Changing my foglight bulbs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-08-2007, 12:08 AM   #1 (permalink)
View ToyoSe's Photo Gallery
Gen6 Changing my foglight bulbs
I just got nokya bulbs, how do i change my foglight bulbs. i tried to search but couldnt find and diy, can someone post a link here, thanks
ToyoSe is offline   Reply With Quote
Old 12-08-2007, 03:08 AM   #2 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
http://www.camrymanuals.com/index.ph...=110&topicid=0
It is fairly easy, just remove the splash guards on the wheels wells and you can reach your hands in.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 12-08-2007, 09:06 AM   #3 (permalink)
07 Camry XLE V6
View tiswicked's Photo Gallery
I just installed my Nokya bulbs in my Foglights about 4 days ago. It was fairly easy and quick. If you have a ramp then it would be even easier. I tried to put my car up on ramps but the front bumper was touching just a little bit, so I just left it as is and squeezed in ( I have some old fashion steel ramps, I think most newer ramps don't have a clearance issue unless your vehicle is lowered.) All I did was remove 4 screws (4 each side) below the foglight (all were 10mm sized). Remove the 3 screws that hold on the "front fairings" (aerodynamic plastic trim in front of the wheel) and 1 screw just below the foglight that is on the Engine undercover. After those screws are removed then you will be able to pull back the Engine Undercover and have more than enough room to remove and install your bulbs. Then just repeat process on the other side.
* Please note that I am not a mechanic or technician. I am just an average auto enthusiast and I understand that there are a few different ways to do this procedure.
2007 Camry XLE V6
tiswicked is offline   Reply With Quote
Old 12-08-2007, 10:46 AM   #4 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
yeah you just remove the flaps at the bottom, bend them down a bit and then change the bulb. I did have a page of the manual for hte gen5 but im not sure where it is.
CamrySExxx is offline   Reply With Quote
Old 12-08-2007, 12:28 PM   #5 (permalink)
Baby's got a new skirt
ebumdude's Avatar
Gameroom cash: $180662
iTrader Score: 7 reviews
View ebumdude's Photo Gallery
I think the OP might have been talking about the "actual" bulbs themselves......no?
- 07' Camry: LED interior/JDM fogs/Lighted stainless door sills/White cathode footwells front, back & trunk/Kenwood DDX6019/Rockford Fosgate P400-4/TMA T1000/(2) 10" Polk Momo 2104/Polk MM6's front's/Polk db6501's rear's/2.0 farad Tsunami Cap/18" Primax /6000k HID/Tein's
-09' Venza
ebumdude is offline   Reply With Quote
Old 12-08-2007, 01:02 PM   #6 (permalink)
thats possible, changing the lights are pretty easy, pop off the clip but pressing the clip thing and pulling it off, grab the bulb itself twist it and pull out. Replace in reverse order
Old 12-10-2007, 02:24 PM   #7 (permalink)
toyocam08's Avatar
View toyocam08's Photo Gallery
Gen6
Where can you find nokya bulbs can someone post a link to where to purchase them. Thanks
toyocam08 is offline   Reply With Quote
Old 12-10-2007, 03:49 PM   #8 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
eBay
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 12-10-2007, 11:27 PM   #9 (permalink)
The Connoisseur
CharmCityES's Avatar
i have 9005 jdm yellow nokya bulbs in my fogs
i love how they illuminate and how they look....but....
make sure theyre secured and wrapped to prevent moisture from getting in the bulb and socket,....this happened to me and shorted my foglight and melted the socket assembly, and i had to go to the junkyard, cut off a 9005 foglight harness off an avalon, cutb the old onw out and soldier the wires together...works fine now but i caution you....always protect electrical componets
-corey
The "Executive Sedan"
Old 12-10-2007, 11:48 PM   #10 (permalink)
ebumdude's Avatar
-corey
9005 jdm's will work without blowing a fuse or anything? if so, I am sold and switching to yellow's.
-09' Venza
Old 12-11-2007, 01:04 AM   #11 (permalink)
The Connoisseur
yes they will....but you will need to do some minor modifications
9006 housings (oem camry fogs) have a single plastic tab inside the light that fits a groove on the harness to lock it into place....9005 harnesses have two smaller tabs that fit two smaller grooves on the housings....the key is to cut down the small two tabs and get the inside of the housing as flat as possible in order to make it fit....without the tabs its a perfect fit...just make sure everything is tight and well secured and well protected frpom the elements before reinstall and you're ready, set and go
Old 12-11-2007, 01:11 AM   #12 (permalink)
ebumdude's Avatar
Gen6
no OEM fogs for me. I got the JDM aftermarket's from flea bay.
I don't want to f*ck anything up, plus I'm happy with the whites I have now.
Thanks for the info though, I do appreciate it.
-09' Venza
Old 12-11-2007, 01:42 AM   #13 (permalink)
Forgive meee.
liquidi3ladz's Avatar
View liquidi3ladz's Photo Gallery
-corey
Yeah! hah omg I should check if any melting occured. D:
2002 Camry LE I4
liquidi3ladz is offline   Reply With Quote
Old 12-11-2007, 10:51 AM   #14 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
No, just wait for the fire...............
Old 12-11-2007, 11:17 AM   #15 (permalink)
View ansyR's Photo Gallery
Why are you such an ass? In every one of your replies, it's always something bitter, sarcastic, and those damn ...............
ansyR is offline   Reply With Quote
Silverstar "Ultra" fredster34 5th & 6th Generation (2002-2006 & 2007-2011) 35 07-22-2007 11:55 AM
PIAA Super Plasma GTX Bulbs? 360glitch 3rd & 4th Generation (1992–1996 & 1997–2001) 7 03-02-2007 10:43 PM
05 rolla S replacement headlight and foglight bulbs BlakJak07 Archived Corolla threads 7 02-27-2007 04:30 PM
Changing Gen 3 Climate Control bulbs. ARG! HELP!!!! ASG14 3rd & 4th Generation (1992–1996 & 1997–2001) 3 10-26-2005 08:12 AM
changing light bulbs... l_touring_dude Archived Corolla threads 6 03-26-2004 05:36 AM
