Disable TPMS - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-11-2007, 07:36 PM   #1 (permalink)
View proteus220's Photo Gallery
Disable TPMS
Hello, I wish to inquire if anyone knows how to disable the TPMS system for the 2007 Camry? I will be getting new wheels soon and do not wish to use the TPMS for I do check tire pressures regularly.
Also, reading about TPMS, it has a battery life of a couple years at which point the valves and system will need to be replaced and reprogrammed again (dealer just quoted $175 PER sensor.) I prefer the simple valves that Costco or any tire store uses, even if new TPMS sensor can be purchased on ebay for $80/set of 4, let alone waiting at the dealer to "program" the sensors which they will probably charge another $60/hr for labor.
Thanks for anyone's input.
proteus220 is offline   Reply With Quote
Old 12-11-2007, 07:42 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
You cannot disable TPMS; however, some people have installed aftermarket wheels on their cars without the sensors and have had no issues other than the light coming on once in a while.
2007 Camry 2.4L 5M
Old 12-11-2007, 07:45 PM   #3 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184780
View DrewsCam's Photo Gallery
just a thought cant the light be pulled out, i think i am going to do that when i get new rims in the fall
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 12-11-2007, 08:13 PM   #4 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
The TPMS warning light should either be a bulb or LED, which should be able to be removed/covered up from the back of the speedometer cluster.
geoff5093 is offline   Reply With Quote
TPMS bypass DIY ncpaladin 2nd Generation (2005+) 127 08-19-2011 10:06 AM
anyone have better pics of the tpms disable mod? 6shooter 2nd Generation (2005+) 2 11-18-2007 09:58 PM
TPMS light was on this morning.... BigWillie 5th & 6th Generation (2002-2006 & 2007-2011) 7 09-23-2007 11:32 AM
'07 tpms disable? livewire102 2nd Generation (2005+) 0 04-02-2007 06:46 PM
TPMS Questions Brandon402 5th & 6th Generation (2002-2006 & 2007-2011) 11 02-23-2007 12:11 PM
