2007 Camry V6 oil filter wrench?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-22-2007, 02:24 PM   #1 (permalink)
View JAG66's Photo Gallery
I bought a 65/67mm oil filter wrench to remove my filter canister, but it's too large and slips. What do the Toyota technicians use and where can I purchase one? Thanks...
JAG66 is offline   Reply With Quote
Old 11-22-2007, 03:15 PM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
The search function in this forum is working fine. I used it and found this previous thread for you:
http://www.toyotanation.com/forum/t186291.html
2006 Camry LE Special Edition
Old 11-22-2007, 09:29 PM   #3 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
i use an oil filter wrench that looks like a large pair of channel lock pliers. this way its universal enough to use on multiple vehicles.
Old 11-22-2007, 10:13 PM   #4 (permalink)
Thanks for the help.
Old 11-22-2007, 11:30 PM   #5 (permalink)
The Connoisseur
CharmCityES's Avatar
haha
easy solution
the canister comes off in one piece, so i use a standard socket wrench with an extension and remove the whole canister by inserting the extension square tip into the canister square indentation and twisting counterclockwise....works like a charm, but watch the hot oil spill....its a little messier than the standard method, but it works....clean the canister, change the large O ring gasket, insert new filter, and put ir back on hand tight, and tighten the canister further by tightening clockwise with the socket wrench/extension
The "Executive Sedan"
Old 11-23-2007, 11:53 AM   #6 (permalink)
Originally Posted by CorCamrySE View Post
haha
easy solution
That's not the way it works on my 07. The 3/8" square indentation removes the housing drain plug to drain the cannister, then I need the tool to remove the filter cannister housing.
You may have your cannister drain plug on so tight that you can actually remove the housing with your ratchet and extension???
Old 11-23-2007, 12:21 PM   #7 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
Usually the drain plug IS too tight to remove seperate from the housing. When trying to remove it, the whole housing comes out.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 11-23-2007, 08:47 PM   #8 (permalink)
The Connoisseur
^^ exactly. it seems to always come out as one whole piece...although it doesnt appeaer as it would
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 02:49 PM
Toyota Camry 2007 oil filter? compfreak 5th & 6th Generation (2002-2006 & 2007-2011) 5 07-30-2007 10:56 PM
2007 Camry V6 Oil Filter Problem pillpusher84 5th & 6th Generation (2002-2006 & 2007-2011) 5 10-04-2006 07:33 AM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
Oil Filter Wrench BenG Hardcore Tech and Competition 12 07-22-2003 10:01 PM
