Best brakes? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-22-2007, 06:13 PM   #1 (permalink)
etc
View etc's Photo Gallery
Best brakes?
What are some good front brake pads for 02 Camry?
rockauto dot com has a multitude of choices.
etc is offline   Reply With Quote
Old 11-22-2007, 06:49 PM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
OEM pads are probably the best choice for low noise, low dusting, and long life. They also provide for immediate bite at low temperatures. They aren't expensive either. Make sure that you reuse the shims. If the shims are already gone, get a set from the dealer.
2006 Camry LE Special Edition
Old 11-22-2007, 07:29 PM   #3 (permalink)
etc
Look on rockauto, they have several makers claiming to have OEM... that's the confusion.
Old 11-22-2007, 08:24 PM   #4 (permalink)
Gameroom cash: $101605
View kenny1773's Photo Gallery
TRD VVTi is telling you to get the pads from a Toyota Dealer
If you insist on using RockAuto, I have had good luck with the Raybestos Professional Grade Ceramic (they may say OE Ceramic) - good pads
I think Akebono Ceramic was the original toyota pad OEM available at tirerack.com
I have also had good luck with the Hawk HPS Street pads from tirerack.com
edit to add working rockauto.com 5% off code 809906618368 - good until Dec 17th 2007 I think
kenny1773 is offline   Reply With Quote
Old 11-22-2007, 10:33 PM   #5 (permalink)
I callz it like i seez it
View ScrooYoo's Photo Gallery
I looked at that website and the pads they have on there are really cheap which makes me think they are lousy quality.
I would suggest spending the extra money and get premium pads. They cost more but they pay for themselves because they last twice as long and the cheap ones tend to whistle/squeak/grind.
I've been using Monroe premium (abt. $60 a set in Canada) and find they work pretty well.
ScrooYoo is offline   Reply With Quote
Old 11-22-2007, 11:20 PM   #6 (permalink)
etc
Do you mean these Monroe Ceramic brakes?
$26.79$0.00$26.79
$26.79$0.00$26.79
QuickStop}
Front$27.89$0.00$27.89
MONROE Part # CX908 {Premium Ceramic Pads (Monroe STOP & GO Promotion--Purchase Monroe Premium Brake Pads and receive a $20 Rebate (one per household)--See More Info page for details)}
Front; Noise Elimination Clips Included.
$29.79$0.00$29.79
ACDELCO Part # 17D908C {#19108017}
PAD KIT,FRT DISC BRK DURASTOP CERAMIC$30.79$0.00$30.79
MONROE Part # DX828 {Monroe Dynamic Pads (Monroe STOP & GO Promotion--Purchase Monroe Premium Brake Pads and receive a $20 Rebate (one per household)--See More Info page for details)}
Rear; (Made in USA); Noise Elimination Clips Included.
$30.79$0.00$30.79
MONROE Part # DX908 {Monroe Dynamic Pads (Monroe STOP & GO Promotion--Purchase Monroe Premium Brake Pads and receive a $20 Rebate (one per household)--See More Info page for details)}
$31.79$0.00$31.79
ACDELCO Part # 17D908M {#89033887}
PAD KIT,FRT DISC BRK DURASTOP SEMI MET$32.99$0.00$32.99
WAGNER Part # PD908 {ThermoQuiet}
Front$34.79$0.00$34.79
MONROE Part # DX885 {Monroe Dynamic Pads (Monroe STOP & GO Promotion--Purchase Monroe Premium Brake Pads and receive a $20 Rebate (one per household)--See More Info page for details)}
Rear; (Made in Japan); Noise Elimination Clips Included.
$34.89$0.00$34.89
WAGNER Part # PD885A {ThermoQuiet}
Rear; Japan Built$34.99$0.00$34.99
ACDELCO Part # 17D828C {#19108001}
PAD KIT,RR DISC BRK DURASTOP CERAMIC$35.79$0.00$35.79
MONROE Part # CX885 {Premium Ceramic Pads (Monroe STOP & GO Promotion--Purchase Monroe Premium Brake Pads and receive a $20 Rebate (one per household)--See More Info page for details)}
Rear; (Made in Japan); Original Equipment Replacement Recommendation.; Noise Elimination Clips Included.
Old 11-22-2007, 11:24 PM   #7 (permalink)
the critic's Avatar
View the critic's Photo Gallery
Best brake pads that I've used are the Akebono ProACT ceramics. No noise, low dust, and super long life if they are installed on a freshly resurfaced or new set of rotors with the proper lubrication. Hawk HPS pads are also great for drivers who tend to overheat their pads (and cause pedal pulsation due to uneven filming), but these pads require a very specific bed-in method and even then, have the potential to squeak every once in a while.
Pep Boys sells a Prostop Ceramic pad for around $40, and it's made by Satisfied. They are selling their entire stock of Prostop branded brake pads for $10/axle tomorrow during Black Friday. Worth a look.
the critic is offline   Reply With Quote
Old 11-22-2007, 11:42 PM   #8 (permalink)
The Connoisseur
CharmCityES's Avatar
ive only heard good things about hawk HPS if oure looking for performance stoppig ability
as for oem quality, tyhe only way to g is OEM toyota, from the dealer.....like TRD said be sure to use oem shims and utalize the wear indicator
The "Executive Sedan"
Old 11-22-2007, 11:44 PM   #9 (permalink)
the critic's Avatar
Akebono ProACT pads tend to outperform OE pads by delivering lower dust output and improving service life without compromising noise.
Old 11-23-2007, 12:14 AM   #10 (permalink)
etc
Sounds interesting.
Quote---------
Old 11-23-2007, 01:15 AM   #11 (permalink)
the critic's Avatar
Warning though, the ad says all Prostop pads in stock are $9.99/axle, but some stores claim it's a misprint. Still worth a try though.
Regardless of what pads you use, be sure to resurface or replace the rotors, lubricate the slide pins, pad abutment clips and the pad shim with a synthetic caliper grease.
Old 11-23-2007, 06:48 AM   #12 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
Someone try the new Wagner "Edge" pads.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 11-23-2007, 12:33 PM   #13 (permalink)
etc
FWIW, PepBoys had a sale from the morning to 11AM, and the only ones on sale where cheap generic ones, not ceramic, based on what I was told there (rightly or not) In any case, there is nothing on sale as of 1pm friday.
AE92 & AE82 Brake upgrade options.... freakinbox Older Generations (1969-1987) 8 09-13-2007 03:41 AM
1995 Camry LE Soft Brakes kentarver 3rd & 4th Generation (1992–1996 & 1997–2001) 14 10-17-2006 06:33 AM
Brakes, How are yours? Chazmanian 2nd Generation (2005+) 45 03-24-2006 03:18 AM
Changing Drum Brakes to Disk Brakes on 2003 LE DragonR6 5th & 6th Generation (2002-2006 & 2007-2011) 1 12-10-2004 04:07 PM
Conversion Kit - Rear Drum Brakes To Disc Brakes Nikolas Archived Corolla threads 5 08-20-2004 10:38 PM
