Nissan Code P0158 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-22-2007, 09:44 AM   #1 (permalink)
View 1996camry's Photo Gallery
Nissan Code P0158
I have 2001 Nissan Pathfinder with 54k miles...normal this car used gas (89) but put a wrong gas for 87..now i got Engine services light come up...went by Auto zone and the code is P0158..
i remove the negative battery cable out to reset the light but the light still on.. P0158 is oxygen sensor ('bank 2 sense 2)....can you tell where it's locate?
is there a way to reset engine light without using scan (ODBB) to reset?
Does anyone has manual for 2001 Nissan Pathfinder model?
thanks....
1996camry is offline   Reply With Quote
Old 11-22-2007, 10:09 AM   #2 (permalink)
07 Camry XLE V6
View tiswicked's Photo Gallery
First, I think you are posting in the wrong section and maybe even the wrong forum. "Gen 5 & 6 Camry"
But to reset the light, the guys at AUTOZONE can reset the light when they scan for the code, just ask them to.
Also if the vehicle requires 89 gas and you use 87 gas it maybe knocking (pinging) and giving you that code. Sometimes it's very hard to notice engine knock but the onboard computer usually picks it up.
Or a faulty O2 sensor, hey it happens.
2007 Camry XLE V6
tiswicked is offline   Reply With Quote
Old 11-22-2007, 10:35 AM   #3 (permalink)
may you direct which website forum for Nissan?
Old 11-22-2007, 10:39 AM   #4 (permalink)
07 Camry XLE V6
I am not sure which one for a pathfinder but if you had a nissan 350z then I would recommend www.my350Z.com
Try a GOOGLE search for "PATHFINDER FORUM"
2007 Camry XLE V6
Old 11-22-2007, 10:45 AM   #5 (permalink)
07 Camry XLE V6
found one:
http://www.nissanforums.com/truck-suv/
2007 Camry XLE V6
Old 11-22-2007, 11:05 AM   #6 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1076258
iTrader Score: 7 reviews
did i accidently log into a Nissan forum? I believe this is TOYOTANation...not NissanNation...but i could be wrong
2002 Camry SE V6 "Snow White"
19x8 +48 Offset TRD rims are Foe Sale. PM For Inquiries
Old 11-22-2007, 11:06 AM   #7 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Knocking/pinging will not give an O2 sensor code. That code has nothing to do with engine performance. It's strictly emissions.
2006 Camry LE Special Edition
Old 11-22-2007, 11:32 AM   #8 (permalink)
07 Camry XLE V6
my mistake, i thought that the O2 sensor checked your exhaust air/fuel ratio to see if you're running rich (more fuel vapor, less oxygen) or lean (excess oxygen). But I think it does both fuel management and emissions.
2007 Camry XLE V6
Old 11-22-2007, 11:38 AM   #9 (permalink)
TRD VVTi's Avatar
No, it doesn't do both.
Sensor 2 is for emissions only. Period. That's the facts.
Apparently there is a TSB for replacement of the rear O2 sensors and a reflash of the PCM/ECU for this condition.
A quick Google search of "2001 Pathfinder P0158" has netted these results:
http://64.233.167.104/search?q=cache...lnk&cd=1&gl=us
http://www.nissanhelp.com/Ownership/.../NTB02-006.htm
There are more but the OP can do the research. There's plenty of information out there regarding this condition.
This thread needs to die now...
Old 11-22-2007, 11:48 AM   #10 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
Speaking of Pathfinders...I drove one like 2 years ago. From what I remember:
1) It couldn't stop (terrible brakes).
2) It couldn't go (underpowered).
3) 6-speaker Bose sound system was horrid.
Why did anyone buy these things again?
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 11-22-2007, 12:01 PM   #11 (permalink)
07 Camry XLE V6
http://en.wikipedia.org/wiki/Oxygen_sensor
Automotive oxygen sensors, colloquially known as an O2 sensors or lambda sensors make modern electronic fuel injection and emission control possible. They determine if the air/fuel ratio exiting a gas-combustion engine is rich(unburnt fuel vapor) or lean(excess oxygen). Closed loop feedback controlled fuel injection means that the fuel injector output is varied according to real-time sensor data rather than operating with a predetermined fuel map (open loop). In addition to improving overall engine operation, they reduce the amounts of both unburnt fuel and oxides of nitrogen from entering the atmosphere. Unburnt fuel is pollution in the form of air born hydrocarbons, while oxides of nitrogen(NOX gases) are a result of excess air in the fuel mixture resulting in smog and acid rain producing compounds.
This information is sent to the engine management ECU computer, which adjusts the mixture to give the engine the best possible fuel economy and lowest possible exhaust emissions. Failure of these sensors, either through normal aging, the use of leaded fuels, or due to fuel contamination with eg. silicones or silicates, can lead to damage of an automobile's catalytic converter and expensive repairs.
Tampering with or modifying the signal that the oxygen sensor sends to the engine computer can be detrimental. When the engine is under low-load conditions (such as when accelerating very gently, or maintaining a constant speed), the engine is operating under 'closed-loop mode'. This refers to a feedback loop between the fuel injectors, and the oxygen sensor, to maintain stoichiometric ratio. If modifications cause the mixture to run lean, there will be a slight increase in fuel economy, but with massive nitrogen oxide emissions, and the risk of damaging the engine due to detonation and excessively high exhaust gas temperatures. If modifications cause the mixture to run rich, then there will be a slight increase in power, again at the risk of overheating and igniting the catalytic converter, while decreasing fuel economy and increasing hydrocarbon emissions.
When an internal combustion engine is under high load (such as when using wide-open throttle) the oxygen sensor no longer operates (it works, but the signal isn't used to make adjustments in relation to fuel trim/control), and the engine automatically enriches the mixture to protect the engine. Any changes in the sensor output will be ignored in this state, while changes from the air flow meter can lower engine performance due to the mixture being too rich or too lean, and increase the risk of engine damage due to detonation if the mixture is too lean.
2007 Camry XLE V6
Old 11-22-2007, 01:29 PM   #12 (permalink)
TRD VVTi's Avatar
That's a great description of SENSOR 1 however the problem is with SENSOR 2.
Sensor 2 has not input on vehicle performance. It's only there to monitor the convertor(s) as part of OBD II. They are also referred to as catalyst monitors for that reason.
You really don't need to post anymore, you don't know what you're talking about or apparently what you're searching for...
Old 11-22-2007, 01:56 PM   #13 (permalink)
07 Camry XLE V6
Sensor 1 / sensor 2 minor details but anyhow have a happy thanksgiving Vtec. I'm leaving work now, time to eat some turkey.
2007 Camry XLE V6
Old 11-22-2007, 03:08 PM   #14 (permalink)
TRD VVTi's Avatar
Minor details, just a completely different parts and functions...
You have a Happy Thanksgiving as well, tisstump.
I hope you weren't working on cars today... or ever...
Old 11-22-2007, 11:55 PM   #15 (permalink)
The Connoisseur
CharmCityES's Avatar
as usual.....TRD knows his stuff....gotta love someone who will help even if it doesnt pertain to a car that is covered by our fourm
The "Executive Sedan"
Toyota Engine code vivian General Discussion 22 12-27-2008 01:16 AM
2009 Nissan GT-R Production Model xpeed General Discussion 20 10-28-2007 02:48 AM
Radio Error Message 06 Sport Taco 2nd Generation (2005+) 9 09-10-2007 08:45 PM
ecu trouble code Nx2k Archived Corolla threads 1 02-12-2003 06:36 PM
