Newbie needs advice on V6 Camry purchase - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-08-2007, 10:14 AM   #1 (permalink)
View 44rbs's Photo Gallery
Question Newbie needs advice on V6 Camry purchase
Newbie to this site and Toyota. I am in the market for a used V6 Camry maybe 06 or 07. I hear there are V6 or transmission problems. Can someone summarize the issue and how to avoid.
Thanks Randy
44rbs is offline   Reply With Quote
Old 12-08-2007, 10:43 AM   #2 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
Well the V6 transmission problem is with the newer generation (2007+), although in reality people make a bigger deal of it then what it really is, and not everyone experiences it.
If you are trying to decide between a 2006 and 2007 model, the 2007 year was a re-design, and it received a new 3.5L engine and 6-speed transmission, whereas the 2006 model only has a 3.0/3.3L and a 5-speed transmission.
geoff5093 is offline   Reply With Quote
Old 12-08-2007, 11:20 AM   #3 (permalink)
View moeharri's Photo Gallery
geoff, do you have the flare? I can tell you it IS a big deal, a safety concern, and very, very irritating when hard earned money is spent on an obviously flawed car that Toyota has no intention of fixing. While I do think the engine is nice, if you get a bad transmission, it sure spoils the fun.
2007 LE V6 Magnetic Gray, JBL, Moonroof, Toyota Leather Shift Knob, Toyota All Weather Mats, SE Grille, Wheelskins cover
2007 Odyssey EX (traded in 05 XLE I4 Lunar Mist)
moeharri is offline   Reply With Quote
Old 12-08-2007, 01:32 PM   #4 (permalink)
geoff5093's Avatar
Yes I have the flare, however it only revs up between 200-400RPM's. I've seen a few members who have it up to 1K RPM's, and I can see that being a problem, but how can this really be a safety concern? It still drives great and after that initial flare on startup it doesn't happen again for a while. I guess since I drive my car so much (already 16K+ miles), you just get used to it.
I don't know how the flare will effect the transmission long term, however if the only effect is the current 200-400RPM flare on 3rd to 4th shift, I can easily live with it.
Old 12-08-2007, 02:06 PM   #5 (permalink)
Have you had the TSB done? If not, I'd recommend not. I thought about living with the 3-4 flare, but decided to TRUST Toyota and get it applied. Now I have the flare (about 500RPM) on every shift, all day long (instead of only on the 3-4 shift when the car wasn't warmed up). Toyota using its customers are guinea pigs for testing their fixes is ridiculous. They should BUY back every single car that has this problem and use them to fix the problem. If it's really so few cars, they shouldn't have any problem buying back these cars and developing a real solution.
Old 12-08-2007, 02:44 PM   #6 (permalink)
geoff5093's Avatar
Thats what I heard. I havent had it fixed yet, however I did bring it in for them to check and have it documented. I thought that if it did get worse, the car would be worth less if I had to get the transmission replaced.
Old 12-08-2007, 04:25 PM   #7 (permalink)
Thanks Geoff . So the issue is 2007 with 6 speed auto (V6) have a surge or flare of 400 to 1000 rpm in the 3-4 shift. That it? And apparently Toyota has issued a TSB which doesn't fix the problem.
Does the Avalon share the same 6 speed as the Camry?
Old 12-08-2007, 06:04 PM   #8 (permalink)
Blue Ribbon FTW!
fdexclpl's Avatar
View fdexclpl's Photo Gallery
Not all V6 Camrys have the "flare"
The Avalon uses the same transmission.
'07 Camry LE V6 - Blue Ribbon Metallic - 6-disc JBL - Moonroof
Someday I will list my mods here
Originally Posted by TRD VVTi View Post
I am a hater in one regard, I hate stupid.
fdexclpl is offline   Reply With Quote
Old 12-08-2007, 08:01 PM   #9 (permalink)
silverSEV6's Avatar
View silverSEV6's Photo Gallery
Gen6
I have never had the flare, and alot of us dont. For Avalon, only the facelifted 2008 has the 6-speed. 2005, 2006 and 2007 have the 5-speed.
Camry SE V6 Silver | Dark Charcoal leather with heated seats | Moonroof | JBL stereo with 6-dics changer | Auto-dimmer with compass
MODS: 30% tint all around | Moved SE emblem to the upper-right corner | Blue LED's on steering wheel and shifter | K&N Drop-In air filter | White LED lights inside
silverSEV6 is offline   Reply With Quote
Old 12-08-2007, 09:09 PM   #10 (permalink)
View clarkgrizwald's Photo Gallery
flare or no flare the new camrys are good cars. BUT dont believe the hype! get a gen 5.5! the last of the mohicans!!!
clarkgrizwald is offline   Reply With Quote
Old 12-08-2007, 10:16 PM   #11 (permalink)
2007 Camry SE V6
View dirtrat's Photo Gallery
I've had my Gen 6 for over a year and a half and have no flare with my 6 speed.
dirtrat is offline   Reply With Quote
Old 12-09-2007, 01:15 AM   #12 (permalink)
View marc780's Photo Gallery
i own two V6, a 2001 solara and a 2002 camry. They are the best cars i have ever owned (10 in all over the years - 2 sentras, a nissan pickup i still own, a VW rabbit - ugh - etc.). The 2002 just ticked over 100k, no problems whatsoever with either of them.
But if i were buying now, i'd avoid the 2007's and later, i have read posts from many people here about all the problems with them. I'd pick a 2006 model or older unless and until they get the Camrys unf^cked. If it turns out they never do, then my next car will be Honda or Nissan.
Old 12-09-2007, 07:11 AM   #13 (permalink)
geoff5093's Avatar
Both years have great Camry's, some may say the Gen 5.5 2006 is better while some say the 2007 is better.
As I already mentioned to you however, the 2006 model (except SE) only has a 3.0L 210HP or so engine and a 5-speed automatic. The 2007 has a 3.5L 268HP engine and 6-speed automatic, just something to consider.
Old 01-01-2008, 08:04 AM   #14 (permalink)
View Stangar's Photo Gallery
Sooo, . . . . has the "flare" problem of the 6 speed transmission been fixed in
the 2008 model year? Thanks for your response.
Stangar is offline   Reply With Quote
Old 01-01-2008, 08:16 AM   #15 (permalink)
View kendallKICKASS's Photo Gallery
it really depends on ur personal likes in a car i have a 1999 camry 4cyl and i think they the best u can get for lasting forever. my mom gave it to me when i got my dl's and when she got it it had 44k miles now it has 220k and only been in the shop for mods that i have put on it. but the 2007 camry's totally kickass they faster then the other gens and just like all camry's reliable just make sure the dealer tells u if it is one that have a tranny problem
kendallKICKASS is offline   Reply With Quote
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 06:20 PM
Purchase advice: 2004 Camry SE V6 or 2005 SE I4 Sedan Man 5th & 6th Generation (2002-2006 & 2007-2011) 30 08-23-2007 06:53 AM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
Need to Purchase Parts for 95 Camry Auto V6 satexascamry 3rd & 4th Generation (1992–1996 & 1997–2001) 0 10-24-2004 01:02 PM
