Correct bulbs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-28-2007, 04:18 PM   #1 (permalink)
View RoseMobile's Photo Gallery
Gen6 Correct bulbs
Im pretty sure anyone can answer me with the quickness so here goes foglight bulbs are h11 and so are the low beams so why are the fogs less bright than my low beam headlights i just want to replace oem bulbs with some higher output ones I got the fogs covered which will be nokya hyper yellow dont know what to dofor my low beams any suggestions lookin for sumthing bright but not hid and while im where at it how can I get rid of the turn signal cover on the headlight thanks... oh yea i aint car savvy either.... thanks fellas in advance..
RoseMobile is offline   Reply With Quote
Old 11-28-2007, 04:29 PM   #2 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
They are not as bright is only an illusion caused by the type of reflector it uses.
Do you mean the amber reflector in the headlight assembly? If so, you need to bake, and dismantle the whole headlight assemblies
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 11-28-2007, 04:42 PM   #3 (permalink)
thanks alot JSM seems to be alot of work might just leave it there. on another note for my low beams n fogs what do u suggest just bulbs no kits
Old 11-28-2007, 04:46 PM   #4 (permalink)
JSM1284's Avatar
I'll let someone else chime in on bulb recommendations. I just go HID.
2005 Lexus ES330
Old 11-28-2007, 04:50 PM   #5 (permalink)
hopefully theres someone who can help me w/o tellin me to search thru the threads...
Old 11-28-2007, 05:18 PM   #6 (permalink)
Gameroom cash: $283730
View LE05's Photo Gallery
try piaa or silverstar bulbs. if you had searched ... you would have found this info.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 11-28-2007, 05:25 PM   #7 (permalink)
been around the block
View SourDieseL's Photo Gallery
i just bought Nokya Yellow Stage 1 H11 2500K fogs but haven't installed them yet. They are said to be 55W but on the packaging came 80W for H11 with a warning on the side of the packaging recommending harness upgrades. Last thing I need is my harness melting and having to make a thread like the #%@$^% one! =)
For low beams, I've been looking into/waiting for info on GE Nighthawks -search for it- but I've read mixed for both PIAA and Silverstars
SourDieseL is offline   Reply With Quote
Old 11-28-2007, 05:32 PM   #8 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
Some say you can use Silverstar ones that would be brighter then stock.
I used: http://hirheadlights.com/
Toshiba HIR bulbs, they are brighter then OEM bulbs but don't have a white/blue look to them. The color matches OEM color, but it is fairly expensive for those bulbs.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Anyone has HIR bulbs ??? jaep0913 5th & 6th Generation (2002-2006 & 2007-2011) 8 02-21-2007 10:18 PM
New Fog Bulbs ShadowfaxII Camry & Solara Lounge 31 07-27-2005 05:43 PM
Headlight Bulb Info - Halogen, HID, HIR, Lumins, etc... BLUEMEANIE General Discussion 2 02-09-2005 01:19 PM
Fog Light Bulbs virtualkuz General Discussion 4 12-05-2004 04:53 AM
Part # for gauge cluster bulbs Ratko Camry & Solara Lounge 7 01-30-2002 04:44 PM
