'03 Camry blowin' smoke on start-up after extended no use - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-26-2007, 02:05 AM   #1 (permalink)
'11 Camry SE Sport
View carrlos's Photo Gallery
Recently my 2003 Camry LE is blowing out a big puff of bluish/white smoke in the mornings when I first start the car or after extended periods of non-use. But I am not getting any smoke any other time that I can detect. The temperature here doesn't drop much below 70 degrees if it does.
What could this be and how can I remedy it?
carrlos is offline   Reply With Quote
Old 11-26-2007, 08:15 AM   #2 (permalink)
Not-So-New TN User
Netforcer's Avatar
Gameroom cash: $224200
You might be burning oil
My Partial Partout!!!
Photo Album
Old 11-26-2007, 08:30 AM   #3 (permalink)
'11 Camry SE Sport
That's a little obvious!!! But I need to know the possible culprit and what I can do to remedy the situation. I'm still not ready for a new car!!
Old 11-26-2007, 10:22 AM   #4 (permalink)
View Aceventura9586's Photo Gallery
Valve cover gasket leak?
Aceventura9586 is offline   Reply With Quote
Old 11-26-2007, 11:01 AM   #5 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $172825
View JSM1284's Photo Gallery
Most likely just the valve seals. Common problem, nothing big to worry about.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 11-26-2007, 11:13 AM   #6 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $318510
View gdanaher's Photo Gallery
There are valve stem seals which are attached to the tops of the valve guides. Their job is to prevent oil from draining down the stem of the valves. Over time they wear out and let some oil to get by. This usually happens with high mileage engines. 100k or better. They can be replaced with the head installed but it is tricky. Generally you wait until you need a valve job.
gdanaher is offline   Reply With Quote
Old 11-26-2007, 11:15 AM   #7 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
easy their guys .... it could just be condensation and such from sitting for so long
several of my cars have done that, my camry did it this year after the temp change
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 11-26-2007, 12:07 PM   #8 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
Id have to agree with the valve seals guess since hes seeing bluish white smoke. Like everyone else said, dont worry about it untill you need major engine work done.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 11-26-2007, 01:21 PM   #9 (permalink)
Banned
View DressUpYourPet's Photo Gallery
yeah id leave it alone like everbody says. Until the following happens or is aboutt o happen:
1. Engine needs a valve job (theshop will change em then)
2. Smoke becomes too excessive your car looks like the Batmobile trying to elude the joker with his Bat-cloud
3. Your car is about to go and have smog check. If you have smog check chances are it is not going to pass, obviously, if theres any oil burning out the tailpipe.
If a compression check and mileage show the engine to be in fine shape, it is possible to just change the valve seals with the cylinder head still in the car - but on most if not all camry engines the camshafts have to come out to get to the valve seals. And you still have to remove a whole bunch of parts just to do that.
DressUpYourPet is offline   Reply With Quote
Old 11-26-2007, 02:17 PM   #10 (permalink)
View toyomoho's Photo Gallery
Have someone start the engine whilst you smell the exhaust smoke. If water, oil or gas you will know it. Off hand sounds like worn exhaust valve seals, if so the amount of smoke will increase over time.
I have changed the seals with the head(s) still on the car but it is very time consuming! Once the seals were installed the startup smoke want away.
Old 11-26-2007, 02:42 PM   #11 (permalink)
'11 Camry SE Sport
Thanks everyone!
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 09:42 PM
08 Accord EXL-V6 vs Camry SE krispykreme 5th & 6th Generation (2002-2006 & 2007-2011) 17 05-22-2009 11:12 PM
08 Accord EXL-V6 vs Camry SE V6 krispykreme 5th & 6th Generation (2002-2006 & 2007-2011) 12 10-01-2007 09:43 PM
plastic protectant on lower panels of 03 camry CharmCityES Detailing & Car Care 3 04-10-2007 03:12 AM
Fusion marches past Camry! sciguy0504 Camry & Solara Lounge 38 05-04-2006 07:27 AM
