2004 se v6 3.3l shifting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-22-2007, 10:02 AM   #1 (permalink)
View johnnguyen's Photo Gallery
i'm a noob at this, but i have been reading the threads about the camry transmission doing some dramatic shifting and i find it very similar to my case. i have a 2004 se v6 3.3l. it has those problemactic shifting cases where it would be hisatint when shifting between 20 to 40 mph, also when you stop it does a dramatic shift and it forces your back off the seat even when you try to soften up the breaking before a stop.... very jerky everyway. does anyone have any advice for me as to how to approach the dealership?
father bought the 2004 cam se v6 3.3l brand new back in 04 and gave it to me, now it has about 55k miles on it. is there anything i can do? i was reading about the reseting the transmission by taking the negative wires off the battery to reset the car or something, would that help in addition to going to the dealership?
johnnguyen is offline   Reply With Quote
Old 11-22-2007, 10:35 AM   #2 (permalink)
07 Camry XLE V6
View tiswicked's Photo Gallery
Take it to the dealership 5yr / 60K mile PowerTrain warranty
Do your best to explain the situation to them and be sure to go along for the road test when they try to duplicate the problem or you do the driving and show them the issue since it will be easier for you to duplicate. Sometimes they will return your can and say "unable to duplicate issue"
2007 Camry XLE V6
tiswicked is offline   Reply With Quote
Old 11-22-2007, 01:51 PM   #3 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
You could try disconnecting the negative lead on the battery for a few minutes.
If that doesn't change anything or make it appear more normal you can always have the dealer check it.
If there's a problem it should be covered under the 5 year/60,000 mile powertrain warranty. If there isn't a problem, they may charge you a diagnostic fee/check out charge for checking your car out.
2006 Camry LE Special Edition
Old 11-22-2007, 02:36 PM   #4 (permalink)
2003 Camry Speedster
View IPDaily's Photo Gallery
Gen5
i would try resetting the ECU before you do anything else... you'd be surprised how much that can accomplish... all you have to do is disconnect the negative battery terminal for about 30 minutes, then start the car and let it run for about 10-15 minutes, so it warms up, then you can drive it... resetting the ECU will change the values stored in the computer so that they reprogram themselves to optimally suit your driving style... i actually did it with mine, and now it feels peppier and the transmission seems to shift more smoothly, so give it a try... if that doesn't work, take it to the dealership... i think there might actually be a TSB for shifting smoothness in gen 5 camry's... i don't know if it applies to the 1MZ and the 3MZ or just the 1MZ, but i had it done to mine at one point...
2003 Toyota Camry XLE V6, 18x7.5" ASA rims +40mm offset, Bridgestone Potenza Tires 225/45/18, H&R Sport Springs, TRD Exhaust/Strut Tower Brace/Rear Sway Bar, Wood Steering Wheel, 20% LLumar Tint
2007 Toyota Camry SE V6, Sport Leather
IPDaily is offline   Reply With Quote
Old 11-22-2007, 03:01 PM   #5 (permalink)
TRD VVTi's Avatar
You don't need to disconnect the battery for 30 minutes...
There is also no need to let the car run for 10-15 minutes...
Old 11-22-2007, 03:07 PM   #6 (permalink)
i'm sorry, but what does TSB stand for?
Old 11-22-2007, 03:11 PM   #7 (permalink)
TRD VVTi's Avatar
Technical Service Bulletin.
TSB's are articles that technicians use to diagnose cars. You can look up TSB's for previously documented problems/failures/etc.
Old 11-23-2007, 01:09 PM   #8 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
Sorry im late. There is a TSb for your concern.
Engine Controls - A/T Downshift Lag/Gear HuntingTRANSMISSION & CLUTCH
TC003-05
Title:
ECM CALIBRATION: SHIFT FEELING
ENHANCEMENT
Models:
'04 - '05 Camry (3MZ-FE, 5-Speed A/T)
June 3, 2005
Introduction
To improve the transmission shift feeling during specific operating modes, the Engine Control Module (SAE term: Powertrain Control Module/PCM) calibration has been revised. These improvements include:
^Reduced downshift lag when accelerating at speeds from 10 to 20 mph.
^Less gear hunting when driving on/off accelerator pedal at 20 to 30 mph (for example: during heavy rush-hour traffic).
^Improved response rate during heavy acceleration from a stop.
NOTE :
^Version 12.2a or later Diagnostic Tester software is required to perform this procedure.
^Before proceeding, verify the ECM (PCM) calibration has NOT been updated by checking for the Authorized Modifications Label (shown in step 1 of the Repair Procedure).
^Harsh ATM shifting may result if any Repair Procedure steps are omitted (specifically steps 2 and 4 of "Flash Reprogram ECM").
Applicable Vehicles
^2004 - 2005 model year Camry vehicles equipped with 3MZ-FE engine and 5-speed automatic transmission.
Warranty Information
Applicable Warranty*:
This repair is covered under the Toyota Federal Emissions Warranty. This warranty is in effect for 96 months or 80,000 miles, whichever occurs first, from the vehicle's in-service date.
*Warranty application is limited to correction of a problem based upon a customer's specific complaint
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 11-23-2007, 04:54 PM   #9 (permalink)
thank you.
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 02:49 PM
so i crunched some numbers, true carlo$ 5th & 6th Generation (2002-2006 & 2007-2011) 36 10-28-2007 06:12 AM
08 Accord EXL-V6 vs Camry SE V6 krispykreme 5th & 6th Generation (2002-2006 & 2007-2011) 12 10-01-2007 08:43 PM
2004 Camry SE V6 clean slate Brin747 5th & 6th Generation (2002-2006 & 2007-2011) 5 04-21-2006 10:05 AM
Almost in a 2004 SE V6 abracc Introduce Yourself Here 1 07-30-2005 10:28 PM
