Squeaking noise from rear - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-05-2007, 09:28 AM   #1 (permalink)
Slemay
View Slemay's Photo Gallery
I have a 2004 toyota camry and I have eibach springs and a TRD rear sway bar (set up on the roughest setting) since may of 2006. I live in a pretty cold climate and since the cold has arrived I have a squeaking noise from the rear of the car. You can hear the noise with the smallest bump and even giving a quick jerk of the wheel. I've sprayed W-D40 and white grease on the springs/bushings and around the bushing of my sway bar. Did not help the situation. Does any have the same problem? Any ideas?
Slemay is offline   Reply With Quote
Old 12-05-2007, 09:42 AM   #2 (permalink)
Asian N00b Modder
Gellenole's Avatar
View Gellenole's Photo Gallery
^ I have the same issue, usually you may want to try to regrease the bar itself, but if it's really cold (below 50's) it'll squeak regardless it looks like. I ignore it just because when it gets warm it doesn't do it anymore, and only happens in the extreme cold.
1995 Camry I4 @ 123k Miles - RIP 5-26-07
[Silverado Backed into it]
Originally Posted by catric69 View Post
It's cheaper if you get a new gf.
Gellenole is offline   Reply With Quote
Old 12-05-2007, 09:59 AM   #3 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
You will need to lube the bushing by taking it off the sway bar. That's usually where the noise comes from.
I've had great luck using synthetic grease on similar setups.
2006 Camry LE Special Edition
Old 12-05-2007, 10:15 AM   #4 (permalink)
2007 RED Camry XLE Owner
Old Dood's Avatar
View Old Dood's Photo Gallery
I had them do that to my 07 earlier this year. That was the trick too. No more squeaks...
"We can't solve problems by using the same kind of thinking we used when we created them." Albert Einstein
Old Dood is offline   Reply With Quote
Old 12-05-2007, 12:35 PM   #5 (permalink)
Slemay
I will try that. Thank you
Old 12-06-2007, 02:19 AM   #6 (permalink)
TRD VVTi's Avatar
Gen5
You're more than welcome. I hope that helps you out.
If not, at least know that I was touching myself with a smile on my face as I typed my reply.
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
Removing rear sway bar because of rattle noise. green94camry 3rd & 4th Generation (1992–1996 & 1997–2001) 13 02-16-2008 05:53 PM
Rear Brake Noise sandman 1st Generation (1998-2003) 14 10-03-2007 11:23 PM
2004 Camry 4cyl A/T Booming Noise in Rear LPB 5th & 6th Generation (2002-2006 & 2007-2011) 2 04-22-2004 05:18 PM
Drift Setting help for GT3 I hate Toyota Corp :( Off Topic 3 11-10-2003 10:36 PM
