battery - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-22-2007, 05:19 PM   #1 (permalink)
View johnnguyen's Photo Gallery
Gen5 battery
how do you clean out the battery corrosion properly? there may be already a thread for this, but i can't seem to find it.
johnnguyen is offline   Reply With Quote
Old 11-22-2007, 05:50 PM   #2 (permalink)
View TRDGen5.5camry's Photo Gallery
Talking
step:
1.get a cup
2.get baking soda
3.get water
4.put baking soda and water in to cup
5.mix them together(water & baking soda) in the cup
6.get a rag or cloth
7.dip the rag or cloth in the cup that mix with water & baking soda
8.apply the stuff to where there is rust at the battery
9.clean up the mess that you make in step 8
10.take 2 step back and give yourself a pad on the back for a job well done
TRDGen5.5camry is offline   Reply With Quote
Old 11-22-2007, 06:52 PM   #3 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
Baking soda works good but you can purchase a designated cleaner from any auto parts store that works better and doesn't make near as much mess.
I had a bottle of red stuff that I think was made by MOC. It worked very well.
Use a stiff bristle brush and make sure that you remove the cables to get all the corrosion.
Remove the negative battery cable first, and install the negative battery cable last.
2006 Camry LE Special Edition
Old 11-22-2007, 10:37 PM   #4 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
if you are going the baking soda route, i recommend removing the battery. when i cleaned my battery, i got the stuff all over the place, especially using a wire brush to get the harder corrosion off. although this may just be in my case because i had a LOT of corrosion on it. enough that it took me half an hour, a flat head screwdriver, and about 3 cups of the baking soda mixture to even be able to remove the positive side clamp
MrSo0h0o is offline   Reply With Quote
Old 11-22-2007, 10:50 PM   #5 (permalink)
TRD VVTi's Avatar
That's why when I saw a hint of corrosion on my battery I said screw it and replaced it with an Optima.
Cheap batteries suck.
Many years ago I had an AC Delco battery leak (in my Formula) and the acid went into the positive cable all the way to the starter. My starter was so corroded that it looked like a Chia pet. Needless to say I didn't notice it until the black plastic tubing that protects the cable under the car turned to a liquid and ended up on my garage floor in a puddle. I had an extended warranty at the time and didn't have to pay for anything but as soon as the next battery showed a hint of leaking, I replaced it with an Optima also.
Old 11-22-2007, 10:56 PM   #6 (permalink)
MrSo0h0o's Avatar
yea i got my car used so it prob went 22k without the battery being cleaned.. it got so bad that it wouldnt start because it was that corroded. i thought i had a bad battery so i bought a new one, but when i cleaned it off and took it out, the eye was green and thats when i realized.. but a nice battery is nice to have
Old 11-22-2007, 11:46 PM   #7 (permalink)
The Connoisseur
CharmCityES's Avatar
correct. the battery service kit isn made by MOC and it is very good. when i service batteries at work and the battery on my camry this is what i use...
baking soda also works very well if you cant track down the service kits
gotta love homemade car maintenence
The "Executive Sedan"
Toyota: Reconditioning Can Extend Hybrid Battery Life Tideland Prius Toyota News 8 10-10-2007 10:28 PM
Battery dies after 3 -4 days capinoy 89-95 Toyota Pickup/Hilux 13 06-05-2007 10:37 PM
Battery Problems haux Camry & Solara Lounge 3 09-21-2006 12:48 AM
More on this damn car battery! speedemn Camry & Solara Lounge 14 01-01-2006 09:21 PM
Battery ?'s 1995 camry V6 LE kenny1773 3rd & 4th Generation (1992–1996 & 1997–2001) 14 11-29-2004 03:29 PM
