so I want to replace my own tranny - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-26-2007, 10:04 AM   #1 (permalink)
carlo$'s Avatar
View carlo$'s Photo Gallery
fluid.
i was told all i have to do is remove the plug and drain the fluid.
i do not want to drop the pan and replace the filter, if there is one.
my question is, once i remove the plug how much fluid is going to drain out?
i need to know so i can buy the right amount from toyota.
looking at the online manual all i saw were instructions on how to drain the fluid and take the tranny apart.
i did not see anything about a tranny filter.
thanks.
2005 LE 4 cyl
carlo$ is offline   Reply With Quote
Old 11-26-2007, 10:27 AM   #2 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $133432
View Yazovets's Photo Gallery
I'm pretty sure there's no filter involved here. Ask a Toyota dealer to look up the quantity necessary for the fluid.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 11-26-2007, 11:02 AM   #3 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $172825
View JSM1284's Photo Gallery
Drain and Fill: Up to 3.7 US. qt. (3.5 L; 3.1 Imp. qt.)
Change Automatic Transmission Fluid Only As Necessary.
Generally, it is necessary to change automatic transmission fluid only if your vehicle is driven under one of the Special Operating Conditions listed under one of the Scheduled Maintenance Guide or Owners Manual Supplement.
When changing the automatic transmission fluid, use only "Toyota Genuine ATF Type T-IV " (ATF JWS3309 or NWS6500) to aid in assuring optimum transmission performance.
Notice: Using automatic transmission fluid other than "Toyota Genuine ATF Type T-IV" may cause deterioration in shift quality, locking up of your transmission accompanied by vibration, and ultimately damage the automatic transmission of your vehicle.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 11-26-2007, 11:25 AM   #4 (permalink)
carlo$'s Avatar
you are the man! thanks.
the only reason im considering it, is because the dealer told me i needed to change the fluid.
the other day i went to quick lube to have my oil changed, they also recommended i replace the tranny fluid.
hence, i am considering doing it myself.
2005 LE 4 cyl
Old 11-26-2007, 03:39 PM   #5 (permalink)
View s0uthstar85's Photo Gallery
Your dealer told you this? Are you sure it wasn't a Oil Change Chain? If it was, then you should see this:
http://www.youtube.com/watch?v=VE8aLaoj5n0
Alot of people are getting screwed by companies like EZ Lube and Jiffy Lube.
Black 2007 Camry I4 SE - Tabula Rasa
-3M ColorStable Tint: 35% Front, 20% Back
s0uthstar85 is offline   Reply With Quote
Old 11-26-2007, 04:10 PM   #6 (permalink)
carlo$'s Avatar
actually the dealer told me first.
the following week kwik kar told me the same thing.
hence my concern.
i got ripped off by paying 39.99 for an oil change at kwik kar, last time i go there.
2005 LE 4 cyl
Old 03-06-2008, 10:12 PM   #7 (permalink)
View i 1a 05 Camry's Photo Gallery
where can I get the instruction manual on how to do the transmission drain properly?
i 1a 05 Camry is offline   Reply With Quote
Old 03-07-2008, 10:45 AM   #8 (permalink)
View kruang's Photo Gallery
Do you have the allen key to open the transmission plug? I believe the size is 11mm. I can't seem to find that around here in SoCal.
kruang is offline   Reply With Quote
94 5 speed 22re to older auto tranny swap subliminaltrips 89-95 Toyota Pickup/Hilux 4 01-27-2006 08:28 AM
94 2wd 5 speed 22re to older auto tranny swap subliminaltrips 89-95 Toyota Pickup/Hilux 0 01-18-2006 07:46 PM
94 5 speed 22re to older auto tranny swap subliminaltrips 89-95 Toyota Pickup/Hilux 0 01-18-2006 07:44 PM
Life sucks! Front wheels locked up! Tranny? es250nut Camry & Solara Lounge 4 10-08-2004 01:27 AM
Yet another Gen 2 Tranny problem spills1969 1st & 2nd Generation (1983–1986 & 1987-1991) 2 09-24-2003 03:15 AM
