'08 XLE Homelink Probs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-30-2007, 03:39 PM   #1 (permalink)
View gadgetjunkie's Photo Gallery
Well I picked up my new '08 XLE this morning and am loving it! Much smoother ride than my '05 Maxima. I did a search on this and didn't come up with much so here goes. I am trying to program the Homelink to open my garage doors. I tried everyway I know of and still no luck. The openers are about 3 years old and are the Genie brand. Has anyone had any luck getting these to work? Hopefully there is a trick to this. I tried holding the old remote up to the car and then also the "learn" button on the opener itself and no luck with either method. Any thoughts?
gadgetjunkie is offline   Reply With Quote
Old 11-30-2007, 03:47 PM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
A few owners have had problems programming and/or using the Search........
Camry 2007 XLE Homelink problem
Old 11-30-2007, 03:47 PM   #3 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184780
View DrewsCam's Photo Gallery
how many buttons are on the home link unit,
if it has 3
usually you need to clear the intial memory
buttone 1 then 2 and then hold down which button you want to link along with your remote button held down for about 15seconds. This is how my moms new altima worked.
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 11-30-2007, 04:22 PM   #4 (permalink)
if it has 3
The car has 3 homelink buttons. I did clear the memory and try the method you suggest and no luck.
Old 11-30-2007, 04:28 PM   #5 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
REGISTRATION
  1. REGISTER TRANSMITTER CODE HINT:
    • The vehicle's garage door opener system records transmitter codes for systems such as garage doors gates, door locks, home lighting systems, security systems, or other transmitter-code based systems.
    • The garage door opener system is built into the roof console box assembly. If the roof console box assembly is replaced, transmitter codes previously registered in the garage door opener system must be re-registered.
    • Ensure that the customer is aware that existing codes may be cleared from the garage door opener system while performing diagnosis of the system. All remotes required to reprogram the system should be made available at the time of inspection or repair of the garage door opener system.
  1. Re-registration of codes in the garage door opener system, (registration mode) NOTE:
    • When programming a garage door opener system, you may operate a garage door or other device. To prevent injury, it is necessary to make sure that people and objects are out of the way of the garage door or other device.
    • Before beginning programming of the garage door opener system, turn off the engine and remove the key from the ignition key cylinder.
    • The garage door opener system cannot be used with openers that:
  1. Were manufactured before April 1,1982.
  2. Do not meet Federal Safety Standards (for example, garage doors without a jam protection function).
HINT:
  • 3 transmitter codes can be registered with the garage door opener system. It is possible to register one handheld transmitter code (original transmitter) for each of the three garage door opener system switches.
  • Disconnecting the vehicle's battery will not erase the transmitter codes registered in the garage door opener system.
  • An attempt to overwrite a previously registered code may fail. In this case, the previously registered handheld transmitter code will not be erased.
  • To successfully program the garage door opener system, it may be necessary to replace the handheld transmitter battery before programming.
  1. Select one of the garage door opener system switches to program.
  2. Press and hold the selected switch for 20 seconds . The garage door opener system will enter registration mode. Continue to hold this switch during steps 3 and 4. HINT: The garage door opener system LED should stay on while holding the selected switch for the 20 second period. After entering registration mode, the LED will flash approximately 1 time per second (1 Hz) . This indicates that the garage door opener system has entered registration mode and is listening for a code from a handheld transmitter.
  1. After the garage door opener system has entered registration mode, bring the original handheld transmitter within 2 to 9 cm (1 to 3 in.) of the garage door opener system. Press and hold the switch on the handheld transmitter. If the flashing speed of the garage door indicator light changes from the slow speed to a faster speed, proceed to step 4. HINT: Some handheld transmitters stop transmitting after 1 to 2 seconds . In this case, continue to hold the selected garage door opener system switch while pressing the handheld transmitter switch for two seconds at a time. Repeat the cycle of pressing and releasing the transmitter switch while monitoring for a change of the flashing speed of the indicator LED.
  1. When the indicator light begins to flash more rapidly, release both switches. This indicates that the garage door opener system has been successfully programmed. If the garage door opener system fails to program, review all hints before trying the programming process again. HINT:
    • If transmitter registration fails:
  1. The battery in the handheld transmitter may be weak or need to be replaced.
  2. The handheld transmitter and opener device to be registered may not be compatible with the vehicle's garage door opener system.
    • After entering the garage door opener system registration mode, registration of the handheld transmitter code must be completed within 90 seconds . If 90 seconds have elapsed, the garage door opener system will enter low power mode.
    • For first time programming it may be necessary to press and hold the two outer switches until the indicator light begins to flash rapidly. The length of time that it is necessary to hold the switches for in this case should be approximately 20 seconds .
    • In some cases, the garage door indicator light may flash slowly (1 time per second (1 Hz) ) as soon as the selected garage door opener system switch is pressed. This indicates that the system is ready or "listening" for a code from a handheld transmitter. Continue to hold the switch and proceed from step 3.
  1. Erasure of transmitter codes in the garage door opener system, (clear mode) HINT: All three codes registered in the garage door opener system will be erased. No option exists for erasing only one transmitter code.
    1. Press and hold the left and right switches of the garage door opener system for 20 seconds . The LED will begin to flash approximately 5 times per second (5.6 Hz.) This indicates that the codes contained in the vehicle garage door opener system have been erased. Releasing the switches ends clear mode. HINT:
    • If the switches are released within 10 seconds after the transmitter codes have been erased, the system will enter registration mode immediately the next time a garage door opener system switch is pressed.
    • If the switches are held for 10 seconds or more after the transmitter codes have been erased, default codes will be set to the three switches of the garage door opener system. These default codes may in some cases be used for training an opener device that uses rolling codes.
  1. Low power mode:
    1. If the garage door opener switch is stuck or held for 100 seconds or more , the garage door opener will enter low power mode to economize on power consumption. When the garage door opener has entered low power mode, the LED turns off. When the garage door opener switch is released, low power mode will end.
    2. ROLLING CODE SYSTEMS
  1. If the handheld transmitter for the opener device (customer's garage door) being programmed uses a rolling code, it may be necessary to "train" the garage door opener device. HINT:
    • "Train" refers to causing the opener device (customer's ceiling mounted garage door opener) to recognize a non-rolling code.
    • The steps required to "train" an opener device may vary depending on the model, type, age, and manufacturer of the device.
  1. Locate the "training" button on the opener device.
  2. Press the training button.
  3. Within 30 seconds press and release the vehicle's programmed "HomeLink" switch twice. Some opener devices may require the vehicle's switch to be pressed three times.
  4. The vehicle's garage door opener system should now operate the opener device. HINT: Opener device refers to a device such as a ceiling mounted garage door opener, which is located at the customer's residence. It is necessary to read the instructions for the customer's opener device, to allow the procedure to be performed safely and successfully. The customer should be aware that performing this procedure will result in a lowered level of security for the customer's opener device.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 11-30-2007, 04:39 PM   #6 (permalink)
Well it was a combination of setting using the handheld remote them programing with the "learn" button on the opener itself. Thanks.
Noobie just bought an 08 XLE Scottyd 5th & 6th Generation (2002-2006 & 2007-2011) 58 01-03-2008 02:28 PM
New Pics Of The 08' XLE JoKeR718 5th & 6th Generation (2002-2006 & 2007-2011) 21 11-26-2007 12:59 AM
08 XLE Grill Question Goobee 5th & 6th Generation (2002-2006 & 2007-2011) 4 10-17-2007 09:43 AM
HomeLink options.....Grrrrr Janster 2nd Generation (2005+) 20 09-25-2007 10:47 AM
Camry 2007 XLE Homelink problem yakuzao 5th & 6th Generation (2002-2006 & 2007-2011) 7 01-09-2007 09:47 PM
