition.
No intercooler -intercoolers are an important part of a turbo setup
Turbo type - (if your turbo is not properly setup to the type of engine, you will hardly see any gains) There are thousands of turbos out there with different spec, there is a great deal of research required when a turbo kit is created by performance aftermarket companies (greddy, HKS, etc...)
Restrictive piping- For a turbo setup it is important that everything is mandrel bent. All intake/intercooler piping, turbo manifold, down pipe and exhaust.
Stock intake or exhaust?- Turbos need to breathe and exhale, both are BPU (basic performance upgrades)
Engine Compression
Pressure loss
Vacuum Leak
2007 Camry XLE V6
tiswicked is offline   Reply With Quote
Old 11-22-2007, 08:38 AM   #12 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
+1
2006 Camry LE Special Edition
Old 11-22-2007, 09:17 AM   #13 (permalink)
I'm hoping this wasn't one of those things where you hoped it was just a bolt on feature. If so, you've gotta do something fast. If you've made no changes at all to anything in your engine/exhaust/intake and your running a turbo, you're asking for a problem. Our cars are only designed to withstand about 8lbs of pressure which is almost the bare minimum that turbo's are made in, unless you had something done to make it smaller.
Old 11-22-2007, 12:45 PM   #14 (permalink)
Not-So-New TN User
Netforcer's Avatar
did you try to do a DEI (Direct Exhaust Injection?)?
http://forums.worsethanfailure.com/f...ad/137373.aspx
I'm about to put up a BS flag...
Photo Album
Old 11-22-2007, 02:39 PM   #15 (permalink)
2003 Camry Speedster
View IPDaily's Photo Gallery
Gen5
if you want more hp, you'd probably be better off trading it in for an 08 V6... 268hp an naturally aspirated
2003 Toyota Camry XLE V6, 18x7.5" ASA rims +40mm offset, Bridgestone Potenza Tires 225/45/18, H&R Sport Springs, TRD Exhaust/Strut Tower Brace/Rear Sway Bar, Wood Steering Wheel, 20% LLumar Tint
2007 Toyota Camry SE V6, Sport Leather
IPDaily is offline   Reply With Quote
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
2001 5sfe Turbo Camry Project Help! speedpro81 3rd & 4th Generation (1992–1996 & 1997–2001) 18 01-18-2005 11:33 PM
Turbo camry????? LWF Camry & Solara Lounge 15 01-15-2005 02:39 PM
Wanta Turbo my 3SGE Camry The Fonz Camry & Solara Lounge 4 01-01-2005 05:21 PM
2003 Camry Daemon 5th & 6th Generation (2002-2006 & 2007-2011) 19 11-16-2002 09:04 AM
